Phenomenal Sound.Little sample, interesting comments
Then you must already be listening through a phenomenal system, or how could you tell?Phenomenal Sound.
That's a valid reason for asking. Not many others left.Friend was curious and wanted to know.
Im listening with my HD800S And i can certainly tell when i hear system that is great.Then you must already be listening through a phenomenal system, or how could you tell?
Even through the YouTube lossy compression? Really? Perhaps Amir should review that way.Im listening with my HD800S And i can certainly tell when i hear system that is great.
From youtube demos this LS60 is more impressive to me than Even Reference line up.
Clarity, cohesion, imaging, depth and bass sounds so good.
I expect Reference line up to take over this at loud wolumes.
I dont understand your comment? demos dont exist if you cant hear a difference...Even through the YouTube lossy compression? Really? Perhaps Amir should review that way.
Demos exist to generate trade and income. I have myself listened to online demos and decided that a system sounded so much better than mine, until I reminded myself that what I was listening to WAS my system.I dont understand your comment? demos dont exist if you cant hear a difference...
You can believe what you want to believe i just expressed my impressions.
Try harder! You didn't do it properly. You held back.We did and it didn't happen. Oh well...
Those LSX look like what my old Creative PC speakers from the 90`s wanted to be when they grow up.Ah… lsx ii ! If they are as good as the ls50w2 I’ll consider one for desktop use.
You're asking for a scientific paper explaining my (rather mainstream science) statement and then base your point on some other manufacturer's white paper? Let me start with pointing to KEF's LS60 WP then: https://assets.kef.com/product-support/ls60-wireless/LS60W_Whitepaper.pdfI dont agree, theres gonna be losses without any baffle and the diffraction problem will be terrible at the edges around the drivers. Im sceptic.
Can you link to any scientific paper that explain your statement ?
I have one that shows very clearly the dissadvantages of narrow baffles. From GRIMM audio.
Read more here:
Hi Harkpabst,You're asking for a scientific paper explaining my (rather mainstream science) statement and then base your point on some other manufacturer's white paper? Let me start with pointing to KEF's LS60 WPs then: https://assets.kef.com/product-support/ls60-wireless/LS60W_Whitepaper.pdf
Figure 3 on page 4 shows a simulation of on-axis response of a 4" driver in cubes of different sizes. Note how the undesirable effects diminish with smaller cabinet sizes.
The "baffle step" or "diffraction loss" is actually the lesser problem. It's relatively easy to compensate for, in particular with an active design. The ripple (usually) introduced by sharp edges and its associated effects on the polar response is the true enemy. One solution to this are generously rounded edges as found in the LS1 (or e.g. Blades or LS50), but it's not the only way. Both effects are caused by the same physical phenomenon (the way sound waves propagate around obstacles) but it makes sense to differentiate between the two. Take e.g. a fully spherical enclosure with a "small" driver mounted to it. No sharp edges at all, no ripple, but still it exhibits the ~6 dB baffle step. This is not the place to go too much into all the details but my scientific reference for these issues is the late Siegfried Linkwitz. Does it get much more scientific?
Bruno Putzeys surely is one of the most respected developers in the audio industry and nobody will contradict his ideas lightheartedly. In fact, I don't. I explicitly don't even dispute that very well sounding speakers can be build using wide baffles. It's just not the most common way to do it and not so because all others are just clueless idiots. As always it's a matter of compromises and each solution brings its own drawbacks and technical problems. Again, I confess that small baffles impose their own problems but that doesn't mean that wider baffles don't nor that they are the one and only solution. Bruno Putzeys seems to agree on this. Otherwise his work for Kii Audio would not have resulted in a narrow baffle speaker (with a lot of extra trickery, I know): https://www.kiiaudio.com/kii_three.php
Very narrow baffles are not only chosen for looks and KEF took this approach to a new level with LS60 Wireless, at least as far as their own portfolio is concerned. The Uni-Q driver and Single Apparent Source configuration are helpful here. Finally I want to point out that KEF has not officially published detailed information about the crossover frequencies, yet. So far we all came to think that the lower crossover point is probably around 390 Hz because this frequency is mentioned as a side note in one sentence in the LS60 Wireless white paper. They have not revealed filter slopes and characteristics of the HF crossover point.
Thanks for clarification, @AOR. I like what I hear (or rather read). That MF/HF crossover point says something about the qualities of the new 4" Uni-Q. The normalized dispersion plots and DI plots don't give the slightest hint towards the crossover point, impressive. And without having heard those speakers yet I'm totally sure those tweeters won't show any dynamic compression. Nice!The MF/HF crossover frequency is around 3.1kHz.
All drivers have 4th order electrical filters applied, except the HPF on the MF, which is 3rd order. The different order on the mid is due to the acoustical response beginning to roll off near crossover. This means that it behaves (a little) like a 1st order filter. The addition of the 3rd order electrical filter to the 1st order acoustic filter results in a 4th order response that matches the LF (at least, over the crossover band).
I don't think so. Same reasoning as here: https://www.audiosciencereview.com/...ess-just-announced.33705/page-40#post-1186376Thanks for posting the video filmed in Barcelona. Turns out that Francisco del Pozo, a wannabe Darko was there. It´s always good to see what the enemies are doing...
That video led me to think, if the LSX are next, will it be safe to assume the new version will share the uniq array with the LS60? Just in video they look very similar.
So the LSX is closer to an LS50 array, but in a smaller size.I don't think so. Same reasoning as here: https://www.audiosciencereview.com/...ess-just-announced.33705/page-40#post-1186376
LSX needs a real mid-woofer. I doubt the decoupled magnet would make sense when the driver is operated down below its resonance frequency. Different requirements for the surround as well. Even if the LS60 Wireless Uni-Q midrange has been designed with increased excursion this will hardly suffice for that matter.
Speaking with the accumulated authority of a person not associated with KEF or GP in any way: Yes.So the LSX is closer to an LS50 array, but in a smaller size.
Youtube audio cannot possibly ever be an audio reference. Nor can it help you hear differences between resolving gear.I dont understand your comment? demos dont exist if you cant hear a difference...
Having done the design work on this, putting it in everything as it's refreshed is a no-brainer.It will be interesting to see if the Metamaterial Absorption Technology still makes it into LSX II. Unless this has already been answered somewhere (so any guessing would be pointless) my personal guess would be: Absolutely.
