Level Up after Aune S6 - Suggestions
donpablo
village
Hello
Since 2 years I have been using Aune S6. My current setups are:
Aune S6 -> Stax SRM-252s -> RR1 Conquest and Stax L300 (modded)
Aune S6 -> XLR cables -> Little Dot MK3 SE -> XLR cable -> Hifiman HE-560 and Magister Kennerton
I am pretty happy from first setup and plan to invest in some closed back planars to fullfill my make my collection complete. However first setup is most important for me.
I am very curious how much money I have to spend to feel a real, audible step up from Aune S6 DAC(?)
What I am looking for is:
- great soundstage
- great separation, holography
- good bass control
- lush amphitheatric sound
- line out controlled with knob (I noticed that different % values of line out from Aune S6 are giving different sound results in Stax SRM-252s, probably because of that different amplification level of this amp has a bit different sound signature - I dont know if other electrostatic amps behave same way but I have to assume that).
- XLR outs
- XLR headphone IN (optional)
I know that DAC itself is not responsible for all of the above, but it gives a base to the amplificated signal, and if it is possible I would like to improve this base with better one.
Thank you in advance. (Prefferably I would not like to spend more than $1000, however if a 'level up' is not possible below that price than I will consider ;))
Julf
Amsterdam, The Netherlands
- great soundstage
- good bass control
None of those are really determined by your DAC, but rather your source material, speakers and room / listening position (or headphones, fit and ear shape).
Krunok
Zg, Cro
Most probably your Aune S6 is absolutely transparent to your ears so you won't hear any difference if you swap it for another transparent DAC. If you want to improve SQ use EQ and/or buy yourself better headphones.
donpablo
donpablo
village
@Krunok I suppose it will be hard to buy better headphones (I mean the open-backs one) than I have now for similar price they cost, even twice of that, so maybe what I should to do is to invest in better electrostatic amp? But this is quite expensive thing ;)
@Julf @Krunok Btw. so why people are so amazed of sonic experience describing Matrix X-Sabre Pro? They overpaid?
Krunok
Zg, Cro
Frankly, I think Little Dot is the weakest part of your chain.
donpablo
donpablo
village
@Krunok Little Dot is not the part of my electrostatic chain (this one I listen most of the time now).
donpablo
donpablo
village
@Krunok I have one of cheapest Stax amp, but level up 353X or 353s its about $800-1000 thing ;) and I cant listen to it anywhere here before purchase.
Krunok
Zg, Cro
I don't know. My guess would be that some folks are impressed with measurements and simply won't to have state of the art technology as they can afford it, and there's nothing wrong in that.
The truth is however you will easilly find sub $300 DAC that would sound equally transparent as Sabre Pro.
donpablo
donpablo
village
@Krunok Aune S6 has AKM 4495 and Matrix or Sabaj have ES9038Pro chip.
So there are no audible sonic differences between those 2 and their implementations in well made DAC?
donpablo
donpablo
village
@daftcombo This actually might be true! :D I had just hope that there are better DACs than Aune S6 - you guys here are saying that no.
What about cables? Inerconnects, USB cable or tools like Audioquest JitterBug? Do they introduce any differences in sound in your opinion?
Krunok
Zg, Cro
OMG, that's a big NO for all 3 of them.
daftcombo
They might introduce differences in the form of crap sound. Search for totaldac GIGAFILTER for instance.
