bequietjk
- Joined
- Jan 4, 2019
- Messages
- 462
- Likes
- 475
RME ADI-2 Pro V2.
If you measure this im going to have to turn a cheek.
*A guy that owns an M2
RME ADI-2 Pro V2.
I have a feeling this is probably due to the pandemic and supply issues, along with demand outstripping supply. So they're probably pushing out subpar cosmetic QC that they'd normally catch out of necessity.
Looks to be exactly the same.So how much worst the M2 will perform vs the M4 purely as DAC+ volume control when connected to active studio monitors ?
It depends on the staff handling the product. Some staff open, unpack and repack veryyy carefully and others are total slobs about it. When I worked for a mass merchandiser we had issues with new product mysteriously being repacked very shoddily and nobody to answer for that. We finally had to lock the warehouse door to keep people out with strict orders to the warehouse staff not to let anybody in so that lazy sneaky peeps did not have access to product.Possibly some returns sold as new by the seller? Possibly not, too.
I have had factory seconds and factory refurbs that from the packaging into the contents I could swear were new unopened. Then I have had new unopened that looked repacked/disturbed along the way.
Is the filter just one built-in to the ESS DAC or have Motu added their own?I must say it is crazy give how good the performance and how much money it costs. The filter is the cleanest one on ASR and plus all those functionality. Thanks Amir for measuring this and make me interested in Motu now. BTW is there an other measurements for headphone out like impedence?
On TRS outputs seem to be pretty similar, although the tests were performed at different output voltages, but I'm sure they will sound identical on your speakers. Feel free to compare the graphs by yourself.So how much worst the M2 will perform vs the M4 purely as DAC+ volume control when connected to active studio monitors ?
This and the very similar Scarlett 2i2 are both good. How stable are the drivers?
Yes, whenever Amir does recording interfaces I wish he would test the microphone inputs too.Amir, If you still have the unit and have the time, can you please run a SINAD on the mic input with gain turned up to max? Just curious about the performance of the mic amp for conducting measurements for DSP room corrections.
Surprised to see the ESS hump still around these days.
I have been using the 2i4 2nd Gen daily for almost two years. I like that unit very much as a DAC, for vinyl rip through the ADC, headphones occasionnal listening... But have had lots of drivers issues and need a lot of buffer to play seemlessly.I have Focusrite Scarlett 18i20 Gen3
All Gen3 use same driver and for me it has always been rock solid reliable
I need it to be, doing 6 channel DSP crossover and room EQ . Using Win10 ASIO driver
