Low residual noise class a- ab amplifier suggestions
Chrise36
As i am in search for a class a or ab amplifier with low residual noise to bi amp my speakers i would like some suggestions for amps that have residual noise under 50μV. Integrateds receivers poweramps everything is welcome. I have only found specs and measurements for yamaha as301 to 801 until now. Any other suggestions?
dualazmak
NTK
US East
50 μV is -95 dB down from 2.83 V. That is below 0 dBSPL at 1 m for most speakers. Do you really need that low residual electrical noise?
C
Chrise36
I want to match my ncores as far as noise goes else i would be downgrading
pma
Prague
Remember you MUST count with output noise of the sound source, DAC or preamp. This will be multiplied by the gain of the power amplifier (your NCore) and there is no way how to avoid it, regardless power amplifier lowest noise. You need to know level diagram and noise of all the components in the audio chain, otherwise the considerations are pointless. In a real chain, it is the preamp or DAC that almost always determines the resulting noise.
DVDdoug
You're not downgrading the sound if you can't hear the noise. Would you consider it "downgrading" switching from an amplifier that goes to 100kHz to one that "only" goes to 30kHz?
You're more likely to find a S/N spec. You'd have to know the reference (signal) level and with some math (and maybe a spreadsheet) you could convert to volts.
C
Chrise36
The s/n is often misleading i started to give more attention to residual noise that gives an immediate impression about how noisy the amp should be besides it is not practical to find what you describe for every amp i would be interested.
C
Chrise36
For the time the dac (D50S) is driving the amp that is a quiet dac. What do you think of the Yamaha AS 301? It has good specs although the older AS700 seems to be much better amp.
pjug
If these will be tweeter amps, maybe neurochrome is a good option:
groovybassist
Wendell, NC
If you can DIY, Neurochrome is a great option. I run a Modulus-286 built by @tomchr as my DIY chops are nil.
