JDS Atom Amp+ Review (Headphone Amplifier)
This is a review and detailed measurements of the JDS Labs Atom Amp+ headphone amplifier. It was sent to me by the company and costs US $99. It was announced today.
The Amp+ follows the same recent industrial design in JDS amps and dacs:
It is light but functional. Dual gains are provided and single 1/4 headphone jack. The input selector chooses between 3.5 mm and RCA connectors in the back:
As you see power is provided through an external AC transformer.
JDS Labs Atom Amp+ Measurements
As usual we start with our "unity gain" setting which means the same input voltage is produced at the output. In the case of unbalanced amplifiers, I use 2 volts which is the nominal maximum output of desktop DACs:
I would expect stellar performance from JDS and that is exactly what we see. Distortion is incredibly low at -130 dB (15 dB better than threshold of hearing). A 60 Hz tone is also visible but it is ordinarily buried in the broadband noise level as you see in a bit. For now, SINAD which characterizes noise+distortion is near top of the class:
Signal to noise ratio at unit gain and 50 mv are excellent:
As you see the noise floor is at -121 dB which is higher than the mains noise I indicated above. Still, this is extremely good performance with 20+ bits of dynamic range at 2 volt out, and 15 bits with just 50 mv out (adjusted by turning down the volume):
Frequency response is one of the widest and flattest I have measured:
Power into 300 ohm is healthy 248 milliwatts (my threshold is 100 mw):
In either gain, there is no clipping so if you hear some, it is your headphone!
Switching to 32 ohm load, there is clipping now in high gain:
Distortion rises a bit with lower impedance which you can see better when I sweep from 600 down to 12 ohm:
JDS Labs Atom Amp+ THD vs frequency vs power Measurements Headphone Amplifier.png
Channel balance is specified at 0.6 dB. My testing shows even better results:
JDS Atom Amp+ Listening Tests
The Amp+ had no trouble driving my Sennheiser HD650 to hearing loss territory with incredible dynamics, bass and lack of distortion. Switching to much lower impedance Ether CX showed a bit of limit at the highest outputs with a touch of distortion. By then though, I could only tolerate the sound for a few seconds so for any "normal" listening, there is excellent fidelity there.
JDS Labs targets 99% of the state of the art in headphone performance and delivers. It is a breath of fresh air to check my measurements against their specs and see them very closely match with no weasel words used to get better numbers. Company has impeccable reputation for excellent customer service which when combined with such a low cost, means a winner in my book.
It is my pleasure to put JDS Labs Atom Amp+ on my recommendation list.
Zensō
California
What's the difference between this and the last Atom amp?
From the JDS blog:
Aside from subtle fit and finish improvements since release, we’re tagging “Atom Amp+” because we’ve boosted performance using the same analog IC employed in the matching Atom DAC+. More importantly, every Atom Amp+ is built with hand matched potentiometers for superior low volume imaging, up to 20dB better than the originally spec’ed Alps pots.
More here: https://blog.jdslabs.com/2021/07/jds-labs-atom-amp-is-now-atom-amp-plus/
raif71
I almost gave this thread a miss...thought it was the older jds atom thread. Luckily I saw, "today" at the date. What did jds lab do differently in the design or selection of components to improve the atom?
How is the volume knob and the chassis? They were horribly plastic and cheap in the normal previous version.
Basically the same although I think the feet are larger/stickier.
phoenixsong
I like how they've always paid attention to the channel balance of their amps. My o2 amp from them was clearly better in this regard compared o the one from Massdrop
filo97s
Sestri Levante
Is still LME49600-based like the old atom right?
From the JDS blog, it seems they've changed only the input stage
JohnYang1997
China
It sounds like they changed the opamps to lm4562/lme49720. Just like their EL series.
One dual opamp per channel. Each opamp has half for gain stage and half for controlling lme49600.
Helicopter
Michigan
Thanks Amir. This is really impressive, beating Heresy on SINAD and the aesthetic is better than their old products. Topping and Schiit are still better looking but no complaints about the look of this at $99. Does this have protection like IEMagni?
