- Joined
- May 21, 2019
- Messages
- 4,036
- Likes
- 6,828
What kind did you use?I run my sub from the rca output of the RME ADI-2. I have added a passive high pass filter to the XLR cable from the ADI-2 to the power amplifier.
In the cable, and made to measure by an engineer who also did the calculations. It is similar to the Harrison Labs FMod.What kind did you use?
So why make an LFE input separately? Anyway.... (Biden voice) That's why I sad im new expert
So the Arendal would also work in a 2.1 system well for music.
I've reached out to the customer service of Arendal, they said the sub doesn't have hpl, but wrote this "Our subwoofers have a lowpass filter / crossover, so yes you can set it to 80hz and let your speakers handle the higher frequencies. You will be perfectly safe with that."On some SVS subs, there is a high pass filter on the non-LFE labeled outputs. Check the manual for the sub you are considering to find out the difference.
1. Genelec 7360 *2
2. REL S5 *2
3. Linn akurate sub *2
3. SVS 2000sb *2
4. XTZ cinema 12 *2
Without a very good dsp crossover in the subwoofer it doesnt matter if you have the worlds best drivers or amplifiers.
Edit: only one subwoofer is a waste of money because the soundˋs gonna be worse as soon as you have that sub in your system. Two subwoofers is absolutely nesessary. Its impossible to integrate only one subwoofer in a stereo system, if you want your music to sound better.
This is not high passing in my understanding. The sub has a low pass filter and that is it."Our subwoofers have a lowpass filter / crossover, so yes you can set it to 80hz and let your speakers handle the higher frequencies. You will be perfectly safe with that."
Thats not true at all . It depends .The problem with any REL vs SVS comparison is the SVS wins easily. REL is for people with more money than brains. WAIT!! Did I just say that? Oh, I mean people who want a good looking sub with the REL logo on the driver.
For the music I listen to, sub 20hz does come up. And while SVS prices keep going up, it's still the better value from room to room, unless you wanna do diy.It's for people who put brand over form over function... I mean, people who want a sub that is "musical" and 'fast' and never 'too big for the room' (because it doesn't go deep enough compared to competitors.)
As a term it definitely dosen't have a place. A well designed subwoofer plays "fast" as they describe it, whether sealed, ported, PRs, TL, etc.I would read data-bass.com "Subwoofer myths article" as a starting point
The REL is a true sub, only <80 Hz or so.I just bought the 6 pack of carbon special… setup the dual line array and connected to my Trinnov amethyst. But for the sake of argument it’s irrelevant as the measurement was the same with Trinnov or direct.
Here is rew measurement. To rule out the room i then took measurement with a single Perlisten d15s.
I can’t explain the drop or shelf’s on the rel. makes no sense. Any ideas ?
Orange is rel and teal is Perlisten. This happened no matter where I placed either sub. It happened whether I used 1 or 3 or 6 rels. The shape was always the same.
Simply misuse of the term "crossover"....half a crossover is only half a crossover.I've reached out to the customer service of Arendal, they said the sub doesn't have hpl, but wrote this "Our subwoofers have a lowpass filter / crossover, so yes you can set it to 80hz and let your speakers handle the higher frequencies. You will be perfectly safe with that."
I saw in video that with high passing (?) the bookshelf speaker would be relieved from producing the lows and the sub would take over that job, thus having more power for the speakers.
I'm new to this area of audio tech, would this crossover setting do the job or is it different?
This is bad science. The sub high level connection, regardless of its impedance, sees the phase of the amp. The woofer of the main speaker driver is behind at least an inductor and parallel with a capacitor and also often in series with a baffle step network. All of these effect phase. The sub is between an 8 ohm speaker and a ~0 ohm amp output impedance, so it just sees the amps output.I prefer the high level inputs if the sub is designed around them.
The speaker load determines the signal phase. Since the speaker load of8 Ohm is much larger than the sub 150 kOhm it determines the phase. The sub will see the same phase as the speaker. If the sub is fast enough it will follow the speaker in lock step (or close).
