Massdrop X KOSS ESP/95X Electrostatic Headphone Review
Jose Hidalgo
France
IAtaman
Sorry your religious cult is under attack by heretics and the best you can do is to meme vaguely about it. I wish I could've spared you this pain and suffering.
Could you please ease on the tantrum you are throwing because some people on internet don't want to accept your beloved headphones are great.
If I understand you correctly, you are claiming estat headphones must be charged for a while to sound at their best. I don't know anything about that and am willing to learn. If you have anything more than a drop.com forum post about it, please do share - I would like to understand better. If it is you and your buddies' experiences only, not interested.
Please also note that there are people on this forum who has probably forgotten more about audio, audio electronics, estats etc than you will every know, so a bit of humility is highly recommended as well.
abm0
In order to have "more" I would first have to have at least those first quotes, but now that they've been deleted I'm back to square one and the discussion will seem to come out of nowhere and be motivated by almost nothing instead of being motivated by comments from experienced people with years if not decades of usage of electrostatic headphones/speakers.
But anyway, I've found something more concrete about one of Nottagorilla's quotes on Stax designs putting megaohm-scale resistances in series with their headphone diaphragms:
MyNewMicrohphone said:
electrostatic drivers have extremely high impedance ratings typically above 100 kΩ (100,000 Ω) [...] This seemingly extreme impedance is required to keep the electric charge from escaping the driver.
I assume this is pure resistance we're talking about, so the effect has to be symmetrical, so by however much that 100k/1Mohm resistance is slowing down the leakage of the membrane charge once accumulated, by the same amount it should slow down the initial accumulation itself. Now I just need more numeric data on how much slowing down is going on here, or what the total capacity of the membrane is, like in Coulombs or something. If there's any technical reason to say estats need to charge for tens of hours, it has to be tied to this.
Of course there are, I've seen them discuss technical topics in several places on here since I joined, and there is no sign of them in these last few exchanges on this topic. It's almost insulting to real engineers and scientists to compare them to this tantrum-throwing friend we had in here swinging back and forth between flamebaiting and insisting he didn't care to continue the discusison. :rolleyes:
Jose Hidalgo
France
Since you are talking about me, then know that I just happen to be an engineer from one of France's top schools, which happens to be the equivalent of MIT.
Is that "real engineer" enough for you? Do I need to justify my studies and my knowledge just to please you? :facepalm:
And BTW, when you talk about somebody behind his back, at least have the courage to name him.
Like I said, I just don't have time to waste with the audiophile tantrum YOU are trowing from the start (as said by IAtaman here).
And yes, I still get notifications about this thread. So in the future, think twice about what you say and how you say it. Or else nobody @ ASR will give a damn about your posts.
Back to real life now.
abm0
Hah! Just as I suspected, capacitors don't charge linearly but asymptotically:
Remember that, at any finite t, Q is less than its asymptotic value CV
Upon integrating Equation 5.19.2, we obtain
Q=CV(1−e^−t/(RC)) (5.19.3)
Thus the charge on the capacitor asymptotically approaches its final value CV, reaching 63% (1 - e^-1) of the final value in time RC
So since the estat membrane charges like a capacitor, we can likewise expect it to take some very large amount of time to reach exactly-full charge (math analysis says infinite time, but since physics is quantized we only have to wait for the "last electron" to get out in order to reach that 100% positive charge on the membrane and determine that the process is over).
So it turns out there should be exactly zero surprise to hear someone claim that it takes some huge amount of time to fully charge an estat membrane - that's just textbook capacitor physics. The only real question is what is the last charge increment that can still make an audible difference during estat operation (or how long do you need to charge until there is no more audible benefit left to gain).
IAtaman
Time constant of an RC circuit can be calculated simply by multiplying capacitance with resistance. I think you said resistance was in the range of 100K ohm. If you know the capacitance as wel, we can easily calculate how long it might take for it to reach any arbitrary voltage level compared to max voltage.
abm0
Well yea, that's what it boils down to. Not sure they publish diaphragm capacitance though. I can find a published spec of 110 pF including cable for the Stax SR-L300, but if typical cable capacitance is 40-60 pF (if it's nothing crazy long) it doesn't make sense that the diaphragm with its comparatively huge surface area would only add another 50-ish to that. I think they're only counting the stators in that, since those are the ones in the actual audio signal path. I don't know that we can easily infer the diaphragm capacitance from the stator capacitance.
IAtaman
Well, 100nF capacitance would have a time constant of about 10ms for 100K ohm resistance. At 100ms, the system would have reached +99% of its voltage. If you go down to pico range, it would be even shorter. If the assumptions and calculations are correct, it looks like it is very unlikely for longer charging to make any discernible difference.
abm0
Which assumptions? That published value is likely not the membrane capacitance since it's unrealistically low for such a large surface (it's comparable to the inter-wire capacitance in the cable itself - ridiculous).
Remember I quoted 110 pF, not nF. Assuming only 60 pF of that is the driver, and with Nottagorilla's hint about Stax typically using a series R>=1Mohm, we get RC=60μs and then 99% charge time = 5*RC = 300 μs. That looks like it could only be done 3.33k times/s and would only allow the reproduction of sine waves of up to 833 Hz (0-to-max charge is 1/4 of a sine period).
Can't possibly be the stators, right? Wrong. If they targeted charge states of up to 99% there would always be that asymptotic curvature enveloping the reproduced signal and making it sound like it's constantly soft-clipping. For music reproduction you can't just push a capacitor-like driver to its charge limit, you have to keep it below some percentage where the charging curve looks almost perfectly linear.
Can't say how low that would have to be, but I'm thinking it has to be damn low. Even if we used R=100kohm we would still have to keep the charging confined to where it doesn't take more than 0.25*RC so the process can be repeated at more than 160 kHz and allow the reproduction of sines of up to 40-ish kHz, which is a typical estat spec.
And even with all this we still don't know the membrane's capacitance or how long it takes to charge to its constant positive bias. :D
IAtaman
I don't understand what are you talking about.
Below is a simplified diagram of a electrostatic speaker. You apply a constant voltage to the diaphragm / membrane. That creates an electric field between the the membrane and the stators. You apply the audio signal to the stators. Membrane moves to create changing air pressure. Are we aligned so far?
Now, what I thought you were saying was that it would take a lot of time to charge the membrane for it to produce sound properly. Neither the charge voltage of the membrane, nor the time constant of the RC circuit that dictates how long it would take to charge it has anything to do with the frequency of the audio signal. So what are you talking about when you say 140Hz or 833hz and such?
abm0
Yes.
No, it doesn't, I would say at first glance. (Orrr maybe it does - see below.)
Trying to estimate what frequencies the stators can reproduce based on the published Stax spec of "110 pF including cable", which I first thought characterized only the capacitor formed between the stators and said nothing about the membrane.
But if I look at that circuit again, it might be the combined capacitance of stators+membrane treated as 2 parallel capacitors, in which case all the estimations would have to be redone.
Are you reading it differently? Where do you see the 110 pF (minus cable) spec being realized on the diagram - between which terminals/plates?
IAtaman
With all due respect, I am getting the feeling that you have no idea what you are talking about and making theories up as you go.
There is one obvious capacitor in that circuit. Base voltage of that capacitor is constant, and sound is reproduced by modulating the electrical field by applying the audio signal to the stators. Even if the capacitance of was 10 times higher than what is specified at 1000pF (or 1nF), it would be almost fully charged after 5 seconds.
I don't know about you, but to me the theory that these needs to be charged for hours to sound right is starting to smell sour.
abm0
Well yes, I never claimed to be an expert at any of this. That's why I started by quoting the experiences of others claiming to be long-time users of the device, that's why I went on to trying to piece together what I could from different sources to explain said claims etc.
Tru dat, even in my "let's fumble with some numbers" analysis, things are already not looking great for the many-hours hypothesis, once the Stax spec is plugged into the formulas.
It could be that this was never about charging the membrane to the full Coulomb value but rather - as was my first suspicion before going into the capacitor discussion - about the uniform spread of that charge across the membrane surface. (I notice Ken Rockwell is also talking about it in these terms in his Stax reviews.) If the charge is not spread evenly you will not get equal forces acting at each point on the membrane and therefore you will not get perfectly planar movement, resulting in higher distortion (basically the reason planars were invented in the first place). How charge spread could be measured though is really completely beyond my pay grade. Short of redoing the distortion/noise/etc. measurements multiple times as the headphones stay powered for minutes and then hours, I don't know how this could be tested.
IAtaman
Or alternatively, and a lot more likely, charging them for a long time has no effect on the sound quality of these headphones
abm0
That's just a guess, I would prefer to see it confirmed with measurements before adopting it as some kind of final conclusion.
IAtaman
Sure, it is just a guess, in the same way that every time I turn my amp on, I guess it will work. Good luck to you.
abm0
Nope, not in the same way. Apples are not oranges. These are electrostatic headphones, not electrodynamic, not magnetodynamic. Their membrane does not retain the same movement-relevant characteristics when unpowered vs. powered. How that transitions happens and what it does to the performance is worth investigating.
Svperstar
I'm thinking of getting the iCan Phantom, patiently waiting to see if anyone is every going to use the 95x on it.
