Matrix Audio X-SABRE 3 DAC/Streamer Official Thread
TSullivanM
Ok I have done some heavy troubleshooting now, which included completely reinstalling Windows for example and now im stuck with some serious problems on this brand new device. I hope its user error on my part.
Everything is installed fine and when I boot up the computer and turn the X-sabre on everything works fine, I can watch youtube for hours if I want to but the trouble starts when im switching apps. If I play a movie clip or music file from the hard drive everything suddenly drops. The computer still shows everything as working its just that there is no sound. And this seems to come when switching programs. If I stick to one and the same everything works but when I switch I need to reboot both the computer and the X-sabre for everything to start working again.
SirraH77
Have you tried changing exclusive mode setting from your audio device properties?
(the picture is just from my laptop speaker settings, but all audio devices should have those settings)
Charlie
since the last update of ma remote, the Matrix finds my nas but the music no longer synchronizes. Does anyone have this problem too?
Charlie
I have the same problem on my Android phone as on my iPad
MatrixAudio
Xi'an China
Hi, this is the built-in UPnP function by Synology NAS, it doesn't support search, so couldn't be imported into Library of MA Remote App.
In this case, you can browse the UPnP server by folders. After that pop-up notification, back to Library - Files.
If you want to import all the contents from the UPnP server to the Library, The UPnP server should support "search" functionality. You can install a MinimServer on your Synology. Please refer to this tutorial. https://matrix-digi.feishu.cn/docx/JHxtdTuMuonD7JxF8ehcFHcHn5f
Just like the screenshot above, tick the UPnP server named MinimServer, albums will be imported.
Charlie
Mini server does not recognize xsabre3.
Before this update I had no problems. Before, ma remote read the contents of my nas without problem.
Goodfellas27
Try the MConnect App
It's great for upnp
You could also try cleaning your app's cache on your phone
officialsm
About frequency response on XLR i was reading:
Frequency Response: 20 Hz-20 kHz ±0.05 -3dB@86 kHz
Means that response is up to 86KHz ?
