Integrated to drive Tekton Lore Reference
TheInquiring
Dear experts!
I need your advice on a solid-state integrated amp to drive a pair of these Tektons to moderate levels (65 - 70 dB) in a modest Hi-Fi music-only setup, please.
Budget: would like to stay below $500 (flexible, within reason).
Please chime in!
RayDunzl
Central Scrutinizer
Riverview FL
Nobody knows!
Wombat
Australia
Any long-lived brand name with 50-100W per channel.
TheInquiring
TheInquiring
Thank you!
Some examples (concrete models, if at all possible, please) would be very helpful... In your opinion, should I also consider ChiFi (I am a bit reluctant here, to tell you the truth)?
Dialectic
a fortified compound
Here's an answer you may not want to hear: sell the Tektons and get some reasonably priced and well engineered actives. It will save you money, heartache, and headaches in the long run.
Ron Texas
Don't agree.
To the OP, if Chi Fi breaks, you are out of luck.
Look at integrated amps from Onkyo, Marantz and Sony and NAD. Tektons are efficient, so you can stick to the low end of the 50-100 range. I am not up on specific models. There are many and they change frequently. Look for reviews particularly on Cnet and What Hi-Fi.
DonH56
Monument, CO
96 dB/W/m means a pair about 10' away will produce almost 110 dB with 50 W to each speaker. They claim 8-ohm average impedance. Most any name-brand amplifier will suit.
I have never ordered from this place but they have a selection of amplifiers: http://www.audioadvisor.com/product...tegrated$2520Amplifiers/sort:ss_price_min:asc Here is another list: https://www.listenup.com/shop/electronics/integrated-amplifiers.html
Look over features and prices then search for a local or online dealer you like. I would look a little higher than $500, maybe up to about $750 retail, and look for (or negotiate) a deal. Retail prices often include 30-40% markup so you may be able to save 10%-30%, more if you find a clearance or other special. And there is always the used market.
You might also consider an entry-level AVR. That way you get a tuner (radio) as well, and since there are so many you can probably find a good one cheaper than an integrated amp (since the latter tend to be more of a specialty item). You just wouldn't use the extra amplifier channels and processing modes. You might, however, find you appreciate room correction (or not).
Sal1950
The Chicago Crusher
Central Fl
Dear experts!
Please chime in!
Marantz, Some nice units were on sale at Audio Adviser
TheInquiring
TheInquiring
Thank you very much!
In your opinion, dear experts, how important is it to have a fully balanced signal path (balanced all the way through means x2 parts of SE...)? Do we have any objective evidence to support such requirements?
Wombat
Australia
DonH56
Monument, CO
There are numerous theoretical and practical advantages for some applications. Consumer audio is not usually one if them. I did write a article on ground loops that shows how balanced can help, and if you have a (very) high noise environment they can help, but most don't need them. Personally that would be very low on my feature list. I also misdoubt there will be many fully-balanced (differential) units at the $500 USD and under price point (but not something I have researched!)
FWIWFM - Don
TheInquiring
TheInquiring
I must confess in recent auditions I was unable to tell balanced from SE (level matched) and now am just looking for a musical integrated, as you, dear experts, suggested me a long time ago.
On my radar at the moment:
NAD c326bee
Rega Mira 3
Marantz PM6005
Cambridge Audio Azur 640A V2
Would you kindly give me your opinion on the above integrated amps, please?
What alternatives should I also consider, please?
Please chime in!
Sal1950
The Chicago Crusher
Central Fl
Sound quality wise I believe they will all supply a top flight performance.
Compare the features that will suit your needs best.
Wombat
Australia
NAD c326bee
Rega Mira 3
Marantz PM6005
Please chime in!
I have the NAD C 326BEE. I use it to drive horn-mounted Altec 802 compression drivers from 500Hz upwards. I am happy with it. No issues.
Lots of inputs(RCA only). No phono pre. Tone controls, which can be 'defeated', start work closer to each end of the frequency range than most amps. I prefer this.
They are warm to the touch at idle so if you stack it leave a little room above it for air circulation. The top has lots of vent slots.
