- Joined
- Jun 19, 2018
- Messages
- 6,652
- Likes
- 9,408
It is a single measurement with a sweep at my listening position. Bass MGMT is with Audiolense using Roon’s convolver. The sub crosses over to the mains at 98 Hz.
Let me check the time domain.
How would you recommend to measure things more meaningful?
Ok thanks. Unfortunately I don't have first-hand experience with Audiolense, though I know others here do. But there are a couple of things I can say that may account for why you seem to be hearing something different from what the measurement shows.
Firstly, basing your correction curve on only one measurement is not optimal. It would be better to take multiple measurements from at and around the listening position and to average these, then to use the averaged response to derive your correction curve. This is basically because you have two ears which are not in the same location, and you don't have your head in a vice while listening.
Secondly, it looks to me as though perhaps your correction filter is too finely tuned. You won't hear every narrow-band peak and dip that a measurement shows. In other words, your correction filter may be overcompensating, correcting errors that you don't hear and possibly thereby creating ones that you do hear. It's hard for me to say though without having used Audiolense and without knowing exactly what it did to create the curve it created for your system.
Hopefully others here with experience with Audiolense can chime in here and help out...
