Millivolt Meter Recommendation for Audio
carlob
Roma, Italy
Wide range supplies are common for low power devices as their disadvantage is that you have to dimension all the components for the worst case voltage and current. Past 70/100W you use a doubler circuit.
carlob
Roma, Italy
Anyways the modern way is to use a switching regulator that can operate from 110VAC to 220VAC, which is the IC in your circuit I think.
Bridge rectifier -> 400V caps -> TNY178PN - didn't check the datasheet.
mansr
Hampshire
Getting back to the topic, I hooked up an iFi DAC and let it run for a few hours. Ever a source of surprising behaviours, it did not fail to deliver:
watchnerd
watchnerd
Seattle Area, USA
OK.....so what is the output voltage of your Revox when playing the 1kHz zero reference tone? I'm taking bets on how close it is before tweaking it. :cool:
So I'm not sure what to make of these results.
First, a DC battery test with a D cell battery. The packaging says 1.5V; I have no idea how loose D cell battery tolerances are.
6.7% off spec. Is it the meter or the battery? No idea...
Moving on the to the calibration tape.
The default reference fluxivity for the PR99 MK II is 250 nWB/m = 0 VU
So it's expected that a 355 nWb/m tape gives this result for a 1 kHz tone.
Looks like the left channel is about 0.5 dB too low.
When measuring the 1 kHz test tone at 355 nWb/m = +3 VU, we get this output at the XLR line out jacks, in CAL (calibrated / fixed) mode:
So the next part is where my math is making me less than confident.
At 0 VU on the meter, the output should be +4 dBU at the XLR jacks, which = 1.23 VAC, I think.
So +3 dB on the VU meter should be.....+7 dBU, which = 2.24 VAC??
Is that math correct?
If so, either the output is a little hot, the meter is off by .01V, or my measuring is doing something wrong.
Or my math is wrong.
MakeMineVinyl
Santa Fe, NM
I don't know if your machine has a VU meter calibration adjustment. If it does, you need to get your meters to equal 1.23V at "0 VU". After that, adjust the playback gain so that the meters read +3 if you want 250nWb operating level or zero if you want +6. At any rate, I always thought a "D" cell was 1.56VDC, but that was back in the days of old skool Ray-O-Vac batteries. :oops:
Doodski
For a new 1.5V battery they will measure a little higher like you see there. The resistance across the battery should be low and as it discharges the resistance will increase.
watchnerd
watchnerd
Seattle Area, USA
It does have VU calibration.
And it is currently reading +3 on a 355 nWB tape = 0 VU @ 250 nWB (more or less).
I think, given the tape is pegging at +3 dB on the VU meter, the current VAC reading at the line-out is about right, based on conversion math.
watchnerd
watchnerd
Seattle Area, USA
It's fresh from the package. Probably sitting in a drawer for a year.
MakeMineVinyl
Santa Fe, NM
Inject a 1kHz sine wave into the line input and adjust the voltage until the line output voltage of the machine is 1.23 VAC (don't use the calibration tape for this). Then adjust the meter calibration for 0VU on the internal VU meters. From then on, 0VU will equal 1.23V. After that, you can throw away your multi-meter. ;)
watchnerd
watchnerd
Seattle Area, USA
What voltage peak to peak from the signal generator?
MakeMineVinyl
Santa Fe, NM
It doesn't matter. Just output any level and adjust the record input level until you get 1.23V from both line outs of the machine. Then adjust the VU meter calibration pots so that they are at "0". Unless your machine is very weird, this should work. Then you can proceed with calibrating playback level using your tape. You don't need your multi-meter after getting your VU meters to read "0" at 1.23V from the line outs.
My Ampex machine is easy this way; there's no way to adjust the VU meters, so thay must be dead accurate. :p
watchnerd
watchnerd
Seattle Area, USA
It doesn't matter. Just output any level and adjust the record input level until you get 1.23V from the line outs of the machine. Then adjust the VU meter calibration pots so that they are at "0". Unless your machine is very weird, this should work. Then you can proceed with calibrating playback level using your tape.
Well, it's weird.
See post #869.
You're supposed to do that step before you mess with the VU meters.
You adjust internal trim pots (not the external ones for the VU meters) and measure at the monitor out, not the line out.
MakeMineVinyl
Santa Fe, NM
Try it the way I described. The manual might want to do another way, but the bottom line is that you want the VU meters to read "0" when the line outs are putting out 1.23V. I guess I'm like the car mechanic who has tuned 76,000,000 engines by feel - don't need no fucking manuals. o_O
restorer-john
Well, it's weird.
See post #869.
You are 100% correct. Input levels, playback levels and final stage levels are all adjusted before messing with any VU trims.
