Measurements of RME ADI-2 DAC and Headphone Amp
Alan S
Ocean State China
@MC_RME
Why did you delete my post and my account in RME User Forum ?
That is a very bad move.
If there is anything wrong with the post, you could reply.
Is that what you do to the user?
Is that the way you handle the problem?
I created a user group and there are 50 members, we are very disappointed.
Alan S
Ocean State China
I'd assume it's not providing power on the USB device side, and the power input on the isolator is only there to drive the isolator itself when USB host power is not sufficient (the isolator requires 320 mA). Not a problem with the ADI-2 DAC, though.
The Intona devices do provide power on the device side using linear regulators.
EDIT:
Nevermind, I just found this thread:
https://www.eevblog.com/forum/beginners/129322-help-with-crappy-usb-isolator/
I'm going to cancel the order. I guess the Intona devices are really the only proper solutions on the market.
I read about your USB port noise issue.
Do you have any plans to test with Intona?
MC_RME
@MC_RME
You posted three times in a row. Number 1 was the above thread opener but without the last paragraph, so it made zero sense. Number 2 was a totally unrelated quote, making no sense again. Number 3 was only two words: '10th floor'. What? This all from a suspicious chinese mail address. So I decided you must be either a spammer checking or a troll. We have to do this daily multiple times to keep our forum clean.
There is no problem. And you are not banned so can register your account again. Maybe avoid '10th floor' posts in the future...
BTW, what both forumsters and admins also don't like is to post the same stuff into multiple locations simultaneously, keeping people busy that try to help, not noticing they are wasting their time as you got answers somewhere else already.
Alan S
Ocean State China
I didn't post 3 times, I edited, in the same location.
I edited because I tried to describ clearly. Is there anything wrong with the edit function in RME User Forum?
You said you didn't see, so I told you where is the post.
My first post was 10th floor, yours was 11th.
You deleted them, so that thread just has 8 replies now.
Where is your so called "multiple locations“ ?
A user with Chinese mail address edited his post, you deleted his account.
What's your motivation?
I asked you for help and I choose my words carefully. I said "Could you please help" but your rude response let me down.
VintageFlanker
Paris
Why was M040 activated?
Maybe you should ask yourself why it happened "one day"? What was your previous DAC?
Should I do something about it?
I see nothing related with the ADI-2 DAC. You're complaining about a very specific usage with a very specific function of your speakers. Maybe you just should turn off this sleep function? Or ask Genelec support instead?
:facepalm:... I don't believe that.
MC_RME
4. One day, the USB cable was not plugged in early, and the DAC was not turned on. When I turned on the computer and plugged in the USB cable, M040 was activated. I repeat, the DAC was NOT turned on.
Why was M040 activated? Is that a ground loops USB issue? Should I do something about it?
Connecting cables can always cause small pops or clicks. In this case it seems to have happened via ground, so the ADI does not need to be turned on for it to happen. But as long as you don't hear noise or hum this would not be called a 'ground loop issue'. And no, you don't need to do anything about it.
Edit: if you want to further research this, simply repeat the procedure with the speaker already on. Then you might hear what made it wake up.
Alan S
Ocean State China
I have been using ADI-2 DAC, I said it in no.2
Thomas savage
The Watchman
uk, taunton
You deleted them, so that main post just has 8 replies now.
This is not the place for this , dragging issues from other forums (bannings and the like) to ASR such as this is not massively desirable.
If you want to do that please put it in a PM.
Product related inquiries are of course welcome.
Alan S
Ocean State China
First the ADI-2 Pro and DAC are 100% immune against ground loops or USB noise.
But you said the ADI-2 DAC is 100% immune against ground loops or USB noise.
I will try it again without power plugged in ADI-2 DAC, and add another using sicuation: OTG from Smart phone.
Alan S
Ocean State China
Sorry for that, but MC deleted my accout, it seems I got no way to reply.
I just want to discuss the issue about using ADI-2 DAC, I love this unit.
I don't want any confrontation, trust me.
Alan S
Ocean State China
The situation I mentioned is based on the premise of using a mobile phone.
Ok... And what DAC you used before with the actual setup? Anyway, I think @MC_RME already answered to your "problem".
Doesn't look like an issue to me.
Cheers.
The situation I mentioned is based on the premise of using ADI-2 DAC.
I‘ve being using it for 7 months.
Actually, the situation I mentioned happened 2 weeks ago. I didn't care about it until I see entrophy's posts.
entrophy
Europe
I don't believe your setup and mine are in any way or shape related. I have no issues with the device, the ground loops I've been struggling with I'd have with any other device, it's not particular to the ADI-2 DAC, and the device is certainly not the cause for anything other than my pleasure listening through it.
Alan S
Ocean State China
So why did you come to this thread?
Back to my first question, do you have any plans to test with Intona?
Wish you solve the ground loops problem and have much more pleasure.
MC_RME
Yes, and I explained exactly how this statement is meant. The ADI's analog outputs will not be degraded or have noise from ground loops or USB. You wil hear such effects from other devices that you connect to the ADI. To prove that the ADI's output is clean you can use a headphone or a fully isolated, floating amp (best battery driven) to check the ADI's line outputs.
As I wrote it is mostly the amps or the speakers that make such problems audible.
MC_RME
Can you use it when it's charging or only when unplugged?
If you use the 12 V output then you can only use the small mini-USB socket for charging. That works but is limited in speed (I always use the 12 V socket as charging input with the XT charger, uses 16V and some Amperes, really fast).
TalentCell makes good, similar products that can be used while charging. They provide a simple DC split cable, and charge only with 12 V, so that's why it works.
entrophy
Europe
So does this mean one could theoretically use the XT as a ADI-2 DAC PSU that's permanently attached to its charger? Is the XT line-interactive?
MC_RME
The goal here was to be fully galvanically isolated, right? Charging the battery while using it prevents that. Then there is no difference to using the ADI via its own power supply.
