KEF R11 Meta Tower Speaker Review
Rate this speaker:
    Votes: 5 1.1%
    Votes: 5 1.1%
    Votes: 82 18.2%
    Votes: 359 79.6%
exm
Made in Great Britain or just assembled ?
Do you think Kef has two manufacturing lines of the same HP (I'm talking about components) ? One in Europe, the other in China?
Furthermore, Kef has been owned since 1992 by a multinational based in Hong Kong which also owns Celestion and is listed on the stock exchange.
As far as I know, everything Reference is hand-made in the UK. The cabinets are sourced locally for sure. Are the drivers and crossovers also made in the UK? I believe so, not 100% sure.
exm
My current speaker is the R900 (with EQ 41 Hz -10db).
I have always found it a bit slow, lacking slam, and with a kinda "plastic" treble.
Wondering if this R11 meta is significantly better...
No. I feel that the R900 is a superior speakers (my 2 cents). If you want to upgrade, get a used pair of Reference 5s...
Vacceo
We may have to wait for the R110 meta... :p
I have the feeling that jumping from my current IQ series to R Meta can be night and day, but since I have to upgrade my electronics first, that could be a way to get an even further change in the future.
thewas
I am "afraid" it can be really a huge step, but why do you have to upgrade your electronics first? That expensive loudspeakers always need expensive electronics is a myth, measurements show that there are a lot of cheap electronics which are audibly transparent.
Vacceo
Because with my current AVR, I´d need more wattage to run 4 ohm speakers. On the other hand, the AVR can run 9 speakers and I want to run 11. Dirac is another interesting element I want added.
EDIT: @thewas , I also think that I can squeeze my current speakers further with Dirac. With that done, I can adress shortcomings with speakers. I get a good sound with Audyssey, but I think I can do better than a 2016 AVR in that department.
lordhumungous
There's a guy over on the Roon forum that says this speaker sounds "dull" and "muffled".
That would be the first Kef speaker ive ever heard being described as such. This is why you can't trust your ears.
welwynnick
The thing Kef seems to consistently underdo subjectively for me is the bass. They allow for to much room gain on their upper echelon speakers for my taste, and so end up sounding a bit wimpy and thin, while their older Ref series (threes and fours) were a bit the contrary..Correcting and extending my KEF Ref 205 using h RME ADI 2 DAC adaptative loudness and Focus Fidelity generated FIR filters in Roon, made them sound so much better it is really an eye opener.I use a modified Harman style curve, with 4 to 5 db bass boost instead of the original 6db, and 1 to 1,5 db less downward high freq tilt past 1Khz. Kef s quality,low distortion, low compression drivers, especially in multy way models, take this Equing with no problem.
Several people commented about this, and I see the reasoning behind the objection.
However, looking at the Revel floorstanders that Amir tested - F208, 228, 328 etc - they all show the same bass shelving / tapering, and I don't hear many complaints about them.
bodhi
This is why we have measurements. People's taste in low end reproduction varies so much that I pay no attention to random comments about whether some speaker is bass heavy or light if I don't know for sure that the person is talking about compared to flat(tish) FR or there isn't some kind of measurements attached.
kelesh
That's why I think the value proposition on the R11 isn't great unless you can get them on a really good sale.
These or Buchardt A700 for the same money? A700 all day. And there are other end game speakers I would want to cross-shop as well. Revel is a toss up; the F228Be is too expensive. The F226Be is right there but the bass output is lacking. Then there are value kings like Ascend and Philharmonic Audio to consider.
Different animals, though. A700 are active. You have to run line-level from the source, rather than speaker cable, not to mention power, as well as fiddle with controls on the back of the speakers. I personally dislike this. And they are ugly, in a "modern furniture" way. YMMV
Chromatischism
Perceived frequency response is relative to what you've heard. The user likely spent many years with boom-tiss speakers and needs to give these more time. I've never been a KEF fanboy but I think these look great, just too expensive.
Chromatischism
While looks are subjective, you're getting more for your money, at least.
beagleman
Pittsburgh Pa
Ehh, not so sure.
The thing about AVRs being way too weak to play 4 ohm speakers is partially true, but not completely.
I have run SEVERAL 4 ohm speakers, albeit in mostly 2 channel mode or 2.1 and there was ZERO issue, as long as one was within the limits of its actual power.
A dedicated Power amp for sure "MIGHT" give you more headroom and so on, but its for sure not some Night and day difference or huge change. Its more a subtle change and when I did that 95% of the time, I could not even tell the difference
Now running all 9 channels full volume...for sure more of a weakness....
Vacceo
Ehh, not so sure.
I currently run all seven channels and they work on the IQ's at moderate volumen. With the R's, I'd not count on it.
ban25
FWIW, I currently run two R11s, an R2C, a pair of R3s, and four Ci200RR-THX in-ceilings all on an AVR. No problems whatsoever at reference volumes (0 dB) in Atmos movies or listening to music upmixed in AURO3D.
ROOSKIE
Minneapolis
'Proper' Bass levels will likely be
A. Very subjective
B. objectively different at different playback levels.
C. influenced by the room size
So...
A= dealers choice
B= The louder you listen the lower the bass could be tuned to have the same subjective balance with the rest of the spectrum.
Testing has shown it takes about 10db in the midrange to to sound twice as loud
Yet it take s 5-6db in the bass to sound twice as loud.(and the minimum threshold for audibility is very high in the very low bass)
Therefore the perception of neutral or pleasing bass levels is fully intertwined with the actual playback levels.
C= perception of 'correct' bass SPL relative to the rest of the band has been shown to be different in larger vs smaller rooms.
AudioJester
Yes they are consistent.
Erin ran the R5meta on his klippel. Go have a look at his site. 'Erin's Audio Corner'. He also did a YouTube review of that speaker.
I don't see any reason to buy the R11 if you have subs. Or even the the R7. With subs and the right crossover blending the R5 or even the R3 will handle most situations.
The R11 is for the look of a tall tower and maybe for someone who doesn't want any subwoofers.
I think a lot of that 'huge' tower sense of scale is sighted biases. Subs and medium sized mains would be my general choice vs huge towers and both options sound 'huge'.
Not sure about this. If you have subs, you still buy the best performing speaker you can afford. The R11 measures better than any of the others mentioned. Now the advantage being that for many situations you may not even need subs.
Value for money? In the Kef range, by your argument the original LS50 is enough. Or cheaper Ascend, BMR, Arendal.....
beagleman
Pittsburgh Pa
I have listened to many large speakers, where owners claimed they did not "Need" a sub, but in literally almost every case, I found their definition on "Not needing" one, to not be the same as mine.
My 2 relatively mid priced Velodyne CT-120s, from many years ago, STILL had noticeably better Deep bass in the 26 or so to 35 Hertz range.
Even most bigger speakers, with a few exceptions, rarely do well below about 35Hz, in my experiences.
Some DO below 35, but it is either not at the same level as higher bass, due to roll off or placement, or distortion is not equal to my 2 subs, and in a noticeable way.
radix
I have Revel F228be. For a few years, I did not have room in the living room for a sub. It was kind of an open floorplan. Anyway, sound was good. Then I moved to a new house and got an Arendel 1723 S1. It makes a tremendous difference. A 14" driver can move air in ways even dual 8" cannot. It's almost 1.5x the surface area. And, the sub needs to be in a different spot than the speakers to avoid bad room modes. No way I could EQ the room mode away from the speakers.
I have some L100 re-issues in a different room without sub. They sound just fine, it's obvious (in non-level matched test) that the f228be w/ sub is just a completely different experience. Yes, it's different amps, different rooms, different volumes, but the F228+sub goes down below 10 Hz with authority. The L100s die out around 35 Hz. And yes, I do listen to some music with < 40 Hz content. Though probably the 100-200 Hz modes I cannot fix without a sub on the L100s that come across the most.
AudioJester
Ah, need for subs varies, we will all have anecdotes. There are threads full of the same back and forth.
If you look at in room measurements and bass levels, most people fall into the untrained listener category and need subs for extra/exagurated bass
Mnyb
Sweden, Västerås
You mostly need the sub for bass quality and headroom and reduce the work the mains have to do.
One might also spend some bass headroom to EQ the room .
And if you managed to the flatten the room bass will sound subjectively lean to most listeners so it might need a little kick up :) especially if you don’t usually listen at reference levels , so one might end up with some “loudness” compensation baked into the system.
IMO bass varies widely with the production of the music to ! So you will end up at one end of the circle of confusion?
Seems like bass reproduction been a problem for studio control rooms too ? And if it’s very popular song it may be very bass reduced and lack slam due to “production values” ?
So tone controls and or several different presets of your EQ can help you ?
