Meze 109 Pro
Peterinvan
I was in my favourite store in Vancouver, BC, to pick up a new FiiO KA3 dongle for my iPhone. Here’s a plug:
Headphonebar.com
However, this is a candy store for audiophiles, and you can listen to a good selection of TOTL headphones. I had been reading the reports on the new Meze 109 Pro, so I had to try them.
I was seduced by the look and feel of the new Meze 109. The best piece of industrial design I have seen in a long time. The self adjusting headband and velvet ear pads are really comfortable. Function + form.
And the music! I bought them after comparing to my Grado SR325, and the in store demo models of the Focal Clear Mg, and the Grado RSX1.
When I got home and opened my new pair, they sounded a bit hot in the higher frequencies, and the bass below 100Hz was a bit veiled or “muddy”.
So I put a long Tidal playlist on repeat, with bass heavy tracks.
After 50 hours, I am pleased to report that the top end is tamed and the bass is more realistic. BTW, I listen to music with more acoustic instruments, and look for that “woody” sound of a close miked double bass.
The only down side to report is that these headphones are not suited for multitasking (working, reading, doom scrolling, swiping, etc.) because the music is so engaging that I stop whatever else I am doing and listen to the music. The soundstage and pinpoint isolation of the instruments is a pleasure. The old cliche about hearing things for the first time applies.
The sub-bass reminds me of the day I added my SVS1000 sub to my KEF LS50W speakers! I do not get this sub-bass feeling from my other headphones (e.g. LCD-XC).
Read the other reviews on line. I mostly concur with other’s observations, but it would be nice to see them reviewed on this Forum with measurements.
Peterinvan
Peterinvan
I find the 109s to be quite different with different DACs
FiiO M11 Pro is much warmer than my Cayin RU6 for example. On Easy Money (Ricky Lee Jones), the RU6 presents the bass with a nice woody tone, with slightly hot vocals and treble. The M11 Pro is warmer all around. The bass is a bit under a blanket.
My Centrance M8 (AKM4493?) is even warmer. No bass distrortion. No sibilance.
The hot treble on the 109s diminished noticeably after about 50 hours.
I use Tidal for most of my listening, so no EQ available.
Ilkless
Singapore
Some measurements from Brent Butterworth:
Measurements from @Resolve :
Broad agreement, though Brent measured a 6kHz dip like Resolve's from only one channel but not the other. I had been looking out for these because I adore Meze's industrial design but the Empyrean is difficult to justify even used.
Unfortunately I have never been a fan of headphones with lesser/no ear gain from 1-2kHz. This is something quite common in high-end headphones like Hifiman, some ZMF and some others and encouraged by many tweako gear fetishist types on other forums. IME I strongly prefer FR tracking Harman from 1-2kHz, then peaking at 3kHz, but 1.5dB or so below Harman, gradually closing the gap until the curve intersects again around the last octave. And a bass shelf that is about 2dB below Harman, which gives good thump without excess masking of the lower mids, and also helps to compensate for leakage somewhat. The 9kHz dip is mostly innocuous and a common measurement artefact, so it doesn't concern me. My preferred and perceptually accurate curve is drawn (with MS paint) in green for reference. Some headphones that come decently close are the Empyrean, ZMF Auteur Classic, Audeze MM-500/LCD-5 with EQ.
audiobasha
My left side quit the day I got them after listening for about 5 hours. Pity as I really liked them.
Interesting. The left side was also what failed on my first pair. It started to buzz badly. I got them replaced. I hope the new pair lasts. Never heard of any quality issues on other meze models - hope they sort this out.
BigKev2023
When I first put them on I kind of noticed a slight imbalance in the left side which eventually went away but later the left side just quit altogether. They are sending me a new pair. I'll be putting them through their paces hoping for a better result this time as I actually thought these could be my endgame headphones.
audiobasha
They sent me a new pair as well. So far so good. Hope these new pairs last :)
NDRQ
Can you just stop this audiophool nonsense?
_Piotr
Cracow
I've just gotten mine today. I like the lows and the sound stage, but the highs can be painful. Will spend some time with them to see if I can get over it
I'm running them with SMSL SH-9/SU-9
Peterinvan
Peterinvan
I would give them 100 hours of break-in for the drivers to reach optimum flexibility.
FrantzM
Here we go again?
:D
After the break in, the sound will be soft, with organic highs and natural mid and the reproduction will be more fleshed out and ...
Come on Man! You should know where you are.. You've been here for a while... ;)
Peace.
Peterinvan
Peterinvan
Here we go again?
:D
Peace.
The drivers are mechanical devices with flexible material.
_thelaughingman
"It is therefore concluded that breaking-in headphones for consumers is not necessary, and won't result in any noticeable change in their sound. The user reports regarding the existence of the break-in phenomena can be explained as a psychoacoustic effect caused by the fact that human hearing is very good at adapting to new sounds.” - Rtings.com 2018
_Piotr
Cracow
I'm returning mine. After 7 days of trying to get used to them, I still can't get over t the's highs, which are too painful for me. Unfortunately, I just couldn't find a good EQ settings to fix it.
Draculr
I just got mine, love them so far. I was looking for an upgrade from the HD600 that still had natural vocals. The various planar headphones I tried just didn't do it for me, they all seem to give vocals a much more thin presentation. I didn't want to mess with the focal clear even though it's cheap now due to various issues (non-replaceable beige suede headband, come on man).
After auditioning against the HD600 they definitely have a lot better imaging and soundstage, a lot more sub bass and the vocals and timbre can go toe to toe so I think for the most part I can say they're a real upgrade without losing what makes the HD600 special.
Peterinvan
Peterinvan
Congrats.
In my experience the drivers achieve optimum flexibility at about 100 hours.
Draculr
At the moment I've got a very, very slight EQ to bring the treble down and after that I can safely say they beat out the HD600 on vocals. I just used the last two EQ filters from oratory1990.
I'm starting to agree with the folk who say I can just stop looking for other audio gear and just enjoy these headphones, they are that good!
