IP address Project Stream box s2 Ultra
coinup
Hi all,
I have a stream box s2 ultra, but for some reason my router a tp link AX11000 will not generate an ip address for it, every other device on the network is being allocated one except the s2 ultra. I am using wired LAN.
Any help appreciated.
C
coinup
it is a demo unit from my local dealer, and im thinking Henley audio has given it a static IP address.
Berwhale
Connect to the unit over wi-fi from your phone, then reset the static IP in the Network menu...
digitalfrost
Palatinate, Germany
Install https://www.wireshark.org/ on your PC.
Connect the box directly to the PC with a cable. Open Wireshark and monitor your network interface. Start the box. If there's any incoming connection you should be able to see the IP address.
Then reconfigure your PC to be able to access the box and reset settings.
C
coinup
I m managed I think to find the MAC address and IP address, but cant get any further.
C
coinup
yes ive tried to my tv, but i cant change anything. ive found the IP address etc, but how do i make use of them.
C
coinup
windows 10.
How do i edit or delete the IP address?
AudiOhm
London, Ontario, Canada
Does the IP address fall in the range of your modem?
Most TP link modems use 192.168. 0.1 or 192.168. 1.1
Ohms
digitalfrost
Palatinate, Germany
Press Win+R
Enter
Code:
shell:ConnectionsFolder
Open the Ethernet network adapter
Click Properties
Click Internet Protocol Version 4
Set address. Choose something that is different in the last row from the box but identical before that, for subnetmask if you don't know just enter 255.255.255.0 it will be fine.
You will loose internet connectivity by that point so remember how to get there and how the settings were before.
C
coinup
i dont think it falls in the range.
This is far too confusing.
Thank you for all of your help. ill keep trying
AudiOhm
What is the static IP address?
If your modem is 192.168.0.1, then the normal range would be up to 192.168.0.255...
Have the dealer reset the IP address, the dealer should know better...
Ohms
AudiOhm
192.158.0.69
More than likely the problem, if it is out of range for your particular modem it will never work...
Are you sure it is 158, and not 168?
Ohms
