Kali Audio IN-8v2 (Second Wave) 3-Way Studio Monitor Review
hardisj
Reviewer
North Alabama
Copy/paste from my site. Review may not translate from my site so here is the link to the full review on my site:
https://www.erinsaudiocorner.com/loudspeakers/kali_in-8v2/
  • Saturday, Jun 26, 2021
Note: Coming Soon
For a primer on what the data means, please watch my series of videos where I provide in-depth discussion and examples of how to read the graphics presented hereon.
https://youtube.com/playlist?list=PLnIxFR_ey0b37Ex4KV2mBz-kYB7QLffR1
Information and Photos
The Kali IN-8v2 is the second generation powered 3-way Studio Monitor featuring a 4-inch coaxial midrange/tweeter and an 8-inch midwoofer.
MSRP for the single speaker is approximately $399 USD and $800 USD for a pair.
The back features a bank of dip switches for boundary settings (discussed later) and basic level adjustments. There is a volume knob and (3) input options: XLR, TRS and RCA phono.
The reference plane in this test is at the tweeter. Volume set to ‘0’ with XLR input. The dip switches were all set to ‘0’ for the free field setting.
CTA-2034 / SPINORAMA:
Early Reflections Breakout:
Estimated In-Room Response:
Additional Measurements
On-Axis Response Linearity
“Globe” Plots
Vertical Polar (Globe) Plot:
Harmonic Distortion
Kali%20IN-8%202nd%20Wave%20%20--%20%20Harmonic%20Distortion%20%2886dB%20%40%201m%29.png
Kali%20IN-8%202nd%20Wave%20%20--%20%20Harmonic%20Distortion%20%2896dB%20%40%201m%29.png
  2. 86dB at 1 meter (red)
  3. 96dB at 1 meter (blue)
  4. 102dB at 1 meter (purple)
Based on my results above, it is obvious the output is limited (via internal DSP) somewhere above the 96dB @ 1m output level.
Long Term Compression Tests
Cumulative Spectral Decay (CSD)
Boundary Settings
I tested this with the IN-5 and am providing it again here. I expect some bit of change from this model but likely not much (and possibly, not at all).
These speakers come with a set of pre-configured boundary settings that can be enabled easily via the dip switches on the back. Below is a close shot of the dip switches.
The dip switch combinations displayed above are labeled and plotted in the graphic below.
Comparison Against the Kali IN-8v1
  • Blue = IN-8v1
  • Black = IN-8v2
On-Axis Response:
Parting / Random Thoughts
  • Subjective listening was primarily at 1.5 meters but varied from 1 to 3 meters. Subjective listening was conducted at 80-95dB at this distance. Higher volumes were done simply to test the output capability in case one wants to try to sit further away.
  • The front port means you have more ability to move these speakers in to the prime spot for your needs. And thanks to the dip switches you have more ability to place the speakers where you need; whether free standing, near a wall or on a console.
  • The on-axis response isn’t flat but that’s the nature of coincident drivers. You’ll need to be off-axis a bit. Kali recommends 10°. My data jives with this, though, I would also recommend trying them off-axis by about 20°. Your mileage may vary. Just do not make the mistake of EQ’ing the on-axis response as this only alters the character of the sound in a negative way.
  • There is zero mechanical noise from these speakers (pops, over-excursion, vent noise) even at higher volumes. However, these are intended to be used as nearfield monitors in the 1-2 meter range. Going past this will naturally mean you’ll need more volume and if you are listening at absurd levels, you will certainly run in to the built-in limiter throttling the output as I showed in my linearity test.
  • There were only a couple of instances where I felt improvement was needed. One example was namely in the 4-5kHz region where - with some music (Lido Shuffle by Boz Skaggs, for example - the sound may jump out at you a bit, having a bit of “bite”. Using my EQ, I padded this down about 2dB and it really made a noticeable improvement. I think 1-2dB cut at 4.5kHz with even a graphic equalizer would make this a more pleasing speaker to most. More than 2dB takes the “edge” off instruments which dulls the sound.
  • Another area that occasionally stood out to me was in the 100-200Hz where some lower vocals tended to sound a bit “hot”. It was a rare occurrence but noticeable, nonetheless. I took the speaker back out to the garage and measured it for CSD (provided previously). The CSD indicates a lingering resonance at roughly 160Hz. It is interesting to note there is a dip in the SPINORAMA data at this frequency but yet a peak in the dynamic compression test. Hmph.
  • The bass is really nice and extends down to 50Hz easily. There are no bass boosts or issues in the bass region that call attention to themselves. Just neutral response that digs relatively deep.
  • Hiss: Practically nonexistent. This is a very noticeable improvement over the IN-8v1.
  • As for SPL levels, these are marketed as a near/mid-field speaker. My data shows the limiter kicking in somewhere above 96dB @ 1m. I had the output up to about 100dB at 1 meter to stress test with some Linkin Park and there were no mechanical issues that I could hear. I’d say that you could probably use these in the midfield in the lower 90’s pretty well but above that would be pushing it. Realistically, you shouldn’t be mixing music (or listening) above the 85dB range for long periods anyway. I do not know that I would recommend these for high volume listening more than 3 meters but for most volume levels and/or closer distances, a pair of these should be more than enough to satisfy your needs.
These are excellent speakers on a whole, to my ears. They are, in my opinion, an excellent value at the MSRP of only $800/pair. It is a great mixing/monitoring speaker and would do well in home audio applications (but be mindful of the output as the linearity changes at high output levels thanks to the built-in limiter). Frankly, I don’t know how Kali is able to produce such a nice speaker for such a reasonable price. I have no problem recommending the Kali IN-8 Second Wave.
In case you are wondering, no, Kali did not send me these speakers to review. They came from a viewer.
Support / Contribute
If you like what you see here and want to help me keep it going, please consider donating via the PayPal Contribute button below. https://www.erinsaudiocorner.com/contribute/
Matias
São Paulo, Brazil
Looks like a great speaker and an excellent value. Congrats, Kali! And thanks, Erin.
McFly
NZ
Agreed. Exceptional value for a studio monitor. What the heck is that tweeter doin up at 10k on though? Having his own party, lucky its mostly likely inaudible.
Edit: Looks like a trait of the coaxial driver tweeter being in a little tunnel
More Dynamics Please
USA
Kali may market the IN-5 as a near-field monitor but they clearly state in the user's manual that the IN-8 is "ideal for near-to-mid-field applications":
The IN-5 and IN-8 are designed to have a continuous output of 85 dB at 2.2 and 3.5 meters, respectively, with 20 dB of dynamic headroom. This makes the IN-5 ideal for most near-field monitoring applications, and the IN-8 ideal for near-to-mid-field applications.
https://static1.squarespace.com/sta...-Most-Recent-Latest-Users-Manual-May-2021.pdf
@hardisj, it isn't entirely clear from your review if you agree with or dispute Kali's claim that the IN-8 can produce continuous output of 85 dB with 20 dB of dynamic headroom (for 105 dB peaks) at up to 3.5 meters.
hardisj
hardisj
Reviewer
North Alabama
Looks excellent! Thank you for your reviews @hardisj. Seems your'e a bit like me and sometimes review in batches?
Kind of. I think it's more that I just sit down and write up the results in batches. I reviewed some of these speakers last week. Just trying to get the data out now.
JonathanB
Thanks for your review.
From your analysis, these are very respectable results at this price range, and really not too much to complain about in every aspect.
Truly a value leader.
The 160Hz artifact is interesting, could be an artifact from the new electronics?
pierre
Switzerland
Pref score would be 5.3 (w/sub 7.2).
Since the speaker is pretty good, EQ is not that useful. With the generated following EQ, score will for up to 6.0. EQ is mostly trying to fix small oscillations (High Q, low gain) that are not very audible and may change from one speaker to another. So I would advise no EQ for this one.
Code:
EQ for Kali IN-8v2 computed from ErinsAudioCorner data
Preference Score 5.3 with EQ 6.0
Generated from http://github.com/pierreaubert/spinorama/generate_peqs.py v0.8
Dated: 2021-06-28-05:36:11
Preamp: -0.9 dB
Filter  1: ON PK Fc  5945 Hz Gain -2.71 dB Q 0.48
Filter  2: ON PK Fc  5670 Hz Gain +2.55 dB Q 8.92
Filter  3: ON PK Fc   505 Hz Gain -0.96 dB Q 3.00
Filter  4: ON PK Fc   944 Hz Gain +1.36 dB Q 9.36
Filter  5: ON PK Fc  1910 Hz Gain -1.02 dB Q 12.00
Filter  6: ON PK Fc 10762 Hz Gain +1.94 dB Q 12.00
Filter  7: ON PK Fc  9004 Hz Gain -0.68 dB Q 12.00
Filter  8: ON PK Fc  4804 Hz Gain -0.92 dB Q 12.00
Filter  9: ON PK Fc  1239 Hz Gain -0.92 dB Q 6.61
Filter 10: ON PK Fc  2597 Hz Gain +0.86 dB Q 3.53
Filter 11: ON PK Fc  7257 Hz Gain +0.67 dB Q 11.91
Filter 12: ON PK Fc  2096 Hz Gain -0.51 dB Q 12.00
Filter 13: ON PK Fc  1636 Hz Gain -0.33 dB Q 12.00
Filter 14: ON PK Fc   333 Hz Gain +0.45 dB Q 12.00
Filter 15: ON PK Fc  4289 Hz Gain +0.96 dB Q 12.00
Filter 16: ON PK Fc  6439 Hz Gain -0.33 dB Q 12.00
Filter 17: ON PK Fc  4633 Hz Gain -0.50 dB Q 12.00
Filter 18: ON PK Fc  1401 Hz Gain -0.26 dB Q 12.00
Filter 19: ON PK Fc  1169 Hz Gain -0.25 dB Q 12.00
Filter 20: ON PK Fc   417 Hz Gain -0.50 dB Q 12.00
Here are Erin's data + EQ:
Moonhead
Denmark
Much appreciated, thanks Erin.
So In8 has a slightly better pref score than In5?
sharock
How easy is it to overlay the estimated in-room graphs of this, the IN-5 and the 8030C?
pierre
Switzerland
daftcombo
Thanks a lot Erin! Two great reviews in a few hours.
This part is not good news:
hardisj
hardisj
Reviewer
North Alabama
Your welcome. FWIW, I actually posted (4) reviews. Bose Bluetooth speaker comparison, apple homepod mini, this one and the ELAC UBR62. :)
It really isn't bad. I mean, out of a 10-scale of noticeability, for me it's like a 3. Which means for pretty much the rest of the world it would be a -5. Because, I swear, I always seem to hear these lower frequency resonances and people say "I don't hear it". *shrug*
daftcombo
I sold my pair of 305p mkII after seing your review because, to me, there was a problem in the 100-200Hz area and you confirmed it.
So, I might be too sensible there too. And when you hear something, it is impossible to un-hear it.
Did you notice something similar with the IN-5?
hardisj
hardisj
Reviewer
North Alabama
I didn't hear it with the IN-5.
The funny thing about hearing the resonance in this speaker was it was the last song I was shuffling through and I turned around to the computer right when I heard it. I thought "what was that", and listened to it again at that point. Heard it again. Went through a few more tracks to listen on purpose and only a couple showed it. I mean, it was really barely noticeable. But when I plotted the CSD I could see what I was hearing. I didn't try to EQ it... maybe you can. I would be surprised if more than 90% of listeners ever heard it. But like you said, once you do, it's impossible to ignore. Luckily it happens rarely. Nowhere near as bad as the JBL 305P mk2 did, so I can still recommend it. And I would still own the speaker if it were in my wheelhouse/need.
Honken
Scania
Thanks for the review, this might be what finally pushes me purchase them. I've been eyeing them and the UBR62 for a while now - if only to test what coaxial speakers would sound like in my room and well, of the two this looks more attractive performance wise.
It's unfortunate that that they can't play louder, but perhaps when crossed to a sub the limited tweeter output isn't much of an issue in practice?
