Unless there's a problem at my end, the link goes nowhere.
That link works!Oops! We ran into some problems.
www.hifiwigwam.com
You sure? I see double monoblock and regular speaker cables here (+ power one, so "semi active").A four way active loudspeaker
There is apparently both a passive and an active version of this speaker .You sure? I see double monoblock and regular speaker cables here (+ power one, so "semi active").
Linn has offered active speakers since the very beginning of offering speakers in the 70’s, so yes, we are sure.You sure
@Tangband already answered:Linn has offered active speakers since the very beginning of offering speakers in the 70’s, so yes, we are sure.
Like it is the case Klimax 350, both should be available at some point.There is apparently both a passive and an active version of this speaker .
It does not show the fully active configuration, and that is for sure.The picture may or may not show the fully active configuration.
Maybe, maybe not, if the 360 is anything like the 350, the amplifiers are in the speaker enclosure.It does not show the fully active configuration, and that is for sure
On-board Amps | 2x 100 W, 2x 400 W, 2x 1000 W |
It looks like the most diffraction free enclosure that Linn has ever made for a loudspeaker. I have listened to the Klimax organik streamer, and this active exakt model has organik dacs . My guess is that they will sound wonderful.It's official:
360 | Speakers | Linn International
Linn 360 flagship speaker - unprecedented clarity and realism with innovative drive unit and amp technologies, and unmeasurably low distortion.www.linn.co.uk
And they cost 55,000£ (semi-active) to 87,500£ (fully active).
"K" stands for "Klimax", I guess... I don't know.Why do all Linn products have the letter 'K' in their names?
It started with the first product, the LP12 Sondek, then the Isobarik DMS and Isobarik Sara, after that all product had K in their name, as a full Linn system guy since the last 40 years, I like it, I think it is Kool.Why do all Linn products have the letter 'K' in their names?
Nearly but not quite true. For a while some of their lower priced products had an "x" rather than a "k" in their name eg Index, Nexus and Helix, all loudspeakers. I remember that it sometimes took almost as long to think of a suitable name as did to design a productIt started with the first product, the LP12 Sondek, then the Isobarik DMS and Isobarik Sara, after that all product had K in their name,
A four way active loudspeaker , good looking cabinet with rounded edges and exakt dsp crossovers.
It seems like Linn is taking diffraction problems seriously , finally.
View attachment 275219View attachment 275220
Rounded edges are always better, or does it depend on the speaker design? Or maybe it's not very necessary?Few people realize that the 10 mm radius that many assume significantly improves baffle edge diffraction is only effective for frequencies above about 6 kHz. Jim Theil of Theil Audio was one of the first manufacturers long ago to put radii of up to 100mm that lowers this frequency to around 600 Hz.
So it was you who subjekted us to aktiv Kelitiks was it? ooooh the stories I could tellFew people realize that the 10 mm radius that many assume significantly improves baffle edge diffraction is only effective for frequencies above about 6 kHz. Jim Theil of Theil Audio was one of the first manufacturers long ago to put radii of up to 100mm that lowers this frequency to around 600 Hz.
When I designed the Linn Keltik (a precursor to this loudspeaker) I put an array of grooves of different lengths and orientations on the baffle to try to break up the edge diffraction effects. It was the best of various patterns I tried and had a very useful effect on imaging etc but I suspect not as good as large radii
Nice to have you on this forum - I loved the sound of active Keltiks and also had active Kabers. I follow your speaker constructions at Legend acoustics with big interest. It seems that an active 4 way speaker is the way to go, without big compromises ?Few people realize that the 10 mm radius that many assume significantly improves baffle edge diffraction is only effective for frequencies above about 6 kHz. Jim Theil of Theil Audio was one of the first manufacturers long ago to put radii of up to 100mm that lowers this frequency to around 600 Hz.
