John Atkinson's of Stereophile Talks About Measurements
ahofer
New York City
I don't find his comments that egregious to be honest, more like head nodding and argument avoidance. The actual video Amir linked to in the OP is virtually without any particular commentary I find disagreeable. Did I miss something?
The part where he asserts how Ethernet cables sound different is disturbing.
pozz
Слава Україні
Editor
Perhaps that's because your threshold is set high, and you are used to the sort of misdirection and ambiguity that guide professional conversations. A good pro is not one who is easily taken in, after all.
I don't find JA all that egregious, especially given the balance he has to maintain.
Once more: Atkinsion provides the measurements of the gear and useful, understandable explanations of what they mean. That's not a trivial contribution for those interested enough to take a deeper dive. I said that I give him more shade than you do because he has to do business in his environment every day. That's enough for me. I accept the measurements and tend to gloss over the rest. I know what I think....cables, schmables. People sufficiently experienced in this business should feel reasonably well served in general by taking that attitude. If one is not so experienced, one is, I suppose a possible mark.
I think your final sentence above is the point. The not-so experienced are not well-served by Stereophile's mix of science, romance and business.
Beershaun
Interesting to hear his criteria and observations on amplifiers and speakers. They are pretty much consistent with what our own Amir does for this site if my notes were correct.
@amirm are there any of his amplifier or speaker criteria stand out as something you don't already have covered in your tests that are worth adding or affect your weighting? Much of what he said is consistent with your measurements and graphs already but thought I'd write down what I heard to get your feedback.
I heard but may have missed things about amplifier criteria:
1)must be powerful enough
2)overall distortion and noise levels levels should be low
3)no/low distortion beyond 2nd or 3rd order harmonics
4)distortion and harmonic mix is the same across all frequencies.
5)distortion and harmonic mix is the same across the entire power range.
6)overall the amplifier behaves consistently across it's rated power range and frequency range.
I heard but may have missed things about speaker criteria, which seemed like a combination of empirically distinct measurements and managing to optimize the entire mechanical system:
1)is on axis response flat. Is the first launch of the wave from the speaker accurate and consistent across the frequency range.
2) do they handle off axis response flat and first reflection flat and well managed.
3)does the manufacturer understand the limits and weaknesses of the speaker and adjust to them to optimize as best they can to compensate for those weaknesses.
4) Speakers that physically have to move less will produce less distortion.
5) temperature plays a role in the performance of a speaker and speaker components have an optimal temperature range and may need to warm up.
6)Distortion
7) Resonances
8)Port resonances
9)speaker modulation noise
10)resonance across the rated frequency band
11)physically bigger speakers can give you a larger soundstage/presentation, more bass, louder volume than smaller ones.
I don't think so. Membership asks for some of his measurements like waterfalls and step functions but I personally find them of little value. Too many graphs can be a turn off to many who read such reports so I have a very high bar for adding more tests.
Unclevanya
Most Musicians dont hear there instruments the way they were meant to, in the audiance. Theres a huge difference in sound between the back of a trumpet and 10' in front of it. Maybe not as dramatic but this goes for every acoustic instrument. ( electric lets you pick your source position). So a trumpet player ( unless he listen to recordings) is the last guy to ask what a trumpet should sound like.
I don't know any musicians - especially jazz players - who don't spend time listening to other players live and recorded. To say they don't know what their instrument sounds like is ludicrous.
ahofer
New York City
Beershaun
What do you think about his statement around penalizing heavier on higher order harmonics and being "more okay with" 2nd and 3rd order harmonic distortion? I took this to mean: if two amps have similar THD the amp with less disturbance after the 3rd order harmonic should perform better and be more desirable than the other.
Blumlein 88
No not ludicrous at all.
The thing that is a bit of a myth is getting sound like the artist intended. The artist doesn't know what he sounds like 10 feet away. Even more so a group of musicians. They hear themselves in a way you can't, and a group complicates it even further. So what they intend can be questioned if they want a certain sound. But whether that represents any kind of sonic accuracy is another question and one the musicians aren't best positioned to decide.
Now yes, musicians hear other musicians and know what the instrument sounds like, but in giving tips on their own playing they really aren't in the best position. That is without getting into how it is impossible for most to hear themselves playing the same way they hear others.
That's why I show the full spectrum using FFT in the dashboard.
Blumlein 88
You see this idea a lot. It makes some kind of sense. Where I see it fall down is when 2nd and 3rd harmonics are more than -90 db down for a pair of amps. However, one amp has nothing else above that and another has a few more harmonics at even lower levels. I don't think you'll hear a difference between them whatsoever.
Blaspheme
I'm just posting because I searched for something else and this came up, so I get to laugh at the thread title: John Atkinson's of Stereophile. Was somebody drunk? Am I reading Chaucer?
DonH56
Monument, CO
Why? His measurements are the main reason I still read Stereophile. And Kal's reviews, natch. ;)
FWIW, Both John and Kal are members of ASR and post here occasionally.
Blaspheme
Not that, JA and KR are exemplary—I was looking for an article by JA that ahofer was thinking of in another thread, because I read it recently. My mirth came from the compound errors of plural and possession in this thread title. People routinely trip over apostrophes, but this one is a bit special.
Edit: found it, I'll head back.
MyCuriosity
Have been reading John’s reviews and measurements for years. By far my favorite writer/reviewer. He is a true gentleman
Cbdb2
Vancouver
When you spend 90% of your time behind a trumpet it will effect what you think a trumpet will sound like.
MRC01
Pacific Northwest
Most Musicians dont hear there instruments the way they were meant to, in the audiance. Theres a huge difference in sound between the back of a trumpet and 10' in front of it. ...
The point is that acoustic instruments sound significantly different to the musician playing them, than to the audience. And since each musician produces a different tone from the same instrument, you can listen to all the recorded and live music you want without knowing exactly what you sound like to the audience. You have a good idea, of course, but it's not precise. And, when trying different instruments, you have to keep in mind that what it sounds like to you, isn't the same as what it sounds like to the audience, so the instrument that sounds best to you while playing might not be the one that sounds best in your recordings or that you use for performances.
I have started to learn to play the piano. Hearing the real instrument on a frequent basis has provided no insight whatsoever when it comes to fidelity assessment and our hobby as a whole. My piano teacher is not an audiophile and gives me blank looks when I talk about what I do! So really, the two have little to do with each other as you say.
GXAlan
You should ask your piano teacher if different brand pianos have different sound characteristics. If your teacher appreciates that difference, then it is easy to explain that a good audio system preserves the characteristic of each piano sound signature.
Most of the difference is in the feel and mechanics, of course, but the sound difference is very important.
There is no shortage of piano gear debates, despite the fact that pianos are largely end game products that get passed onto future generations or sold for pennies. “Class D” pianos still haven’t gotten the quality of the pure analog units :)
Steinway
It is easy to hear Steinway but there is a whole NY vs. Hamburg opinion. I am willing to bet it’s the most commonly used brand out there by professional artists.
Bosendorfer
A Window in Time, Telarc
Rachmaninoff recorded himself on a player piano. After careful restoration you can hear Rachmaninoff play the piano through a Bosendorfer reproducing piano that read the piano rolls.
Bosendorfer is famous for being extra long for added bass.
Shigeru Kawai
Earl Wild at 88
Kawai is most famous for being the first to bring automation to the manufacture of pianos and ABS-Carbon instead of wood to the keys. While people were criticizing the lack of ivory or wood, Kawai did it for consistency. They design their pianos in an anechoic chamber to make sure the piano sounds the way they like and you can see them using ANSYS for finite element analysis in this video.
They are like Revel when it comes to speakers. Lots of engineering. Not as much marketing.
Yamaha CFX
Magdalena Stern-Baczewska, steaming only, Bach’s French Suites
or
Elton John
They are also a company that uses anechoic chambers in the development of their pianos. But Yamaha does a lot of work with “advanced physics modules for numerical analysis and advanced measurements” for digital development.
They have a lot of customized wood that is backed by data
And the CFX press releases talks about a lot of unique geometry and materials.
Also an engineering focused company.
Fazioli
Angela Hewitt’s Beethoven Piano Sonatas
They are famous for being wait lists and rarity. They are perhaps more similar to Dan Agostino of DeVore in that it is a family business with golden ears.
wwenze
I started listening to music after stopping playing the piano at age 14. RIP ABRSM grade 8. Never managed to play skillfully again, but then again maybe I never truly did.
Most of them can somewhat hear the difference between different models, but fail to explain why one should cost 10x of the other.
My violin teacher told me that the tiger-stripe wood pattern of my unit is good quality wood. When I grew up I learnt that it is laminate.
