Motu M2 Review (Audio Interface)
Wombat
Australia
I have a feeling this is probably due to the pandemic and supply issues, along with demand outstripping supply. So they're probably pushing out subpar cosmetic QC that they'd normally catch out of necessity.
Possibly some returns sold as new by the seller? Possibly not, too.
I have had factory seconds and factory refurbs that from the packaging into the contents I could swear were new unopened. Then I have had new unopened that looked repacked/disturbed along the way.
phoenixsong
I did think the dac section sounded excellent when I heard it- clearly better than my OL DAC's. Bit disappointed with the ADC's performance in this review, but still getting lots out of this device so I can't complain
3125b
Germany
So how much worst the M2 will perform vs the M4 purely as DAC+ volume control when connected to active studio monitors ?
Looks to be exactly the same.
ADC is a bit worse (though still transparent) and it has less functionality.
Doodski
It depends on the staff handling the product. Some staff open, unpack and repack veryyy carefully and others are total slobs about it. When I worked for a mass merchandiser we had issues with new product mysteriously being repacked very shoddily and nobody to answer for that. We finally had to lock the warehouse door to keep people out with strict orders to the warehouse staff not to let anybody in so that lazy sneaky peeps did not have access to product.
Tater Tot
What’s the output impedance of headphone out?
The lack of extra power for lower ohm load is weird.
artburda
Switzerland
How is it possible that power vs distortion for 33 ohm and 300 ohm is cleaner with the M2 than with the M4? (Clearly visible by looking at the lines in the graphs)
M4:
M2:
daftcombo
This and the very similar Scarlett 2i2 are both good. How stable are the drivers?
AudioSceptic
Northampton, UK
I must say it is crazy give how good the performance and how much money it costs. The filter is the cleanest one on ASR and plus all those functionality. Thanks Amir for measuring this and make me interested in Motu now. BTW is there an other measurements for headphone out like impedence?
Is the filter just one built-in to the ESS DAC or have Motu added their own?
trl
King of Mods
Iasi, RO
On TRS outputs seem to be pretty similar, although the tests were performed at different output voltages, but I'm sure they will sound identical on your speakers. Feel free to compare the graphs by yourself.
Tks
M2 with a more sensible filter than M4, odd..
Surprised to see the ESS hump still around these days.
Good overall package for sure though.
Promit
The M2 is my interface/DAC of choice, replaced a Focusrite some time back. I get to drive my sub and Adam T7Vs off the XLR outs, and run my Axe Fx into the XLR ins. It's been great and I love the step of real VU meters over the light up rings.
Omid
Amir, If you still have the unit and have the time, can you please run a SINAD on the mic input with gain turned up to max? Just curious about the performance of the mic amp for conducting measurements for DSP room corrections.
Music1969
I have Focusrite Scarlett 18i20 Gen3
All Gen3 use same driver and for me it has always been rock solid reliable
I need it to be, doing 6 channel DSP crossover and room EQ . Using Win10 ASIO driver
Blumlein 88
Yes, whenever Amir does recording interfaces I wish he would test the microphone inputs too.
Joachim Herbert
Munich, Germany
Not sure every designer is aware of it. Acutally I think most could not care lesse. ASR seems the only place this is noted.
Χ Ξ Σ
UTC-8
Weird, that is not my words. Not sure how did another member's words mix up with my username.
daftcombo
I have been using the 2i4 2nd Gen daily for almost two years. I like that unit very much as a DAC, for vinyl rip through the ADC, headphones occasionnal listening... But have had lots of drivers issues and need a lot of buffer to play seemlessly.
I was aksing to myself: would I get another one if mine was dead, or get a MOTU?
P_M
San Francisco Bay Area, CA
Would be awesome to see an IMD test for the ADC also.
