Bjorn
Norway
Here's are the Bayz omni speakers from 2018 at a show in Germany that I visited. Built in super light carbon material.
Killingbeans
Bjerringbro, Denmark.
A bit of a love and hate shape I think. One could make it straight as well, but it would either serious DSP capability or lots of amps with fine gain adjustment. It would bring the cost up.
Of perhaps you would find them different in real life. This is the only type of speaker I've received good feedback from all women who have seen it.
What's going on in that picture? Looks like the base plates broke off, and somebody haphazardly glued them back on with construction adhesive? o_O
JimA84
Dayton Audio used to make some curved line source speakers with a huge number of small, long excursion drivers of around 2-1/2 inch or so. EPIQUE CBT24
G|force
Pioneer , CA
I believe the 4350 and 4355 used the 2405 tweeter, which is a radial design. The wedge in the middle of the slot is actually a nut which screws down the center of the diaphragm. Think ring shaped. :)
dagfinn
Soniclife
"Acoustic Lens Family
Within certain Iimits, the acoustic lens can be made to func-
tion as an optical lens to achieve any desired high frequency
distribution pattern. In JBL lens systems, the lens is attached
to a short horn device so that the wavefront approaching
the lens is a properly constituted plane wave".
Thanks, I get what it's doing now. Is there a modern approach that achieves the same wide result?
Newman
Classic Voigt
