Looking for a simple way to do magnitude plot of a .wav IR file
Music1969
Hi all
I have a .wav convolution file
What's the easiest way I can do a magnitude plot?
I'm on macOS
@mansr
Basically I want to see what the EQ will look like
ernestcarl
Hi all
I'm on macOS
@mansr
Import the file into REW. If you want to simulate what the EQ effect would be to an already existing measurement, use the trace arithmetic A*B function in the ALL SPL view and re-adjust the offset to align the new trace with the original measurement.
