Is my room too square? 26x24
Mentalrudy
Hi there,
Would you consider a 26x22 ft room too square to be good for sound? It’s exact dimensions are (lxwxh) 26’11” x 22’4” x 8’10” or in the metric system 8m22 x 6m82 x 2m70.
Although not mathematically square, would you consider this to be too square to avoid sonic havoc? (Not asking for dsp and possible room correction solutions, just curious if this room is considered square, in other words: do those 4 feet of extra length make a difference). Thanks in advance for considering this question.
Greets,
Rudy
RayDunzl
Central Scrutinizer
Riverview FL
I'd like a nice big room like that.
Square
Well, almost - 5" difference so the graph wouldn't overlap itself, as with square data, so consider the pairs single lines
Yours
"rooms for recording and playing music are designed to have many resonances that are distributed evenly, rather than just a few resonances at the same or nearby frequencies. "
Blumlein 88
Worst room ever. Fellow had an 11 ft x 11ft x 11ft room made of metal. OMG, how awful the sound. He needed to move his rig from the living room at least for a couple years. This was a possible place he could put it. It lasted about one month. Sacrifices were made elsewhere in the house to end this horror.
I'd think though near square your room is enough un-square to avoid the worst results. As Ray's post shows it isn't a horror show, just not optimum.
Here is the room sim in REW. LP and speaker position makes a difference in the smoothness of the response line though major modes are not much effected. I'm showing only the axial modes.
M
Mentalrudy
Thanks for taking the trouble. I did visit the amroc room mode calculator and it gave more or less the same results, but I wasn’t sure how to evaluate these data. Not optimal indeed. Goid news is: the room is big. It should be able to accomodate large three way floorstanders. At my current LP however here is a annoying vertical bass dip. Standing upright sounds fine, sitting down the bass disappears.
Anyhow, hopefully I can treat the issues with room treatment, or two strategically placed subwoofers and some dsp.
RayDunzl
Central Scrutinizer
Riverview FL
RayDunzl
Central Scrutinizer
Riverview FL
Bass in music is not (very rarely) a single frequency.
Your mind will fill in the blanks based on the harmonics it receives.
"The brain perceives the pitch of a tone not only by its fundamental frequency, but also by the periodicity implied by the relationship between the higher harmonics; we may perceive the same pitch (perhaps with a different timbre) even if the fundamental frequency is missing from a tone."
https://en.wikipedia.org/wiki/Missing_fundamental#:~:text=A harmonic sound is said,at the fundamental frequency itself.&text=Nevertheless, a pitch corresponding to the fundamental may still be heard.
https://auditoryneuroscience.com/pitch/missing-fundamentals
Video Example
My Example:
Single Bass guitar note:
Depending on where you pick the string, the ratio of the fundamental to harmonics changes. It was difficult to pick this note wihout the second harmonic being higher in level. Took many tries.
You might say "Well, it will sound distorted if the fundamental is missing."
Observe the "distortion" measure of that undistorted note above. 22.7% - it has harmonics, it is no longer a pure sine, so, the software says it is distorted.
I can argue that music is distortion, the more, the better.
I have a deep hole around 48Hz in my setup:
Red - left and right
Green - both speakers
I didn't know it was there until I measured.
It's a phase problem, this room is not a closed rectangle, so the phase of the standing waves of a test tone cancel, y travelling different distances, though the sound of either speaker alone doesn't create the dip at the listening position.
When the bass is stereo - the dip can disappear, too, as the phase relationship changes.
Hipper
Herts., England
Depends on what you're playing.
Funny. I was thinking of the Joni Mitchell version.
When I was at junior school, aged ten or so, I was in the playground when this girl, Lesley Humphreys who I never liked, came up to me and said 'you're a square'.
I didn't know what this was but the way she said it made it seem not a good thing to be. 'No I'm not'. I said.
'OK, how many Beatles are there?' (this is 1963). Well, at least I'd heard about the Beatles but I hadn't a clue how many there were.
'Three' I said.
'No, there are four. You're a square'. What could I say.
When I got home that day I asked my Mum what a square was....... Yup, I was a square. I still am although a bit more rounded now!
Duke
Princeton, Texas
Nope.
But if you have free reign in this room, what I WOULD suggest is setting up your speakers along a diagonal. This is what Floyd Toole did in his square-ish home listening room back when he lived in Canada.
And, maybe even set them up not quite on a diagonal, to introduce a bit more diversity into the distances from your woofers to your walls in the horizontal plane. To the extent that your two speakers interact with your room differently in the bass region, their summed output will tend to smooth out a bit.
