Meizu Mblu Lifeme Pro Portable DAC/Amp Review
Rate this DAC & HP Amp
    Votes: 5 3.4%
    Votes: 32 21.9%
    Votes: 88 60.3%
    Votes: 21 14.4%
This is a review, listening test and measurements of the Meizu Mblu Lifeme portable DAC and headphone amplifier. It is on kind loan from a member and costs US $23.
Not much to say about the form factor other than it terminates in 3.5mm unbalanced headphone connection.
If you are not familiar with these DAC measurements please watch this video.
Meizu Mblu Lifeme Measurements
Let's start with our dashboard:
Meizu Mblu Lifeme DAC Portable Headphone Amplifier Adapter USB-C Measurement.png
SINAD of nearly 100 dB is quite good for a dongle, landing it in the competent category regardless of type and cost:
I do wish it had more than 1.5 volts out (minimum of 2 volts is my target). I have started to measure power consumption. Current consumption (at 5 volts) is 27 milliamps at idle and rose to 32 ma at 1 volt output into 600 ohm load.
Jitter shows a lot of random clock jitter (the large "skirt" around our 12 kHz tone):
Meizu Mblu Lifeme DAC Portable Headphone Amplifier Adapter USB-C Jitter Measurement.png
Dynamic range is not the best we have seen in a dongle but nevertheless, good:
Meizu Mblu Lifeme DAC Portable Headphone Amplifier Adapter USB-C DNR Measurement.png
Multitone lands in the same category:
Meizu Mblu Lifeme DAC Portable Headphone Amplifier Adapter USB-C Multitone Measurement.png
Power is just about everything so let's measure that starting with 300 ohm:
Meizu Mblu Lifeme DAC Portable Headphone Amplifier Adapter USB-C Power 300 ohm Measurement.png
Seems that we are gain limited in the way there is no clipping. I think this leaves money on the table as otherwise would we get more power. And help with more quiet music tracks. Same is going on with 32 ohm load:
Meizu Mblu Lifeme DAC Portable Headphone Amplifier Adapter USB-C Power 32 ohm Measurement.png
Here is how that compares to its competitors:
Meizu Mblu Lifeme Listening Tests
I started with my everyday Dan Clark Stealth headphone. On tracks that had high levels, the performance was surprisingly acceptable with excellent fidelity. But on other tracks with lower peaks, there just wasn't that much volume there and would only be good for quiet listening. Switching to Sennheiser HD650 we had at least double the volume which made it excellent on loud tracks and good on low amplitude tracks.
The performance of the Lifeme dongle is somewhat variable. On most of the tests it does quite well. My only wish would have been for 2 volt output instead of 1.5. That would have made it a huge winner given its price. As is, it is good for average to better than average headphone/IEM sensitivity.
I am going to recommend the Meizu Mblu Lifeme headphone adapter and DAC.
martijn86
The Netherlands
Thanks for the review Amir. The Power comparison's with competitors is really nice. Do you think we can get a similar comparison with competitors for Sinad and Sinad at 50 millivolt?
Unfortunately due to an 'upgrade' in smartphone, I'm now in the market for a dongle.
Toni Mas
I am currently using a similar device for summertime outdoor hassle free use with sensitive IEMs , and wonder if an upgrade to something "better" like a Tanchjim Space, Moodrop Dawn, etc... would bring any significant and audible improvement. Not quite sure...
JSmith
Algol Perseus
Unfortunately I packed the thing already so I can't run more tests.
Mulder
Gothenburg, Sweden
I think this could be ideal in combination with a separate all analog headphone amplifier, ie as a converter between a phone and a headphone amp.
Jimbob54
Cheap as chips and reasonable performance too.
This uses the Cirrus Logic CS43131 DAC with integrated headphone driver, datasheet;
Some teardown pics;
JSmith
Perhaps a different model but I dont think this is a 43131 device (the original Meizu Hifi Pro and non pro were)
https://www.meizuworld.com/original-meizu-hifi-dac-headphone-amplifier-pro-1.html says
High Performance DAC Chip, Pure HiFi Sound Quality
Using American Conexant CX31993 high-performance DAC decoding chip, the SNR is as high as 124dB, and the DNR is up to 111dB. Support 32bit/384kHz PCM decoding output max, lossless music HiFi enjoyment.
Independent Amplifer Two-Stage Operational,Releases the Potential
Powered by American Maxim MAX97220 secondary operate amplifier chip, After the double supporting of DAC chip and AMP chip,Give your professional headphones a powerful enough drive for a wider sound field and excellent sound quality resolution.
MCH
Some teardown pics;
JSmith
I think those pics are of the unobtainable Meizu hifi pro.
It would be interesting to see what are the differences with this one though...
Jimbob54
See my post above- I agree
Not that it matters what DAC chip really- the performance at the output is what matters. I think for my money I would spend a little more and get the Tanchjim Space lite though. Admittedly not seen measurements but can be had for around $30.
IAtaman
Thanks for that. I love reading datasheets.
Chips specs says 5 mW into 600ohms which requires close to 1.8V but Amir measured 1.45V. 7.1mW at 300 ohm adds up to ca 1.45V. I guess they have not used the charge pump then?
Also interestingly 57 mW measured for 33 ohm is actually better than chip's specs (assuming measurement is per channel as usual) which says 30 mW per channel.
Or maybe there is a revision of this chip that optimizes for higher power at lower impedance?
Jimbob54
Its not a 43131 device..... (see couple of posts above this )
JSmith
Algol Perseus
Thanks, yes you're correct. My fault for posting whilst busy with other things, clearly I've not paid enough attention, apologies all.
JSmith
Jimbob54
JSmith
Easily done when they all look the same and have some combination of meizu , hifi and pro in the names !
milosz
Chicago
$23? When you buy it, do they ask "You want fries with that?"
Respectable performance and low, low price. But wait! There's More! Light weight, small size and woven cover on the cable.
Matias
São Paulo, Brazil
Very unfortunate that they discontinued the 43131 ones to keep this in line... :(
AdamG
Moderator
Reality
For the Price of Two Coffees and a Danish. Incredible what you get here. Yeah it’s not taking the lead on your charts, but it’s competent and gets the job done for a dongle that looks like an adapter. I continue to be amazed by the kit we can obtain on the cheap that only a few years ago would be a budget breaker.
Everyone should have a basket of these Dongles just lying around for quick out the door Audio solutions. I use my dongles mostly in my Truck and Bike. When I do get the rare opportunity to ride. Definitely improves the sound rather than direct from the Phone. Thanks again Amir. Entry level kit like this is how we grow the next generation of Audio Nerds. :cool:
Matias
São Paulo, Brazil
