integrated amplifier for 2 thousand dollars
Leo Tos
Hello! I read your site for a long time, I decided to register myself and ask a question. I need help choosing an integrated amplifier in the price range up to 2 thousand dollars. The requirements are simple: 100 watts into 8 ohms and low THD. So far I have selected Hegel h120 and Nad c388 for myself. I would be glad if you share your opinion and suggest the best options. (I have 3-way DIY speakers on Scan-Speak Revelator.) Thank you!
CDMC
Matias
São Paulo, Brazil
SIY
Alfred, NY
Check out the new offering from Orchard. More power than you need, low distortion.
Alexanderc
Florida, USA
CDMC
If you’re not set on an integrated:
MiniDSP SHD $1200
March Audio P122 or P252 currently $652.50 and $805.50 respectively
Gives you everything you asked for plus Dirac room correction and streaming.
https://www.minidsp.com/products/sh...MI7s-j2OLy6gIVS7LICh3hnwWDEAAYASAAEgJBYfD_BwE
https://www.marchaudio.net.au/
This or swapping out the minidsp for a RME ADI-2 FS would be my choice. I skip the P122 and get the P252, as a bit of extra headroom never hurts and covers if a change to less efficient speakers Happens down the road.
Matias
São Paulo, Brazil
+1 for RME ADI-2 DAC FS v2 and NCore. :)
Archsam
London, UK
Canuck57
Fergus, ON Canada
Kegemusha
The Atolls are pretty good, this is 120W@8Ohm and you can add a DAC as a module into it.
Leo Tos
Leo Tos
Atoll and Rotel amplifiers have higher distortion at volume up to 1W than even the Hegel. I will look for graphs of measurements of March Audio and Nord. I haven't thought about DSP yet, I have an internal crossover in the speakers. Perhaps in the future I will switch to DSP.
Leo Tos
Leo Tos
there is a Polish site https://audio.com.pl/
In the Hi-Fi Test section there are many graphs of measurements of audio equipment. This site helped me to discard very bad options. maybe it will be interesting to someone.
Vasr
"Integrated" varies a lot on what that includes. Your requirements don't say anything about that part. So, as expected, it will become a laundry list of anything integrated anybody likes.
Digital input? How many? Your selection implies yes
Streamers inside?
WiFi ability?
Analog input? How many? Phono?
XLR inputs needed?
Need a crossover to sub output?
Need a trigger input?
Need HT bypass?
Need a remote?
Need room EQ? Or a monitor out to include EQ chain?
FrantzM
miniDSP SHD Power is high on my list ... Provides a lot for $1500... Can be center of a top flight system , assuming its performance is in line with the SHD Studio.
Cahudson42
To be contrarian for a second, why not a Denon AVR-X3600H? Or X3700H if you want to add more than two external power amps later?
Yes, you are only going to use two channels to start. But perhaps with it only driving two, the transformer and PS won't in use seem undersized.
But if you are unhappy with the internal amps, you run it as a preamp and add power amps instead.
You also get Audessey xt32..
https://audiosciencereview.com/forum/index.php?threads/denon-avr-x3600h-av-receiver-review.12676/
Leo Tos
Leo Tos
Streamers inside?
WiFi ability?
XLR inputs needed?
Need HT bypass?
Need a remote?
I don't have big requirements for an amplifier. in the classical sense, an integrated amplifier is a preamplifier and a power amplifier assembled on one chassis. further there are nuances. of course it would be nice to have a coaxial input, bluetooth, etc., but the main thing is gain and a volume control knob
Leo Tos
Leo Tos
for me the most important thing is a minimum of distortion at all volume levels, even at the lowest. at the same time, the power must be sufficient to bang where it is necessary. slew rate is also important. this is a very important parameter and an important dimension. on the stereophile, few amplifiers had a truly rectangular pulse. thanks for the links to the March Audio measurements.
Leo Tos
Leo Tos
and also, thanks to everyone who responded to my request for help and offered solutions to the problem. it is very nice.
Vasr
At this "level of clarity" on the requirement, I would strongly recommend a DAC with volume control (which can be quite small in foot print if space is an issue) and a separate power amp rather than an integrated. If your needs for the pre-amp change in the future (and they will), then you have to replace the whole thing which can be a waste if the power amp was a good one.
A $200-$400 DAC and a $800-$1200 amp should set you up nicely and the amp will last for a long time if and when you outgrow the DAC. You can get much better "measured well" choices this way.
The choices within integrated will be much more limited compromising on the pre-amp or the power-amp or both. If you want to spend a bit more you can get a DAC with a DSP in it. Or a stereo pre-amp with more inputs and/or bass management to future proof.
