Measured differences between interconnect cables
Head_Unit
I just noticed your response, and you got it wrong. This test included everything, including SPL, with a microphone.
[referring to @kongwee
I think @kongwee fooled you with misinformation. In fact, complete set of tests were done, both electrical response and acoustic response with real speaker and microphone.
Huh? Where? I just looked at the original post again reading very slowly. There are many nice graphs, very interesting. However now I notice it does not say what the cables are connected between and what those graphs are showing. ARE they electrical? Acoustical? Am I going blind? Is it in a later post I missed?
@GXAlan can you please elucidate?
It's a lot of nice work, actually somehow the original post can maybe be edited to clarify?
MAB
Portland, OR, USA
Kongwee was responding to my post, where I referenced the following experiment, with all sorts of acoustical measurements, and said that it had no measurements.
Cbdb2
Vancouver
Actually this report from QED provides very good insight on cables. ITs very old but I would say still pretty good read.
Bs from a cable seller.
MAB
Portland, OR, USA
That fact that this thread show the measured in component, not speaker SPL level. Really don't need to tag me. I am not even in this tread https://www.audiosciencereview.com/.../different-binding-posts-is-it-audible.16052/
No, I posted the link stating that someone always says "but you didn't measure full-speaker" or whatever...
And you responded that the link I posted was a "partial setup testing the usual voltage dB measure. Nobody I said again done in SPL." Which is a mischaracterization of the link, which contains bot electrical and acoustic measurements, and quite a comprehensive set of them.
Here is a screen capture of the exchange to refresh your memory.
Understand?
G
GXAlan
Electrical. Unbalanced RCA cables between a USB DAC and ADC. This was done with a low tech Korg DS DAC 10R which shows that even a plain device can be sensitive enough to measure cable differences (when the environment is noisy).
I later caught more effects of LED ceiling lights with an E1DA Cosmos.
kongwee
Understand?
I am responding you do not a full speaker setup. A complete system. Real Waveform not dB vs frequency plot. A binding connect to tweeter with mic feed of you can say you got me. I admit it just base on this setup, ignoring a full speaker setup I mention. I admit I am wrong that you do a partial BP to tweeter with mic feed. I'm apology. But no to a full setup. And no to show real waveform.
Reactions: MAB
MAB
Portland, OR, USA
Thanks, appreciate your post.
Pegwill
Hi Guys
While I don’t pretend to understand all the technicalities behind the measurements neither having access to the sophisticated equipment to highlight the differences, while skimming across the internet I came upon this.
I’m sure a lot will have seen this device however that is not the reason for the post, but how he draws his conclusions by using ‘Audacity’ a free app. This of course will be available to most. It would appear the biggest problem is aligning the two recordings. I have yet to try it myself, but it maybe of some use after all if, you can’t see a difference, I guess you won’t be able to hear a difference.
Just my thoughts anyway, hope it helps.
Regards
Pegwill
DSJR
Suffolk Coastal, UK
Youtube poster techmoan also tried one - [edit - CD shaver] (I love his often irreverent posts) and I remember he didn't find it made any difference at all.
ctrl
.de, DE, DEU
[off-topic] In reference to the "Different Binding Posts - is it audible?" thread.
The thread shows electrical and acoustic measurements of various binding posts.
The electrical resistance measurements are used to show that you can easily measure minimal differences between different binding posts.
The acoustic measurements with tweeter and microphone enable us to classify how big the influence of the binding posts is on the acoustically transmitted signal of a loudspeaker. In the experiment only the high-pass filter part of a crossover is used (to feed the tweeter). Just as in hifi high-end circles a passive 2-way speaker would be driven by bi-amping.
There, the influence of the different binding posts (see section 3 and below) on the acoustic frequency response, the phase frequency response (i.e. the temporal behavior) and the multitone distortion (which include harmonic distortion, intermodulation distortion, etc.) is then shown.
Please ask further questions about this in the "Different Binding Posts - is it audible?" thread.
Pegwill
Hi @DSJR
It’s not clear to me if you read my post or just looked at the picture. The whole point of my post was the use of ‘Audacity’ not whether or not the device being tested worked or not.
If you consider that Audacity cannot be used in this manner that’s a different thing. It seemed logical to me, who does not have acres of technical equipment or the knowledge to use it, but I think I could get my head around Audacity.
Regards
Pegwill
pkane
North-East
Presented purely for interest.
TLDR:
1) Differences in cables exist and can be measured at the audio level and achieve statistically significant differences
2) The differences are vanishingly small, so it doesn't make sense when listening to audio
3) The differences may make a difference when measuring gear
4) These tests will be repeated when my E1DA Cosmos Grade-A unit arrives later this week.
I'm going to tell the whole story and the process I took.
Background, Korg DS-DAC-10R in loopback mode. This isn't a high performance DAC/ADC but it does have a clean power supply, easy to access RCA jacks and it's pretty consistent. It's consistently noisy and consistently distorted from run to run. My main goal was to run through a few different software options in preparation of my incoming E1DA Cosmos ADC.
Cables on test:
1) Silver plated copper, flat ribbon cable, unshielded. I thought it sounded pretty good and then I tried it where I had RF interference and ditched it. I actually wanted to send it to Amir a few years back, but cable testing was a low priority. This is the cable shown here:
and here is proof I thought they sounded different.
2) Monster Cable Ultra Series 800 "THX" Certified
Got these as a freebie with something I bought.
3) Straight Wire Virtuoso 3 (JBL Synthesis branded)
Got a bunch of these and I also thought it sounded noticeably better than I bought more. These came from eBay from a pulled system.
First Experiment
RMAA loopback.
I ran the cables A->B->C->C->B->A sequentially and got this:
No real difference but it was interesting that the noise and dynamic range of the silver cables were very different from the Straight Wires. If you just throw them as aggregate as unpaired student's t-test, it's p < 0.0001
Next I ran multitone tests, no real difference. I felt as if there were differences in the subjective SHAPE of the noise in the bass area
This is where it gets very interesting
1. I don't know why the Straightwire delivered an extra dB during one run. I didn't change anything.
2. Notice the humps at ~15 kHz and 20kHz.
I then decided to run a test tone at exactly 15kHz
These tests are run serially. That is, I ran the full set of 50 Hz test tones. Then ran the full set of 15 kHz test tones. (I changed the cables 6 times not 3 times).
With these sets of tests, it was pretty clear that the left and right cables were different with the straight wire. We're still looking at a difference that is vanishingly small, but you do see differences.
Reversing the cables shows that the humps follow the cable.
Since I had multiple StraightWire cables, I found some replacements and measured them again. Boom. Really clean results. This was about 1 hour later.
Immediately after getting these flat results with the newer cable, I went back to the broken cable 1 hour later after the original set of tests to ensure that it wasn't random noise in the system somewhere
If you compare the 15 kHz results between the Monster Cable and the working Straight Wire cables:
Just saw this thread. A heroic attempt to test interconnects! I'd suggest that a simpler test for cables would be using DeltaWave to null the results.
DSJR
Suffolk Coastal, UK
Hi @DSJR
Regards
Pegwill
I was talking about the CD shaver (edited to make it clear). I have no issue at all with objective comparisons of cables and apologise for muddying the waters (I'm extremely good at that it seems....).
G
GXAlan
This predates my other experiments with DeltaWave/Multitone tool. :)
I still have to redo the amplifier null tests. I have a better thought process on how to do these reliably.
pkane
North-East
Here was my attempt from a few years ago:
egellings
That is interesting. What on earth is going on with the LED???
OK, yeah. Good to move on rather than dwell on cables.
Maybe the LED was powered by a switch mode supply and spewing a bit of RFI.
egellings
10 nanoseconds per division, and you are worried about a small anomaly at that time scale affecting 20 to 20kHz audio? I 'spoze.
Geert
Do someone cares on commenting that? (even a profane like me smells poo...)
Edit: since the post above was removed, the context of the question is the 2024 video and article Alpha-Audio did on their measurement and listening test of 32 interlinks.
It's clear to everyone they're testing with a signal frequency that's far higher than our upper hearing limit. It also far outside the bandwidth of audio equipment, so in practise you won't find such transients in an interlink. This means the measurements by themselves don't prove anything.
However, their argument is that there's a correlation between their measurements and what they've heard, which proves their subjective observations are real and accurate.
So my first question is, how accurate are their subjective observations because they didn't publish any information on that? I would like to see some stats on how the participants judged each cable, and how reliable these judgements are (which involves multiple blind tests for each cable). I also hope the participants judged the cables without influencing each other, so not like in their usual review webcasts.
G
GXAlan
My comment as the guy who posted these measurements:
“This is a clear of something measurable but not actually important.”
I do think neutrik connectors feel better than generic ones and some cables show more creases or lay down more nicely. If you aren’t running in wall cables, nice cables do look nicer especially in multi-use rooms. But once you get beyond basics, even if you allow for the remote possibility that it is better, moving that budget toward better speakers is a smarter move.
