integrated amplifier for 2 thousand dollars
Geert
Atoll and Rotel amplifiers have higher distortion at volume up to 1W than even the Hegel.
I have the Atoll IN200 Signature (with DAC) and I really like it. Where did you find distortion figures?
Leo Tos
Leo Tos
Panelhead
There are a LOT great options.
I looked at low power performance to see what measured best at 50 - 300 mW. The Purifi based units looked great. The Orchard BOSC maybe a little better. At least with low power output levels.
The Denafrips Hyperion looks good if Class AB is a priority. Class AB gets my vote, wider bandwidth. My current amps are are listed as -0.5 dB at 100Khz. I think extended top end is a good thing.
Just like 0.000X% THD + N levels you cannot hear the higher bandwidth. Just if you are spending your own money, pick what clicks your boxes.
Wes
You mention good slew rate, but is that still an issue in amp design?
Neale
Perth, Australia
At this "level of clarity" on the requirement, I would strongly recommend a DAC with volume control (which can be quite small in foot print if space is an issue) and a separate power amp rather than an integrated.
^^ agree with this, but wish there were more DACs available with an analog input or two; have asked about this in a separate ASR thread
restorer-john
slew rate is also important. this is a very important parameter and an important dimension. on the stereophile, few amplifiers had a truly rectangular pulse.
You will open up a huge can of worms with this requirement. If you want a perfect square wave, you will rule out any and all Class D amplifiers and by doing so, the superior performance aspects that class of amplifier can deliver.
SIY
Alfred, NY
You can still get a pretty good one. This was taken with a 1.2mHz bandwidth- if I had taken it down to a 192k sample rate, the 150-180 mV of ultrasonic noise would vanish.
restorer-john
2KHz square, rise time of roughly 10uS so a ~100KHz bandwidth? Is that one of these GaN FET Bosc amplifiers?
That's the analogue generator's square wave on the AP?
SIY
Alfred, NY
No on both counts. That's the Purifi. And the "regular" square wave on the AP (I use a 525, which doesn't have an analog square wave output).
Here's the BOSC; more ultrasonic noise (700mV or so), but at a higher frequency:
restorer-john
Pavel will be here soon, you know he will... ;)
And how do they look at large signal levels (above 2W)?
restorer-john
I thought you had a 555 as well? I had hoped AP would let you keep it, you know, for singing its praises and all.
SIY
Alfred, NY
Cool, I like him, but he's committed to old-fashioned amp design. I'm not, but admittedly I can't design Class D stuff at the level that I can do solid state or tubes.
Everything looks pretty much the same at higher levels and with my simulated speaker dummy load, other than the ultrasonics from the amp switching are proportionately smaller.
Darvis
Belgium
If you’re not set on an integrated:
MiniDSP SHD $1200
March Audio P122 or P252 currently $652.50 and $805.50 respectively
Gives you everything you asked for plus Dirac room correction and streaming.
https://www.minidsp.com/products/sh...MI7s-j2OLy6gIVS7LICh3hnwWDEAAYASAAEgJBYfD_BwE
https://www.marchaudio.net.au/
That's the perfect answer/solution IMHO. I don't understand why someone would avoid dirac if one has the budget for it. We spend hours and hours discussing and analyzing minuscule SQ differences between amps, and there lies a technology that obliterates those differences to bring this whole hobby to another level.
Panelhead
I have to agree. Swapped backward to an old dac with Room Perfect. The DRC really has a positive effect on my speakers and room.
The dac has lower specs and measurements than the dac it replaced , yet made an noticeable change.
To me it showed that in some applications DRC is better than having SOTA performance.
jrampoldi
FYI, the Hegel H90s are down to $1,400 at Dedicated Audio or Safe and Sound. This is due to the arrival of the H95.
Lavawood
Any updates a year in?
My integrated just crapped out.
It’s worth repairing but I need a stand in.
I like the SHD power, but my turntable is left out.
need 100 watts plus
Usb and optical in
Phono or analog in
WiFi streaming would be nice but I have a pc input (usb)
I have separate usb and optical DACs now.
Remote.
