KRK ROKIT 5 Gen 4 Review (Studio Monitor)
This is a review and detailed measurements of the KRK ROKIT 5 Gen 4 active studio monitor (speaker). It was kindly purchased new by a member and drop shipped to me. It costs US $176 each from Amazon including Prime shipping.
I think these yellow drivers look cute :):
Nice to see the cabinet sides curved to reduce diffraction. A small waveguide is provided another tweeter:
Given the small woofer, it is probably sufficient.
You can't see it here since the unit is not powered up but despite being a cheap black and white LCD, I was surprised at its usability (JBL, are you listening?):
There is an App that lets you pair with it and apply equalization. I did not test that. On that note, all measurements and listening tests were performed at factory setting.
I performed over 1000 measurement which resulted in error rate of around 1%.
Measurement temperature was 63 degrees. Left the heater on overnight by accident. Probably cost me $5 in heating bill!
Reference axis was center of the tweeter.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
KRK ROKIT 5 Gen 4 Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
KRK RP5 Rokit G4 Measurements Spinorama CEA-2034 Frequency Response Studio Monitor.png
The on-axis may look a bit messy to the eye but really, if you zoom out a bit, it is more or less flat. We do have a port interference around 680 Hz which is common with front ports:
Back to spin graph, directivity is good. Tweeter has some ups and downs as we also see in the drive response.
Early window shows a drop in mid-range but also a droop in highs which is not bad a thing:
KRK RP5 Rokit G4 Measurements Spinorama CEA-2034 Early Window Frequency Response Studio Monitor.png
As noted, floor (and ceiling) reflection are the issue here so put some absorber there or keep that path length long.
Predicted in-room response in far field shows what we already know:
KRK RP5 Rokit G4 Measurements Spinorama CEA-2034 Predicted In-room Frequency Response Studio M...png
Beamwidth is surprisingly good:
This small woofer is mating well with that wave-guided tweeter. The sharp narrowing toward the end is probably not a bad thing to take away extra sharpness.
We see the same in our contour plot:
Vertical response is typical of these two-way speakers so stay at or slightly above tweeter axis to avoid the holes at 2 to 3 kHz:
Waterfall shows some resonances:
We see the prominent one around 680 Hz which we observed in spin graph just as well.
Distortion is quite good actually at 86 dBSPL, and horrible at 96, the latter of which I could hear during testing:
I am going to show the 96 dB graph in absolute form as I always do. Question: should I switch to using 86 dB in the future for smaller speakers? It will make it harder to then compare all speakers together.
KRK ROKIT 5 Gen 4 Speaker Listening Tests and EQ
I only needed 10 seconds of listening to my standard first reference track to know the sound was right. Very nice tonality which continued to deliver just the same through the rest of my tracks. I took a shot at correcting the resonance at 680 Hz:
I thought the effect was positive. Paradoxically, the sound became a bit warmer. Given the high "Q" of the correction, I don't trust my ears fully to be correct in this regard so do your own testing.
Once there, I could not stop listening to the ROKIT 5! I played track after track while preparing this review.
Pushing the volume up caused the woofer to gradually get distorted. Distortion level would then scale with volume which I prefer to speakers that play and all of a sudden break up badly. Despite only testing one speaker, I could get reasonable loudness so a pair should be very much sufficient in workstation/desktop environment.
There is almost no hiss coming out of the tweeter! I could barely hear it at 1 inch. Past that my PC noise would dwarf it. I expect noise to be a non-issue.
Conclusion
I don't know why but I went into this review thinking this speaker would not do well. But it did, both objectively (if you zoom out a bit) and subjectively. Despite its budget price, it delivers.
Overall, I am happy to recommend the KRK ROKIT 5 Gen 4 monitor. If it could handle more power and was a bit cleaner, I would rate it even a step higher!
Edit: Video review posted to youtube:
  • KRK ROKIT 5 Gen 4.zip
dfuller
That's not too bad... And 86dB/1m is quite a bit louder than I'd expect a 5" speaker to get and sound good at $300 a pair, and especially not with 55 watts of amp in the whole thing!
spacevector
Bayrea
Going forward, can you change this relative scale graph to only include these three traces: Fundamental (at 96dB), THD 86dB, THD 96dB? The harmonic information is readily seen in individual graphs already. Such graph will keep comparison with old graphs possible and allow fairness to small speakers at same time.
Unfortunately it does not look like that app nor the speaker control mentions q-factor anywhere.
Yeh, I saw them calling it graphic equalizer so not as useful.
You mean something like this?
jam
Montreal
Pretty good overall considering the performance, the features and the relatively low cost. It would make a good pair of desktop speakers for a computer.
phoenixsong
Conclusion
Yess table bounce is a thing! I always wondered how the effects differ from floor bounce though
Vovgan
Moscow, Russia
I think no, it’s good to keep the main limitation of the small speakers in plain sight. People should see it before they buy it.
Looking forward to seeing more of larger speaker reviews! Thanks.
YSC
this looked great for such a budget monitor with small footprint, looks close to the Adam T5V ballpark.
Only "issue" to me seems to be the resonance and the HF dip at around 10khz, both have a difference of ~5db from depression to peak with low Q, would this make them more audible?
Grotti
I think small monitors are commonly used in the range of about 86 dB. And since most of the people in Western Europe live in flats with direct neighbors, playing levels about 96 dB too often will result in starting a war.
If someone wants to play music at high levels: get bigger speakers with bigger woofers, which can handle bass levels at 96 dB or higher. But even then I would like to see the behavior of the speaker at a "common" level of about 86 dB.
HiFidFan
U.S.A
Great review Amir
These look like great desktop speakers
Robbo99999
@amirm , you say "should I switch to using 86 dB in the future for smaller speakers? It will make it harder to then compare all speakers together."
If most people are gonna be using small speakers below 86dB then I think it makes sense to change to 86dB for that large graph. As for comparing to other speakers perhaps you can include a small thumbnail pic that is expandable when you click on it of the 96dB graph so that folks can always use that one to compare speakers if they want.
Seems like this speaker is pretty good value, given it's pretty good performance. When I was looking at the spinorama I didn't like some of the sharp peaks and dips, but you can't always have perfection for a low price (well you could get JBL 308p which has excellent spinorama, but higher distortion in Amir's tested unit). I like the EQ option on the back of the speaker, that's quite intriguing and a good value addition, would be interesting to know more about that in terms of number of PEQ filters available, etc. Directivity was quoted as being good, but I thought I saw a lot of places on the spinorama where the gap between early reflections and on-axis was widening & narrowing repeatedly, so I thought that was the opposite of good directivity. I thought good directivity was when early reflections mirrored the on-axis and there was no "concertina effect" of the gap between the two widening & narrowing repeatedly.
sharpty
Queen City
Looks like KRK went with class D this time, and they got it right! I was expecting it to be class A/B like previous gens, considering the apparent lack of hiss. Would be interesting to see some board shots :)
restorer-john
