Measured differences between interconnect cables
GXAlan
Presented purely for interest.
TLDR:
1) Differences in cables exist and can be measured at the audio level and achieve statistically significant differences
2) The differences are vanishingly small, so it doesn't make sense when listening to audio
3) The differences may make a difference when measuring gear
4) These tests will be repeated when my E1DA Cosmos Grade-A unit arrives later this week.
I'm going to tell the whole story and the process I took.
Background, Korg DS-DAC-10R in loopback mode. This isn't a high performance DAC/ADC but it does have a clean power supply, easy to access RCA jacks and it's pretty consistent. It's consistently noisy and consistently distorted from run to run. My main goal was to run through a few different software options in preparation of my incoming E1DA Cosmos ADC.
Cables on test:
1) Silver plated copper, flat ribbon cable, unshielded. I thought it sounded pretty good and then I tried it where I had RF interference and ditched it. I actually wanted to send it to Amir a few years back, but cable testing was a low priority. This is the cable shown here:
and here is proof I thought they sounded different.
2) Monster Cable Ultra Series 800 "THX" Certified
Got these as a freebie with something I bought.
3) Straight Wire Virtuoso 3 (JBL Synthesis branded)
Got a bunch of these and I also thought it sounded noticeably better than I bought more. These came from eBay from a pulled system.
First Experiment
RMAA loopback.
I ran the cables A->B->C->C->B->A sequentially and got this:
No real difference but it was interesting that the noise and dynamic range of the silver cables were very different from the Straight Wires. If you just throw them as aggregate as unpaired student's t-test, it's p < 0.0001
Next I ran multitone tests, no real difference. I felt as if there were differences in the subjective SHAPE of the noise in the bass area
This is where it gets very interesting
1. I don't know why the Straightwire delivered an extra dB during one run. I didn't change anything.
2. Notice the humps at ~15 kHz and 20kHz.
I then decided to run a test tone at exactly 15kHz
These tests are run serially. That is, I ran the full set of 50 Hz test tones. Then ran the full set of 15 kHz test tones. (I changed the cables 6 times not 3 times).
With these sets of tests, it was pretty clear that the left and right cables were different with the straight wire. We're still looking at a difference that is vanishingly small, but you do see differences.
Reversing the cables shows that the humps follow the cable.
Since I had multiple StraightWire cables, I found some replacements and measured them again. Boom. Really clean results. This was about 1 hour later.
Immediately after getting these flat results with the newer cable, I went back to the broken cable 1 hour later after the original set of tests to ensure that it wasn't random noise in the system somewhere
If you compare the 15 kHz results between the Monster Cable and the working Straight Wire cables:
Blumlein 88
I don't think using the T-test like this is appropriate. Firstly too few samples. Yeah, the math works, but too few samples. Secondly this just isn't the use for such a thing.
The one Straightwire having that noise hump is interesting. Would be nice to figure out why? Can you remove the ends to see if a connection is poorly done or nearly touching the shield etc. ?
G
GXAlan
Students t-test just requires the distributions to be normal, which we would expect and going with a two tailed comparison for continuous datasets is fine. The reason you get away with few samples is that the standard deviations are very small relative to the effect size.
A very nice way to look at this is the Vanderbilt University Power Analysis tool where you get to figure out how big of a simple you need to reject the null hypothesis at your desired p-value.
If you look at the L-08m review, I identify the humps as correlating to the use of ceiling LED lights. What’s interesting is that the cables are all shielded, and the lights were all on for this set of tests and there were no dimmers involved. It was a different room from the room I did the L-08m measurements though.
It may be some hole in the shield from old cables affecting the results
Blumlein 88
My old university, but I haven't used their Power analysis tools. I still don't see how this fits for such a statistical treatment in this kind of testing. The math works, but it isn't fit for this use.
G
GXAlan
You are comparing two means and want to reject the null hypothesis that the two means are identical.
1) assumption is that the distribution follows a normal curve. Since we are looking at random noise, it’s pretty fair to assume that it is a normal distribution. This is where a PhD statistician can spend more time to prove a measurement is normally distributed.
2) are the tests paired? No. Each measurement is independent.
3) is it a two- or one-tailed test? Is there only one way the comparison could go? Or could one population have a higher mean or a lower mean? Two-tailed.
4) is the data categorical or continuous? Continuous.
5) then Student’s t-test is applicable.
I have shown that the two groups of measurements are statistically different at a confidence level of p=0.0001. There is a 1/100th of a percent that I detected a difference between the two cables when no difference actually exists.
But statistically significant is not clinically significant.
If I were to repeat this test another 99 times, I would expect 95 of those tests to show that the difference between the two cables is somewhere between 0.567 to 0.733 dB.
Here is the free program I mentioned. Very convenient and to the point.
As a practical matter though, it is not necessary. You can just provide standard deviation and mean to give confidence in the results. We use statistical analysis when the data itself is so random looking that we can't make inferences from it. With these measurements, that is not the case.
kongwee
Nobody is doing a full setup and measured at the speaker side for the real SPL. Assuming that is no difference.
G
GXAlan
Agreed.
100% cables are a waste of money for audiophile tweaks. :). This is a clear example of something measurable but not actually important.
dorakeg
Actually this report from QED provides very good insight on cables. ITs very old but I would say still pretty good read.
kongwee
I really been through lots of these stuff. In the end, nobody plot the frequency response direct from full speaker setup.
MAB
Portland, OR, USA
Yeah, we all been through lots of these things. In the end, someone always says something like "but you didn't plot the frequency response direct from full speaker setup"... as if that nullifies the result. I hope you realize that is a totally different experiment than what the OP did, with different test method and different resolution.
I also hope you realize that the experiment you ask for actually has been done many times. For instance the impact of binding posts:
I post this one because the investigator actually constructed an experiment that by design was to measure specific parameters at moderately high resolution, then measure the response of a speaker. And one of the legs of the experiment was a hammer test using steel nails as binding posts (pun intended!;)) And did show very slight measured reduction in SPL at high frequencies, consistent with our understanding of how and circuits and speakers work. Details are in the link, don't want to distract from this thread though...
OP here is exploring a totally different realm:
So, if you're working on vanishingly small, and work had already been done on really small, sorta small, small, and not so small, don't you think it's a bit absurd to raise the "but you didn't prove audibility" flag???
And, if I understand the first post, OP gonna show us the results again after some really nice new test hardware arrives!:)
So @kongwee , we are really interested here in how these measurements progress. I think the audibility argument is a bit misdirected!
G
GXAlan
What is interesting is that I got my E1DA Cosmos and identified that hump as correlating to the presence of LED lights or not.
Believe it or not, the silver cable literally broke with one of the strands de-laminating from the ribbon portion so I had to discard it.
In this first test, what I have shown is differences in shielding presumably. The broken Straight Wire cable may have a small enough hole in the shielding and when we're looking at numbers, it can be enough of a difference.
I don't think I need additional cable testing since there is other equipment to prioritize right now.
MAB
Portland, OR, USA
That is interesting. What on earth is going on with the LED???
OK, yeah. Good to move on rather than dwell on cables.
DonH56
Monument, CO
LED lights include a switch-mode power supply and are fairly notorious for radiating noise (EMI/RFI), especially the cheaper ones.
Modern instant/fast-start fluorescent lights have a ballast that runs at about 60 kHz, another common noise source.
G
GXAlan
Yeah, these were contractor grade low end stuff. I haven’t had a chance to switch the ones in this test room with the nicer Halo recessed lights. Would be neat to compare :)
kongwee
Another link with partial setup testing the usual voltage dB measure. Nobody I said again done in SPL. Capture the real waveform from a complete setup.
Head_Unit
By "usual voltage dB" you mean that the graphs in that thread are what, voltage at the speaker? It was not clear to me though I read it quickly.
- I think SPL is perhaps too variable due to ambient noise, maybe microphone self-noise, your body moving around the room.
- If a tester doesn't have the setup for that then they won't do it ha ha
- Measurements in the electronic domain are surely more precise and repeatable. And if there's an "audible" difference in voltage at the speaker terminals, it should be audible out of the speaker.
Still, this recalls a heated argument I had with my long-ago manager about checking if a magnetizer was working properly. He insisted on magnetizing a speaker at different levels and measuring the SPL. I strongly felt to check the flux with a coil, that the speaker way was imprecise. Eventually he annoyedly said "OK do that too but measure the damn speaker because I say so and I'm your boss!!!" To which I said "OK, fair enough!"
--> Even if measuring the speaker output might be problematic, it would be nice to see it anyway
MAB
Portland, OR, USA
I just noticed your response, and you got it wrong. This test included everything, including SPL, with a microphone. Did you even bother to read it? If you did, how did you not comprehend what tests were done? In any case, you are incorrect in what you said.
MAB
Portland, OR, USA
I think @kongwee fooled you with misinformation. In fact, complete set of tests were done, both electrical response and acoustic response with real speaker and microphone. It is a really careful job too, and a nice writeup from an ASR member who regularly contributes. I respect that. And Kongwee, as often does, rubbished the whole thing with misleading statement. Kongwee seems eager to upend science, I find this response very troubling since it is at best incoherent, and at worst is a purposeful misinterpretation.
