Most aesthetically pleasing amplifiers
Ingenieur
PA
mhardy6647
Timcognito
NorCal
MakeMineVinyl
Santa Fe, NM
TheBatsEar
Germany
Another silver Yamaha amp, or rather receiver. These can be had for just 200€ sometimes.
The design is very Yamaha. I think they did everything right with this device and i really hope they stick to it in the future.
This one is the R-S700, it has the same power amplifier section as the A-S700, A-S701 and A-S801. But on top it has a rec selector and preamp and poweramp can be split. This is a welcome feature if you want to loop in a MiniDSP or other EQ. None of the A-S has pre-out/main-in, not even the A-S1200 (it's there, but you can not loop in a MiniDSP). Also, the remote has a learning feature and can switch channels on my Phillips TV.
So, if you want a cheap and very good looking, beefy and fully featured preamp, poweramp or integrated amp, this is the sweet spot right now.
Excuse the Kraftwerk CD. It's just good tunes.:cool:
Timcognito
NorCal
Yes the stuff from late '70s still sounds and looks great with those silver face plate, also.
Timcognito
NorCal
TheBatsEar
Germany
Sadyl, those go for a lot more than 200€ now, unless you know how to repair a broken one (usually, replace the caps, relays, potis and set the bias).
The R-S700 isn't that old and should be good for another 10 years or so without maintenance.
Timcognito
NorCal
I agree the prices have gone up. My Dads 1979 Cr-240 is still going strong at my sons apartment.
