Martin Logan SWT-X Wireless kit for Dynamo X subwoofers
Astoneroad
a Cave in the desert
Does anyone have any experience with the Bluetooth transmitter option for Martin Logan Dynamo subwoofers? There is very little info online about this, which definitely raises suspicions that it isn't widely used, usually indicating a mediocre product. I'm very limited to placement of my Dynamo 1100x and considering trying this. Any and all insight is appreciated, since I'm just beginning this research. Any experience with the Anthem app that comes with it, is also welcome. Thanks. SWT-X Manual
droid2000
I'm running a MartinLogan 700 wirelessly. Not sure if it's using the same wireless hardware that you listed. Transmitter looks the same but receiver is built into the sub. It sounds good to me. As good or better than my SVS sub also running wireless.
You don't have to use ML wireless gear with ML subs. Any wireless gear with RCA outputs will work.
Astoneroad
Astoneroad
Are the RCA connectors plugged into the DAC? My vintage McIntosh only has xlr inputs.
FrantzM
One thing to consider in these wireless links is latency. I used wireless link (Not that of the OP) and the subwoofer appeared to be located beyond the limits of my AVR, I believe it was "seen to be at 60 feet, from the microphone.
These items will often tout their range, frequency response or THD but rarely their latency.
Caveat emptor
Peace.
Astoneroad
Astoneroad
Caveat emptor
Peace.
Yes, certainly one in a basket of issues that I'd rather avoid. Emptor is caveated, thanks.
droid2000
My DAC has both XLR and RCA outputs, so the XLR outputs go to the amp, and the RCA outputs go to the wireless transmitters.
If your DAC or preamp only has XLR outputs, you can use XLR to RCA converters to feed the wireless transmitter.
Astoneroad
Astoneroad
Thanks. My mistake, amp has rca inputs, so rca into DAC from transmitter, from DAC to amp via rca.
