Meizu Mblu Lifeme Pro Portable DAC/Amp Review
Rate this DAC & HP Amp
    Votes: 5 3.4%
    Votes: 32 21.9%
    Votes: 88 60.3%
    Votes: 21 14.4%
CarbonMakerU
Knoxville
I think I did not relay my meaning well.
A stiff heatshrunk cable, has more of a leverage. If tugged, the extra lever effect, magnifies the effect to damage the port.
I make my own USB cables, and because of this, I make the USB-C plug (in my case), as tiny as possible, because even a tall plug, has plenty of lever effect.
Could you negate the mechanical advantage of the additional potentially damaging leverage by merely heat shrinking the area around the connections/wire and leave the center flexible? The connections would still be supported hopefully providing longevity.
Ken Tajalli
London UK
Yes, use a thin glue-lined short tubes at ends and leave the centre section exposed.
firestart3r
Late to the party but... does the microphone work like on the Apple dongle ?
I'm looking for a replacement I can use to do phone calls...
Warcsi
Hungary
In the Review Index this is posted as ADC. Mistakenly, I suppose.
