Loxjie D40 Review (DAC & HP Amp)
Rate this product:
    Votes: 4 1.7%
    Votes: 4 1.7%
    Votes: 42 17.9%
    Votes: 184 78.6%
This is a review and detailed measurements of the Loxjie D40 stereo DAC with Bluetooth and headphone amplifier. It was sent to me by the company and costs US $430.
I like the design -- it reminds me of some European brands. Bright white LED display is highly responsive as is the rotary controller. I expect and am happy to see built-in power supply in this price class:
Loxjie D40 DAC Measurements
Let's start with our usual dashboard using USB input and XLR connection:
This is stellar performance with distortion at -140 dB and noise floor that is almost falling off the bottom of the chart! No wonder then that the D40 ranks as the forth best DAC I have ever measured:
RCA output performance is nearly as good:
Dynamic range as we could predict is excellent:
IMD performance is excellent other than a small indication of "ESS DAC IMD Hump:"
Linearity is textbook perfect:
Multitone results is superb:
Jitter performance over USB is excellent as well:
Toslink and Coax add some low frequency benign jitter:
Loxjie D40 Measurements Balanced Coax Toslink SPDIF Jitter Stereo DAC Bluetooth.png
Three filters are provided:
Attenuation is quite high which helps when we perform wideband THD+N measurements:
Loxjie D40 Measurements THD+N vs Frequency Balanced USB Stereo DAC Bluetooth.png
Loxjie D40 Headphone Measurements
Let's start with 50 mv and full output SNR:
The former is slightly below average:
Fortunately there is good amount of power with very low noise and distortion in general:
Notice lack of clipping. This means any distortion you hear is in the headphone or the content!
Loxjie D40 Listening Tests
I performed my testing with my Sennheiser HD650 and Drop Ether CX which are at different ends of the impedance spectrum. There was plenty of volume driving both with superbly clean sound. Driving my everyday Dan Clark Stealth headphone was also satisfying but due to its lower sensitivity, the D40 could not drive it to its maximum volume.
Playing at this level of performance is not easy: tons of attention needs to be paid to circuit design and layout to stomp any and all sources of noise and distortion. Other than leaving some ESS IMD distortion on the table, the D40 performs superbly in DAC department. The headphone output while not at the same level, still provides excellent performance and volume level.
I like the physical design which sets itself apart from the competition while being very performant to user input.
It is my pleasure to recommend the Loxjie D40 DAC and Headphone Amplifier.
_thelaughingman
WHOA!!! Fourth best SINAD on the DAC list. Definitely a good product with the balanced offering and that price.
alekksander
NRN PL
nice!
does anyone know why the multitone graph usually shows more distortion in lower frequencies?
Reactions: 777
_thelaughingman
Thanks Amir! Nice work Loxjie!
Great DAC for the price. The HPA is iceing on the cake.
I might need to come up with an excuse to get this.
I was literally thinking of the same idea to do away with the stack that i have on my desk.
Dzhaughn
Not bad at all. But for just a bit more money, wouldn't you rather have a MiniDSP Flex and a $120 headphone amp (say, the Magni) that performs better?
With the Flex, you can listen LPs with properly EQd headphones with the full 20 bit dynamic range. And then add a tube amp EQ filter when you want to dream about your ancestral hi fi sound. Maybe you can make Joy Division sound like it was intended to: on a cassette player in a car.
Of course, the second paragraph is meant to be cute. But I honestly think the MiniDSP Flex is a game changer. It should completley change the workflow for how Amir tests speakers.
enricoclaudio
Houston, TX - USA
Thanks for another great review, @amirm Thanks God I'm not in the market for another DAC as this could have been my choice right now.
Aperiodic
So Amir, pros and cons, this unit vs the similarly priced (and just-reviewed) JDS Element III?
_thelaughingman
Balanced outputs on this vs SE on Element III and better SINAD on this because they’re using TOTL ESS chip. JDS lab focused on polishing the element vs pushing the SINAD war, plus the digital volume pot and OLED display on element for better product.
remlemasi
I’m in the same boat. While Element III is technically not SOTA DAC/SINAD wise, it shouldn’t matter right? Both are comfortably high enough that they should sound identical right? So it’s all about features, industrial design, after sales support, etc.
DrIacozKnows
Thanks Amirm.
This is the best DAC in terms of cost benefit ratio.
In the headphone amp field the Topping A30PRO is still hard to beat.
Aperiodic
If the customer support provided here is anything like for SMSL (Nonexistent IME; I have the Sanskrit 10 vII and never got an answer to a simple technical query after 2 or 3 emails), then count me in the JDS camp. Responsive customer service is worth more to me than an overkill SINAD number.
