JBL 4367
dallasjustice
dallasjustice
Dallas, Texas
Did you decide after your investigation of the cabinet to go active?
Yes. I found a pair of M2. I’m going to pick them up Saturday. Because the M2 was designed for that purpose, it makes much more sense to use them. Ill miss the 4367 speakers tho. They were wonderful.
RayDunzl
Central Scrutinizer
Riverview FL
I'm having trouble resisting your post...
Dialectic
a fortified compound
Congrats! Will you continue to employ the Benchmark stack with the M2s?
Wombat
Australia
RayDunzl
Central Scrutinizer
Riverview FL
100 views an hour so far...
Sal1950
The Chicago Crusher
Central Fl
dallasjustice
dallasjustice
Dallas, Texas
Your suggestion I try out the M2 instead of trying to convert the 4367 turned out to be very good advice. I’m glad I didn’t try to play engineer. I’m just a lawyer.
dallasjustice
dallasjustice
Dallas, Texas
Yes. The Benchmark gear is really the thing that got my wheels turning again about using my own crossovers and EQ for the M2. I’d thought about it before. But now I can see how the gear part of it makes it easy.
Dialectic
Very interesting. Will you add a second Benchmark DAC or perhaps replace the DAC with a hardware digital crossover?
dallasjustice
dallasjustice
Dallas, Texas
The crossover will be similar to an NT 2 octave. FIR generated by Audiolense. I use Jriver convolver for routing. The Lynx Hilo is the heart of the digital setup. The Hilo will use four analog outs and the benchmark connect to Hilo over AES will use 2 analog outs. So a total of 6 channels.
svart-hvitt
Lawyer?
That explains your flexible budget!
I read your investigations and tests with great interest.
Sal1950
The Chicago Crusher
Central Fl
Anxiously await the reports. ;)
RayDunzl
Central Scrutinizer
Riverview FL
Well, that should cure my anxiety attacks (assuming they were sold...)
There were 1325 views a couple of hours ago. Seems quite brisk.
dallasjustice
dallasjustice
Dallas, Texas
Sold.
dallasjustice
dallasjustice
Dallas, Texas
I’ve sold a lot of audio gear on audiogon. I used to think Krell had the most interest and highest resale versus price paid. I remember I sold my Krell 900e amps for a little less than I paid for them.
But now, it’s clear to me that JBL does even better WRT resale. I sold them in less than 24 hours for almost asking price.
RayDunzl
Central Scrutinizer
Riverview FL
You didn't give all your new buddies here any advance warning!
