Unless your simulator can simulate the effect of PCB layout then it may not be telling you much about what the noise level is.
Good morning and thank you for your kind and valuable response
obviously, as you rightly say, the design and construction of an audio device is a very complex operation
I absolutely don't have the skills needed to do something from scratch
so what do I do? what other incompetent people do I try to copy others
I'm really obsessed with pre-amps which I consider the command center of an entire system
if I had to splurge for an element of an audio chain I would do it for an excellent line preamp
Having said this and speaking of projects, I really like the minimalist approach and that is extracting the maximum in terms of performance from very simple circuits.
I started by downloading service manuals from top preamps from the 70s which they say sound good
Their circuits, being commercial products, have a fundamental quality. They work more or less well but they absolutely work
Usually the line stage is made up of three blocks, initial stage - tone controls - output stage usually called often flat amp (usually a buffer with little of no gain)
In short, it's about taking the flat amp, putting a potentiometer in front of it and you have a line pre-amp Done
Now the question is also important.
Can we increase the already decent performance by maintaining the same basic scheme but changing working point components?
the answer I give myself is probably yes
How can the effects of changing a component be verified in a more practical way?
with the help of simulation software
Now if you ask me how close the distortion calculated with LTSpice is to the measured one, I have no idea
It is clear that the final judgment can be given only by a good spectrum analyzer that remains in my dreams given the prices
I am seriously considering purchasing an entry level model by Picoscope
When a friend of mine told him this, he recommended me a Psychoscope instead
Yes, for me audio is a disease. If I were good at mathematics I would have done it for a living
