Measurements of speaker cables in frequency and time domain
scott wurcer
Audio Luminary
I confess I can't recall ever doing this in 50 years of being a "hi-fi bug".
I was at a party where the host was playing the music a little loud through some old valve amps (interfering with folks "chatting up" each other). So someone just pulled the cable off, instant magic smoke.
Chrispy
PNW
Guys with goofy gear should perhaps be careful if allowing either Costanza or Seinfeld to control the stereo.....
scott wurcer
Audio Luminary
I made an attempt to measure input impedance of 5m zipcord speaker cable with open end (no termination), with a point-by-point measurement at discrete frequencies and Excel sheet. The result looks quite realistic. There is a dip near 10MHz.
Appreciate the effort, but as I have always said wire threads have only down to go. From the totally inappropriate use of Heaviside's telegrapher's equation to the knee jerk "speaker cables are not transmission lines".
pma
pma
Prague
Finally the last one. Measured input impedance of 10m coaxial speaker cable (not terminated) and corresponding oscillations of one amplifier to which this cable was connected. No magic smoke, only very hot heatsink due to cross-conduction in the output stage. This time, the amplifier was saved by its large heatsink.
Power amplifier oscillations with the measured cable. The oscillations go away if the cable is terminated by a resistor of some 47 - 200 ohm.
Edit: as my measurement method of cable impedance is simple with not enough resolution, I am adding a simulation of the 10m measured cable. Please note the enormous capacitance at the 1st impedance dip. This is the killer we speak about.
Simulation of 10m coax cable input impedance
restorer-john
Parties. Tripping over long speaker cables and pulling them out at high volume. Tube amps go pop. Some transistor amps do too.
Thomas savage
The Watchman
uk, taunton
Wow audiophiles with actual friends and a social life , the good old days , or maybe all just a dream .
Dreaming about parties where someone not only turns up the precious volume knob but the room is filled with people enjoying music and dancing rather than sitting in respectful silence in a trance like state consumed by awe for the equipment and revelling in the safety of solitude.., THEN the wires get ripped out by these ravers and the amps go bang!
Thats like the ' teeth falling out ' dream and the ' walking around school with no trousers ' dream all rolled into one .
Good job @pma , its a shame how the whole ' gotcha ' ' no you didn't ' vibe gets in the way so often.
KSTR
Berlin, Germany
Nice to see a documented real-life example here.
Another take-away we should not forget:
Preamplifier or Headphone amplifiers can and will have the exact same issues. Headphone outputs which have been "optimized" for lowest output resistance by practically omitting any series resistance are especially prone if they don't have a series decoupler for RF frequencies installed -- which one should do anway to avoid RF sneaking into the amp from the output side
Reactions: pma
scott wurcer
Audio Luminary
The number one dream is falling short on credits to graduate. Had the teeth falling out one last night.
pma
pma
Prague
Hi Klaus, I tried my headphone amplifier with 0.06 ohm output impedance when loaded with 10m of Tasker C121 cable once with no termination (open end) and secondly with the far end terminated by 50 ohm. I was measuring the 200 kHz square response at the headphone amp output, i.e. the cable input. There was nothing special happening, only that in case of the open cable there is a predictable reflection on the rising edge and some other well damped reflections. The amp has no special anti-RF elements at its output, only it was thoroughly tested with any imaginable load to ensure stability. Yes we would see reflections (in case of the open end cable) with higher amplitude if the amp was even faster.
Tasker C121 10m, open end, cable input. Cable driven from headamp with 0.06 output impedance.
Tasker C121 10m, 50 ohm terminated end, cable input. Cable driven from headamp with 0.06 output impedance.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
How was the rest of the party? I bet it got very quiet very fast...I hope the host had a sense of humor about it.
I am thinking this would make for a good SNL skit.
KSTR
Berlin, Germany
Pavel, sure there are designs that handle any amount of real or reflection-generated capacitive load without sustained oscillation, even without any R//L isolation cell.
One just cannot rely it that small signal low current amplifiers are automatically any safer than speaker level amplifiers.
Head_Unit
With class D the intention is to filter all HF anyway so it does not matter there. class-D amplifiers are bandwidth limited anyway while one can build analog amps with >100kHz bandwidths.
GBW
What are the highest bandwidth Class D amps out there? I saw one test of I forget which, bandwidth much higher than usual but not like 500k or anything. In Class AB huge bandwidth was a thing...doesn't seem so as much any more? Maybe because it typically used a lot of feedback?
Andysu
Excellent thought.
It's boring to listen to dummy loads.
How about a test of these electrical microvariations as shown in the response of a speaker in a room taken at the listening position?
that was what i was precisely thinking doing it, you know doing it, trying see if i can use the THX monitor with amp return connected to length cable connected to JBL hf horn in certain way so i can see some sort of result of interest with simply frequency sweep. the test has been on my list for few years, but i have Cats to feed and look after which is far more important than some tom holman THX cinema and dolby lab for movies or music listening, if you get the understanding of my meaning? but i see if i can make effort as this, been one of the curiosities on my mind for a while.
egellings
I think that cables may make a difference in sound, but the effect, if any, is microscopic, and I am not willing to spend a lot of money for so little benefit, if any.
Chrispy
PNW
Why is that particularly important?
Head_Unit
Why is what? The bandwidth? Or the feedback? I tend to believe designers who don't like gobs of feedback, because it's nice for steady state but music is not steady state. In some sense feedback should operate at the speed of light but in physical devices...my electrical engineering education was not in that area.
Chrispy
PNW
The bandwidth to start.
ps or perhaps the range of the bandwidth as to what is actually meaningful....
Andysu
it is possible highly possible that my Cat, Bear as been doing some chewing on the HF horn speaker cables for L C as signal SPL looks odd in the room while on the THX monitor the sound levels are equal as that is how the THX professional works with short amp return cables and the longer ones going out to the THX speakers.
Bear is a very clever Cat, i do not underestimate him. he has managed to raid the cat food box and pull out 5 packets of cat wet food, last night. so between him and Magic they have eaten and be fed late tonight. you can see Bear sniffing out the JBL 2445 CD, he is plotting. he has managed to get behind the projection screen so many times now, more times, than he has had wet cat food meals. Bear is shifty Kitty Cat.
i may have to take the projection screen down and check the HF horn L C cables, i still get good sound, only its few dB less and i have to compensate with amplifier. Bear is a very clever Snowshoe Cat.
