Measurements to show an amplifier's 'lack of juice' for specific speakers?
whazzup
Upon reading Amir's recent review of LS50 meta and its ~3 ohm impedance, this question popped up in my mind again. Can an amp's lack of juice to drive a speaker show up in sonic measurements? Do transient peaks get affected? Or do they manifest as overheating in the amp, or shutting down? Way higher distortion at high SPLs? Inadequate volume output?
Expensive high wattage amps are frequently marketed to people who 'fear' about an amplifier that cannot drive speakers properly, will be cool to see actual examples, to separate facts from myths.
Plcamp
Ottawa
It would be interesting to see how amps react to lowering load impedance, when it starts to misbehave, what does that look like?
Trying to run attached in a parallel pair I perceived an inability to handle the bass at elevated volumes using a Yamaha RXA3030 receiver, while a power amp off the preouts I perceived no problem. (No I did not blind test etc, I just tried it)
Anyway, it would be nice to know, when amps are tested at ASR, at what minimum impedance the amp misbehaves…a figure of merit?
W
whazzup
Me, I just do not have the fortune (or misfortune) of testing really low impedance speakers, so can't really imagine how an 'incompatible' amplifier - speaker combo sounds likes / measures. Yes, will be cool to see such negative examples in action.
LTig
Europe
W
whazzup
Is there a specific phenomenon that we can point to and say with certainty 'Hah! So your amp has insufficient power for your speakers!'
nemanja_t
Vienna, AUT
Sorry don't quite understand the graphs. The first doesn't seem to show any difference between 8/4/2 ohms, while the second shows rising 'distortion' with higher frequencies?
It is on “Kompatibilitätsdiagramm“ (easy german word), where they say in comment that it is very powerful and can drive speakers with a low impedance.
kschmit2
German magazine AUDIO also uses the power cube or rather stability diagram. And they have developed a metric that allows you to determine whether a loudspeaker/amplifier combo matches or not.
I have added three files with translated articles explaining what they do. Maybe @amirm can chime in on this too.
  • How AUDIO tests amplifiers.pdf
  • THIS IS WHAT THE AUDIO INDEX AND STABILITY DIAGRAM DO.pdf
  • Why simple wattage specifications are of no use to you.pdf
abdo123
Brussels, Belgium
yes, it's when the waveform looks distorted on a oscilloscope, otherwise you just have to rely on your ears and tea leaf reading of the often lacking amplifier specifications of the manufacturer.
nemanja_t
Vienna, AUT
It looks like this:
Plcamp
Ottawa
I like from the article this kind of plot…seems informative. Looks to me this could differentiate amps for anyone needing to drive complex low impedance loads.
solderdude
The Neitherlands
Indeed the electrical phase (differs from acoustical one) is also of importance.
Would have liked to have seen +/- 90 degrees for the current opposite the output voltage.
solderdude
The Neitherlands
Here you can see electrical phase issues explained graphically.
There is a difference between capacitive and inductive loads.
Inductive load:
At 90 degree angle between voltage and current the amp supplies a voltage but no current. 90 degrees later the amplifier does not supply a voltage but the amp has to provide the maximum current. 45 degrees later, as an example the output voltage is negative but the current is still positive.
For capacitive loads a similar thing happens but in the other 'direction'.
Acoustical phase rotates many times depending on distance from woofer and tweeter to the ear, distance etc.
Plcamp
Ottawa
sixty degrees should cover the bases…ninety would imitate powering a speaker with its drivers short circuited!
Then again, it would also be a feature of merit to survive output short circuits…if it were not dangerous to try it, amps really should withstand dead shorts.
solderdude
The Neitherlands
Not really as with a short the current and voltage would have the same value.
The phase can rotate 90 degrees but the current would still be limited by the ohmic part of the speakers.
But sure... most speakers will not go +/-90 degrees but remain below +/- 60 degrees electrically but when testing amps why not see how they handle this ?
