Kingston HyperX Cloud II - Low Volume and Impedance
Audiofire
Denmark
Headset:
> Nominal impedance: 60 Ω per system
> Nominal SPL: 98±3dB
> T.H.D.: < 2%
> Power handling capacity: 150mW
Distortion looks good on rtings.com, much lower than 2%. Volume and EQ are the same when using 3.5 mm or USB connection of the USB control box. I believe the average impedance from a computer is around 30 ohms, which doesn't seem low enough for these headphones. They were tested on a laptop that has a rather average sound card. That was 50 mV max. Then tested on a gaming motherboard that has 200 mV max and it was only just adequate to reach around 94 dB. Used the scope in REW. EQ was configured in Equalizer APO to the target response here (The sound is indeed wrong without these EQ settings):
There was a new audio control box called HyperX Amp USB Sound Card, but that one is not available. It supposedly adds some volume:
What happens if a PCI sound card is installed in a desktop computer and the headset is plugged in with USB, will it use the motherboard sound card or PCI? Is there some external amp that the 3.5 mm cable with three stripes can be plugged into, that would be better than looking for a motherboard with 200 mV? The three stripes are for stereo input and mic output, so would an adapter that splits the connector into separate stereo and mic connectors be best (for an external DAC and ADC)?
Audiofire
Audiofire
Denmark
USB bypasses the computer's sound card functions.
Something like the iBasso DC-05 USB DAC/amp is a good low cost unit.
In that case, it is best to look for an external DAC and ADC. I perceived the volume as the same with USB and the 3.5 mm cable, which somehow suggests a correlation with the internal sound card, but I don't know how it works. Internal sound cards often have limited output voltage, high output impedance and low sound quality. Something like I found in the attached picture seems perfect.
twsecrest
California
You can get a TRRS (f) to dual TRS (m) adapter to split the headphone and mic jack.
Like in like in your last post.
DVDdoug
Gain (related to current volume) isn't necessarily the related to the maximum volume you can get without distortion. You can have a low-power amplifier with high gain.
But there also could be no difference...
twsecrest
California
If you need headphone surround sound, for FPS gaming, a used Sound Blaster Z sound card would do the job.
It's headphone jack has a 22-Ohm output impedance, it would just make 60-Ohm headphones slightly more bassy.
Audiofire
Audiofire
Denmark
I didn't know it was called TRRS. I've had the headphones for around 5 years, but don't plan to keep them. This thread is sort of a review, so that a future owner knows what to expect. A manufacturing date is inside on the magnets. The ear cushions can just be removed along the edge, and there are some screws underneath.
I found this one that has 2.1 ohm output impedance:
twsecrest
California
Sound BlasterX G6, even better than the SB-Z.
