Millivolt Meter Recommendation for Audio
March Audio
Albany Western Australia
Oh another thought is record a 1kHz sine signal at 0dB on the VU meters, play it back and see what you get on the VU and voltage out. We know it should be about 1.23 volts and this would tell us if it's close or way out (as the +2.74dB 355nW signal at 2.25V would imply)
sergeauckland
Suffolk UK
I have a couple of friends with the reel to reel mania, easy to be ripped off if you are not an expert.
Have you seen this: http://mrltapes.com/choo&u.pdf
Dear me, that takes me back!
My first job after University was working with tape, designing high speed tape duplicator electronics and making secondary test tapes for calibration of the duplicators. I used to be able to recite the spoken introductions to Ampex and BASF test tapes, which were the ones we used....Badische Analin und Soda Fabrik Ah Geh. About the only time one heard BASF spoken out fully.
I could also mentally convert the NAB and IEC standards so could use a different test tape to whatever the EQ was. Happy Days! Long lost skills now certainly for me, although I've recently been playing with a 50 year old Ferrograph and getting some decent results.
S
watchnerd
watchnerd
Seattle Area, USA
The narrator on the MRL tape has an American English accent from a different era.
He sounds like an old time news anchor, like Walter Cronkite.
mansr
Hampshire
This other DAC doesn't have the erratic output level of the iFi:
watchnerd
watchnerd
Seattle Area, USA
That's more what I would expect over a two hour period.
I can see the voltage being unstable for the first 5 min while things heat up, or maybe even 15, but the hours of the iFi is puzzling.
It should have reached thermal homeostasis much earlier.
mansr
Hampshire
You'd think so. The meter manual specifies a 30-minute warm-up, as is typical for lab gear. I'll have to try it again and see if the behaviour recurs.
restorer-john
One of the first things I could recite as a very young child was the spoken introductions on my father's test record! I can still remember them all, in order with perfect timing- both sides. Especially the tracking tests where a stylus would jump out of the groove and replay the same piece. I tell him my HiFi/electronics life journey was imprinted into me by that test record. ;)
mansr
Hampshire
What happens if you leave it going for 24 hrs?
Will it deteriorate further? Start oscillating?
Let's find out.
For the first 10 hours or so, it did this:
Then this happened:
Followed by this:
I think the volume control may have gone mad. It's a rather idiotic design, after all.
Audio1Man
Then he's got to keep an ancient PC (286/386/486) alive for the System One! (ISA slots or a really expensive USB 1.0 breakout box IIRC) Trust me, keeping a PC alive that wanted to go to PC heaven 20 years ago gets rather tiring.
I Service & Repair older AP Systems, I also have APIB USB ADAPTERS so they can be run with USB under XP, Vista, Win7, 8 & 10 No old PC's NEEDED.
[email protected] or http://sound-logic-la.com/
Duke
restorer-john
Jack B
If you don't mind the idea of buying something that is no longer supported by the mfr., an excellent meter available on the used market is the Fluke 8060A. 4 1/2 digits, flat frequency response to something like 50 Khz, a dB scale, and the manual is still available on line for free. Audio performance better than any subsequent Fluke handhelds, as far as I know.
