- Joined
- Oct 3, 2019
- Messages
- 288
- Likes
- 518
Hi all,
I wonder if you can help. I want to improve the sound of my LP12 and feel transducer upgrades always seem to offer the biggest leaps. I currently run an MM cart, and would like to try MC. Though I've read several competing opinions elsewhere on whether my Linn Basik LVX tonearm is up to it. Can the science/measurement-minded of you here shed any light?
The Basik LVX specs are as follows:
I'm currently running an Ortofon VMS30 MkII MM. It was refitted by a Linn dealer during a service. IGD is quite bad, and I'm also getting a bit of sibilance. The Ortofon has a compliance of 22 µm/mN, tracking force range of 1.0 - 1.6g and weight of 5g. Using an online calculator, with the LVX this gives a resonance frequency of 8.1Hz - quite low?
Can anyone recommend an MC cart in the £300-£500 range that might work on the LVX? Or might my money be better spent on a new bearing/power supply/arm before addressing the cartridge?
Many thanks,
James
- Overall Length: 284mm
- Effective Length: 230mm
- Overhang: 18mm
- Tonearm rear length: 50mm
- Friction: Less than 20mg
- Effective Mass: 12g
- Cartridge Weight Range: 2-10g
- Stylus Pressure Range: 0.3g in 0.1g steps
Many thanks,
James
