- Joined
- Nov 3, 2020
- Messages
- 625
- Likes
- 1,046
A negative score?! Yikes!Preference Rating
SCORE: -0.7
SCORE w/ sub: 3.5
SCORE: -0.7
SCORE w/ sub: 3.5
Measured wide horizontal directivity support 2.5-way claim, single crossover frequency more likely is a marketing blunder.That could also be marketing misinterpreting what "2.5 way" means.
Like two-way, half-way usableThat could also be marketing misinterpreting what "2.5 way" means.
Typical user positions are vertically above center channel loudspeaker and in a wide horizontal arc, so both horizontal and vertical measurements are necessary.I wonder how much sense it makes to meassure the FR/horizontal while vertical on axis, since the user will be always verticly above it
Well, no, a 2.5-way design has only one crossover frequency, otherwise it would be 3-way. Rather it's one crossover, and one low-pass-filter.That could also be marketing misinterpreting what "2.5 way" means.
Well, that might be semantic, but if we define the crossover as a circuitry which splits input signal in two or more frequency ranges, than 2.5-way crossover splits input signal in three frequency ranges.Well, no, a 2.5-way design has only one crossover frequency, otherwise it would be 3-way. Rather it's one crossover, and one low-pass-filter.
I concur the freestanding measurement is inappropriate for wall-mounted speakers, but when speaker is mounted on-wall it is easy to calculate horizontal and vertical angle to the listener, so horizontal and vertical measurements show all you need to know about the mid-high frequency response at the listener point.Given that they are intended for wall mounting, an on-axis freestanding measurement is inappropriate in two-ways. All 5 speakers when mounted flat on the wall would be "horizontally" off-axis to the listener (the L+R even more than the centre), and be getting wall bass reinforcement.
So I'm not surprised to see them having anechoic on-axis high treble to offset both of those factors. And the "Selecta-mount" stand reduces the treble.
Amir likes standardized tests for all speakers, that can be debated but in what you ask finding one correct height above that represent listener position is a bit arbitrary. It is measured at all position, this give the general behavior on all axis, I know you'd like a 2D graph with numbers, but:you didn't understand. the horizontal should be meassured while veriticly off axis (above)
You can find frequency response at any point in 3D space, combining both measured graphs - horizontal and vertical.you didn't understand. the horizontal should be meassured while veriticly off axis (above)
