KEF Reference 4C Review (Center Speaker)
Rate this speaker:
    Votes: 5 1.4%
    Votes: 6 1.7%
    Votes: 78 22.6%
    Votes: 256 74.2%
This is a review and detailed measurements of the KEF Reference 4C Center home theater speaker. It was kindly purchased new by a member and drop shipped to me. 4C costs US $7,500.
Apology for using stock picture. Speaker weighs 100 pounds and I got interrupted mid-review with our home flooding so still in measurement room. I had finished the measurements though and hence this write up. You can't tell from above picture but this speaker is deep, very deep. The finish is gorgeous but I found a tiny blemish which was disappointing. Back bindings are custom tool metal ones and the best I have seen and felt. No question KEF has targeted high level of execution with this speaker.
A coaxial driver handles midrange and tweeter responsibility. Woofers then bring the bass along (3-way total).
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was the center of the tweeter (aligned by eye). Measurement room was at 10 degrees C which may lower bass output a bit. I used a higher resolution scan than normal which turned out to not be necessary as the speaker is very well behaved in higher frequencies. Accuracy is better than 1% as a result in most of the frequency spectrum.
KEF 4C Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
While not ruler flan, on-axis response is very good. Even better is directivity index (dashed blue at the bottom) showing that important early reflections are similar to on-axis response which you can see better here:
KEF REFERENCE 4C Measurement Early Window Frequency Response Centre Channel Speaker.png
Bass response is stepped down due to port tuning being low. We can see this in the near-field response:
KEF REFERENCE 4C Measurement Driver near-field Frequency Response Centre Channel Speaker.png
Cabinet/port resonances are kept at bay so don't cause coloration in upper midrange as they usually do in ported speakers.
Predicted in-room response is excellent:
KEF REFERENCE 4C Measurement Predicted in-room Frequency Response Centre Channel Speaker.png
BTW, sensitivity is also excellent at 90 dB although you better have an amplifier that doesn't mind the very low impedance dip of just 2.9 ohm:
KEF REFERENCE 4C Measurement IMpedance and phase Response Centre Channel Speaker.png
The quad bass drivers and capable mid-range translate into incredibly low distortion and power capability:
KEF REFERENCE 4C Measurement Relative THD Distortion Centre Channel Speaker.png
The biggest issue with the design of most center speakers is that the doubled up woofer/mid-woofer causes horizontal dispersion to narrow due to timing differential between them. Is that solved here with the coaxial mid-range/mid-woofer? Let's see:
KEF REFERENCE 4C Measurement Horizontal Beam width Response Centre Channel Speaker.png
KEF REFERENCE 4C Measurement Horizontal Directivity Response Centre Channel Speaker.png
Speaker is so wide that there is still good bit of distance between the woofers causing some cancellation. But generally, this is way better than most center speakers we have tested.
The vertical response though shows how good this could be if all the drivers were aligned horizontally:
KEF REFERENCE 4C Measurement Vertical Directivity Response Centre Channel Speaker.png
For fan of timing analysis, here are the rest of the measurements of that type:
Listening Tests
I was in the process of wiring up the speaker to listen to it in the measurement lab when my worried wife ran into the room and said: "downstairs bathroom is flooding!" I rushed out to deal with that and have not had a chance to listen to the 4C yet. I hope to still get a chance to do so and report back.
The fit and finish, design and capabilities of the 4C clearly show that this is a very serious engineering effort by KEF to produce a highly capable center speaker. Physics of sound wavelengths still attack it a bit causing slight narrowing of directivity but otherwise, it is very hard to find fault with this speaker.
I am going to recommend the KEF 4C based on objective data and subjective look and feel of the unit. I expect it to be a super capable center speaker and a great one for 2-channel listening if you use it vertically.
  • KEF Reference 4C Frequency Response ASR.zip
enricoclaudio
Houston, TX - USA
WOW…Price aside, looks like we got a very excellent rival for the Revel C426Be. Thanks @amirm for another great review!!
JD_Spoon
DFW, TX area
Hi, I'm the donor of this particular speaker, thanks to @amirm for doing all the heavy lifting, figuratively and literally. :) Regarding the speaker's cost, it's the same price for the Reference 4c trio as it would be for a Revel PerformaBe F328Be and C426Be trio, and significantly less if you can take advantage of the promotional deal KEF USA has had going on for a couple of months now. Not even going to pretend it's an inexpensive acquisition even at that level, but if you have the means, they're still out there as of this writing.
wavesharp
I have also one KEF Reference 4C. Now I believe I selected one nice center speaker
respice finem
You're unstoppable :cool: thanks.
Very heavy and even more expensive, but a fine big center speaker, if you need one.
For a smaller room, you might IMHO be better off with a compact coax from KEF, like
for 10% of the price.
alex-z
Honey I shrunk the distortion...
Less than .5% THD from 150-4500Hz even at 96dB. I would call this the perfect centre channel if they moved the port tuning up maybe 10Hz.
JD_Spoon
DFW, TX area
FeddyLost
It would be interesting to dampen enclosure better and check CSD and subjective impressions again.
With such low distortion from drivers, only non-suppressed resonances might affect SQ.
Maiky76
French, living in China
KEF 4C Measurements
Listening Tests
Hi,
Score No EQ: 5.9/ 7.3
Not sure if it is relevant...
Score With EQ: 6.7/ 8.1
No EQ Spinorama
EQ Spinorama
Radar
  • KEF R4C APO EQ Score 96000Hz.txt
