MQA Deep Dive - I published music on tidal to test MQA
Status
Not open for further replies.
Oukkidoukki
Just casually testing cobuz with my poor mans hd 800 (k702) , poormans amp 02 jds in my poor mans home.....sounds pretty good!
Grooved
It is really sad that we are having to second-guess whether these major music streaming services are truly bit-perfect and lossless. If Amazon HD is not bit-perfect for at least 16bit/44kHz content (still no empirical data), Canadians have literally no other options left now that Tidal has started compromising its Hi-Fi content. I spent the entire morning trying to use various VPN tools to register for Qobuz with no success. I got to the stage where it asked for payment info and then it refused both my credit card and PayPal.
First World problems, I know.
Maybe your best possibility would be to create a multi-currencies account with something like Wise (Transferwise) and get their card.
I once used it and enter the bank address provided with each currency and it was accepted. The card was recognized in the local currency, and the address was accepted. It's all free to get an account and I think the card is free until this month. I use it with their business account but you can create a personal account only.
I read that "turning on the MQA light" was just a flag so theoretically non MQA content could turn the light on and MQA content could play leaving the light off. My paranoid question is how can I tell if Qobuz is actually streaming 44/13 bit MQA content with the light off rather than true 44/16 content. Can the files to analyzed somehow to tell? I am suspicious that with the Warner music library that is what may be happening.
Do yo have a track on which you are suspicious ? And do you know the 2L track supposed to be a MQA on Qobuz ?
GoldenOne
GoldenOne
Not Active
A video version of this post is available here:
Introduction
MQA is a proprietary music compression solution that uses the FLAC container. It requires a license fee for manufacturers to implement it, and due to the lack of transparency from MQA, there has been relatively little conclusive information about exactly HOW it works. (Or IF it works).
I was frustrated with this, and despite the fact that there is excellent testing that has been done by Archimago, MansR, John Atkinson and others, I wanted to get something done quite conclusively, to get some files encoded in MQA and published on Tidal, so that I could compare them to the original masters.
My tracks were published using MQA's recommended method for indie artists. And the tracks, including original masters, MQA encoded 44.1khz versions, and tidal 'hifi' versions are available here: https://mega.nz/file/S6AFQYQS#H5wK-6m6V7smG-TKdxxRVEfTOVE8vgxVv7Tiq56FVjQ
Feel free to have a look at them and poke around yourself.
I've included analog recordings of a "Full Decode", outputting from an ifi iDSD Diablo into an RME ADI-2 Pro FS R ADC at 24 bit 768khz.
If you have 40 minutes spare, I would recommend watching the video as I explain a little more about the context surrounding some of these tests, MQA's response, and other things.
But if you just want the hard data, read on.
I did contact MQA prior to posting the video (and this post), but their reaction was to immediately have my tracks removed from Tidal, and to have the publisher remove all my content.
I posted here, APS and Head-Fi to encourage people to search for and confirm the existence of the tracks, so that MQA could not later claim they never existed.
Only after I made these posts did I receive an email response which i'll discuss at the end of this post.
Test components
I wanted to get test files such as an impulse response, white noise and -60dB dynamic range test sine encoded in MQA.
When I attempted to simply submit these alone as "Alternative Electronic" tracks, I was told by the publisher that "The MQA Encoder was unable to encode the file".
I therefore assume that MQA has detection in place to ensure no one gets any test files encoded.
To my knowledge the Chord M-Scaler has something similar for impulse response detection.
So, I put together a basic acoustic track, and hid the impulse response, white noise, square wave, 32 tone test and full RightMark Audio Analyzer test sequence inside it with a few seconds of digital silence either side. As well as the musical content itself of course.
I did publish both dithered and non-dithered versions, and both exhibited the same issues that i'm about to show.
For the 88.2khz test I included a few changes.
- Test components such as impulse, whitenoise, RMAA test sequence were adjusted for 88.2khz, so white noise goes up to 44.1khz and impulse is one 88.2khz sample etc
- Added a 35khz+40khz sine, to test if this is removed or retained during MQA Unfolding
- Reduced duration of digital silence at end of file
I did also create another 88.2khz track with the amount of ultrasonic content drastically reduced, and no white noise. But MQA removed all of my content from Tidal before this went live and so I was not able to test this.
Additionally, i'd like to clarify:
This is NOT an attack on any manufacturer that has incorporated MQA into their products.. This post is intended to inform you about the issues and false claims surrounding MQA. There are a huge number of fantastic products which happen to have MQA support. This is about MQA specifically, not the products that support it.
Comparing the 44.1khz files:
The first thing I wanted to test was whether the 44.1khz master track was lossless, both on other platforms such as Deezer, and on Tidal.
For this I used the tool 'DeltaWave' on the Original 44.1khz master and Deezer version. Absolutely bitperfect. Same file.
However the Tidal version was NOT the same
Immediately it was clear that there was more high-frequency noise, and the MQA version actually generated clipping warnings (see top of image) whereas the original did not. This also seemed to be a common theme among commercial tracks I tested. MQA was consistently louder and would clip more often.
I don't actually think this is due to necessarily an overall volume increase though, but simply that even in the 44.1khz file, MQA adds what looks like minimum phase resampling artifacts. This causes some portions of the track to appear louder, transients to 'overshoot' and be more likely to clip.
This is the impulse test in the original file, one sample with digital silence surrounding it (note adobe audition adds the interpolation line hence the squiggle, but you can see the samples):
This was that same portion in the MQA 44.1khz file (time-scale is kept the same):
Not only is it showing minimum phase, and non-linear ringing characteristics, the ringing also does not decay linearly.
Square wave also looked....odd
Original:
MQA 44.1khz:
Lastly, the high frequency noise was not simply dither. It does look like MQA is adding its own dithering, as in the 24 bit un-dithered file I provided the noise floor had been raised, even in silent portions of the tracks.
However the noise rapidly increases in the higher frequency area.
This is a -60dB 1khz sine, used for testing dynamic range. But the same noise pattern exists even in areas of the track that SHOULD be silent.
Original:
MQA 44.1khz:
So no, the 44.1khz file is NOT lossless at all. And shows evidence of compression/resampling, even though the file sample rate has not changed. (Similar effects are seen when compressing to MP3).
But, MQA offers no file size advantage here. In fact the 44.1khz MQA file is a few megabytes bigger than the FLAC master I provided (WAV is bigger obviously).
The 88.2khz file
Next, let's look at the 88.2khz file.
The version on deezer had simply been resampled to 44.1khz. Any >22.05khz content was just removed, and the impulse response showed the resampling but was phase linear. So not lossless, but then Deezer doesn't offer native HiRes, and so a resampled but otherwise fine version is what we'd expect.
The MQA version was.....well a picture says a thousand words:
There is a HUGE amount of high-frequency noise. So much so that for our dynamic range test this is now actually 20dB ABOVE the signal level, with a further increase in noise around the fundamental as well.
The impulse response was near impossible to make out from the noise so isn't shown in this post, but files are linked in the intro if you want to have a look yourselves.
Additionally, any >22.05khz content had been aliased back down into the audible band at fairly audible levels. With my 35khz and 40khz sines now at 4.1khz and 9.1khz. And you can quite clearly hear them being played. They are absolutely NOT 'below the noise floor' as MQA claims.
There was also notable added artifacting in the audible band.
So no, the claim that a hires file "Folded" to 44.1khz can just be played back on a normal DAC with no issue at all is certainly not true. Content is aliased into the audible band and not at acceptable levels.
I did prepare another track to test two things
Firstly, this HF band of noise is not present in many MQA files that are sourced from HiRes masters. Sam Smith's "Too good at goodbyes" is an example of a track where there is a native 88.2khz and MQA version sourced from an 88.2khz master available. It does not have this excessive HF noise. BUT, looking at the original 88.2khz master, you can see that the >22.05khz content was cut anyway. Therefore I suspected that the level of noise added by MQA is proportional to the amount of ultrasonic content it has to fold/reconstruct.
Secondly, I wanted to test what level MQA would encode lower level ultrasonic content down to. Say a signal at -60dB instead of -10dB.
I had submitted this to the publisher, but unfortunately MQA had removed all of my content from Tidal before this track went live and I was never able to test it.
If MQA sends me this file, I will update this post with findings. But I doubt that is going to happen.
Unfolding 44.1khz
So, what happens when we unfold either of these files?
Firstly, I found it curious that even the file where i'd given a 44.1khz master authenticated as "MQA Studio" on the DAC, not just the normal MQA green/magenta light.
Why is MQA unfolding this at all? There was never any ultrasonic content in the master to 'restore'.
Other issues with MQA's "Authentication" have been demonstrated by @FredericV here:
I think it's fair to say MQA's "Authentication" authenticates nothing.
The file is NOT the same as my master, you can alter and chop off large portions of it and still have it authenticate, and it was also never from a high-resolution master.
This imaging is a result of MQA's "Leaky" filter. An issue which has been discussed both by @Archimago in his excellent write-up here:
And by @The Computer Audiophile in his 2018 RMAF talk:
In that talk by the way, MQA handwaves away concerns and implies that the information is simply biased, and cannot be trusted unless Chris reveals his source's real name.
He quite rightly said that ANYONE can demonstrate this issue. And if you'd like to do just that, i've written a post how to do exactly that here:
This post guides you how to test the 'first unfold'.
Mans Rullard has also created a tool to add MQA flagging to any MQA file to trick a DAC into using it's internal MQA renderer filter if you'd like to test the 2nd/3rd unfold "renderer". I've added a .zip for a working windows version to this post, called "MQATools.zip". Simply extract, open up powershell and type:
./mqbgen.exe inputfilename.flac outputfilename.wav
Easiest way is put the input file in the same folder first.
@Miska has also posted a graph of the renderer filter in that thread.
Using the whitenoise in my file, this was the response I got from the 44.1khz file by doing an internal Full Decode on the iDSD Diablo (with HQPlayer Sinc-L in white to show where noise is due to device limitation)
Fun fact: The ifi GTO filter is basically the same as the MQA Full Decode:
Anyway, getting back on-topic, the 44.1khz file simply exhibited imaging problems due to the 'leaky' filter. There was no high frequency content 'restored' because it was never there in the first place. Neither the stock or unfolded 44.1khz files were "lossless".
More concerning, Tidal actually did not offer a lossless version of my track. And i've since found that whilst a track/album NOT marked as "master", it will genuinely stream lossless. For any track/album where it IS marked as "master", the 'hifi' setting simply streams the MQA file but without MQA flagging and does not unfold it. It is the same file!!
This means that for any track marked as "Master", Tidal no longer offers a lossless version, you ONLY have compressed, or lossy MQA.
Tidal also shows absolutely 0 indication about what the original master sample rate was, even though this info is included in the file and services such as roon will display it.
This means that customers have absolutely no idea what they're getting, whether it is from a true Hi-Res master or just poor upsampling, and more to the point, the stock 44.1khz/HiFi version is NOT LOSSLESS. You literally CANNOT avoid MQA for a track marked as master unless you opt for compressed.
Some releases have a separate listing which is not marked as MQA, but this is not universal unfortunately.
The impulse response also now had even wonkier stuff going on which I really don't know how best to describe:
Lastly, a "Full Decode" of the file just results in upward imaging further:
Unfolding 88.2khz
So what about unfolding the 88.2khz version? Does it actually restore high frequency content? Are their claims true?
Well...actually yes....sort of....
With the first unfold done, as you can see above, it DOES put back the high frequency content. However that massive band of noise is still present. Centred on about 25khz.
The audible band has had the overall level of noise reduced compared to the 44.1khz file, but there is still noise present. Additionally, in the places where MQA is needing to 'restore' high frequency content, it leaves audible band artifacts which are not present in either the original master, or actually the 44.1khz MQA file either. And do not exist in parts of the track where there was no ultrasonic content.
This means we effectively have a reduction in dynamic range/added noise whenever MQA is 'restoring' content. Both in the audible and ultrasonic bands.
So to my surprise, yes, MQA does restore ultrasonic content, however it is still quite frankly plagued with issues and the result is still nothing close to my original master.
Once a 'Full Decode' was done, these problems still exist and we just see upward imaging once again.
So:
- MQA is not lossless in either stock or unfolded form. Regardless of original file sample rate.
- Most MQA releases are simply being upsampled, and are NOT sourced from high resolution masters.
- MQA aliases high frequency content down into the audible range with minimal attenuation.
- MQA does put back high frequency content, and remove the previously aliased content when unfolded, but leaves distortion and noise behind.
- Tidal no longer offers true lossless streaming for any track marked as "Master" that I could find. You either have compressed, or lossy MQA. The lossless FLAC is not available and you must use an alternative service such as Qobuz or Deezer.
- MQA 'authentication' and the blue light gives no guarantee of source sample rate or lack of alteration. And does not guarantee that the sound is the same as was in the studio
- A huge number, presumably most, of MQA releases are just upsampled and altered 44.1khz. Not Hi-Res
- MQA like for like offers no file size advantage, and is actually bigger than 44.1khz FLAC. Though is smaller than Hi-Res flac.
Opinion
Now, with the testing out of the way, i'm going to give my own opinions about this situation, MQA in general, and why I did this testing.
The following is my own view, not necessarily fact:
I am an audiophile. I love the gear, I love the music, and I love when a technological advancement brings an improvement to our listening experience.
But anyone in this hobby will tell you that there is a LOT of snakeoil about.
There are plenty of products that promise a better experience and claim to be the best way of doing whatever it is they're doing. But there are two key categories.
- Those that have evidence or can be tested by third parties
- Those that are cannot
There are people like Rob Watts of Chord, who is quite vocal about the fact that he believes his WTA filter design is the optimal method for playing back 44.1khz audio. And not only is evidence given for this, you can test it yourself.
Anyone with a chord dac or a chord M-Scaler is free to play and record any music or test signals they wish, and Rob Watts has also been very responsive on places such as head-fi, writing up detailed posts about how and why his design works.
He isn't going to hand over the filter coefficients, but he'll answer enough questions and provide evidence for you to make an informed decision as to whether you agree and would like to purchase his product.
Same goes for @Miska and his excellent HQPlayer software, which literally has a version that provides direct file output, which you can test with upto 60 sec audio files for free.
Miska is super active on APS and on roon forums answering people's questions about both his own product and the area of digital reconstruction and playback in general.
Similar story with DSD. It is open, anyone can encode and play back files using it, and it is completely able to be poked, prodded, explored, and have the pros and cons discussed.
But then there are companies like MQA.
Not only has MQA has not provided evidence. They prevent you from gathering your own.
You cannot encode your own files in MQA or record the final output of a full decoder, it just operates on a "trust us its better" approach.
Their marketing claims are vague and change and they get disproven.
They have released information and done some things that are genuinely fascinating. MQA's "white glove" treatment, correcting for problems in recording equipment, is truly fantastic and giving the "fairytales" article a read is highly recommended. But the way it is presented makes people believe that this is how MQA's core product works. When it isn't.
The implication is that all MQA releases are better than FLAC, when the majority of it is just upsampled 44.1.
Bob Stuart's blog provides an explanation for how MQA folds high frequency info, which could never work with a 16 bit file as it wouldn't have enough dynamic range.
When issues are presented to them they dodge the question and try to divert the conversation.
And all the while, more and more music content is being replaced with MQA, more and more hardware is supporting MQA, and it continues to spread, with the supposed benefits being unproven and its problems only steadily being exposed as people find ways around the testing roadblocks.
The reason hardware manufacturers are supporting MQA isn't because they genuinely think it works and is better than native hires. Its because you, the consumer, are demanding it.
Various companies such as Schiit, Linn, and even PS audio who's DACs do support MQA, have spoken out against MQA.
Paul from PS audio talks in a video about this, saying that it was added because so many people were demanding it, but he still doesn't like it.
It is a business decision, and regardless of MQA's technical performance, no one can dispute that it is an absolutely fantastic example of the power of marketing.
I like progress, I like advancements in allowing us to enjoy music all the more. But MQA has various demonstrable problems, none of which exist if you simply stream native hires flac or even just 44.1khz.
I cannot recommend ANYONE use MQA in any situation, and you should vote with your wallet, don't buy products that have costly MQA licensing fees tacked on, don't subscribe to platforms like Tidal that are removing lossless content. And demand that companies be honest and transparent about the products they sell.
If a company can't provide it's own evidence, and goes to great lengths to prevent anyone else testing it, that should probably raise a few red flags.
MQA's Response
Immediately after MQA removed my content from Tidal, I posted here and in a few other places to encourage people to go and find the tracks on Tidal or Roon. They could not be streamed, but could be seen. This was so MQA wouldn't later be able to claim they never existed, and there would be "witnesses" so to speak.
AFTER that happened, I received a response from MQA. Their full response can be read here: https://pastebin.com/2YfT6vfZ
I won't address every point as much of it is marketing speak. But there are a few i'd like to address:
- The first part discusses how MQA is more advanced than conventional approaches and intends to account for the conversion process at each end of the chain.
To which i'd respond with two things:
1) In that case why is Warner, who offers MQA for seemingly most of their releases, not using MQA for archival storage? Or anyone else for that matter?
2) Why was I never even asked during the publishing/MQA encoding process about what recording methods or hardware i'd used? I also used a fully MQA certified full decoder for output so that cannot be the issue. And digital recordings were made from Tidal or Roon's MQA core decoder.
More to the point, even if you DID have info about the source and DAC hardware components, how would you account for tracks where multiple ADCs, synths, recording methods and in-production editing methods were used? Hardly any music nowadays is produced in analog and then digitised, or digitally recorded using only one ADC model.
- "We don't understand your frustration about evaluating MQA."
My frustration is that no end to end analysis tools are available like they are for nearly EVERY other format. Yes we can listen to any MQA song, but we have no information about how its been altered, is it the same master, no way to check for placebo, or any way to objectively test with test files other than jumping through hoops like I had to do for this video/post.
Additionally, when someone like Chris Connaker, Mans Rullard or Archimago provides evidence, the question is dodged, and when I reach out to you, you attempt to censor me by removing all of my content.
THAT is my frustration. It isn't transparent in the slightest and MQA responds in a hostile manner whenever criticised.
If you truly stand by your claims, myself, and just about anyone else would be more than happy to work with you to conduct testing that both sides agree on to demonstrate your claims. But when all the evidence suggests your claims are false, and you do not allow proper testing or provide your own, there is absolutely no reason to believe you.
- "This [the MQA encoder] is not configured to deal with content where, for example, the statistics change mid‐song, or where the audio does not resemble natural sound."
Does that then imply that electronic music won't work with MQA? Or that tracks with a combination of 'natural' recording and synthesised parts won't work?
Right now none of the tracks in Tidal's top 10 are true analog recordings, and 8/10 are in MQA.
Maybe the 'studio tools' that are referenced in your response do help to overcome these issues, but again, there is no transparency. We have no idea what these tools are, who has access to them, which releases were made using them, and have no way to evaluate them.
Would you ever consider making a limited version of these available? Perhaps releasing a version that only allows for a max 10 second audio length. This would allow people to test properly.
A little transparency would go a LONG way. And saying that MQA is lossless, but only within certain vague and unspecified criteria, and lossless only using non-conventional evaluation methods, isn't exactly reassuring.
- In regards to my mention of the blue MQA authentication indicator they said: "The onus is on the submitter to check the content when it arrives in Tidal and confirm the sound."
This was NEVER mentioned during the publishing process. And doesn't address the fact that you can take an MQA file, throw away a third of it, and still have that light show up.
Plus, even the 44.1khz file I submitted both sounds different and is objectively different to the master I published.
And again this is the same for any other track where a high sample rate version and MQA version are available, they are not the same.
- The next part of their response goes on to explain how MQA adaptively identifies and responds to content in a track.
This again, implies that it cannot be lossless. If it is behaving differently to different types of recording and music then the result will not be consistent.
It might sound more 'natural' to some people, but sounding natural and being lossless to the original master are not the same thing.
If you wish to market an 'AI upsampling' or responsive/adaptive process then that's totally fine. But sounding subjectively better to some people does NOT make it lossless and is no excuse to make false marketing claims.
- They also discuss the files I had published.
I should firstly mention that the information and status messages they're providing here, I only ever received one of these, the one saying that the encoder was unable to encode the file. And that was only for the files where it was literally just a test file, an impulse response or square wave without any other content, which would likely not pass MQA's checks for this sort of content.
All the other error messages, I never received, I do not know if these are genuine, and given as MQA had the publisher remove all of my content I cannot go back and check.
Given as I cannot verify any of these, and even if they are true it doesn't address the fact that the encoder was unable to handle my files, I won't discuss this point further.
- In response to my concerns about added noise, MQA claims that this was my fault, as I didn't dither the files. Claiming this was a "Naive mistake".
No MQA, it wasn't. In fact this was something I had explicitly tested. The first track I submitted, called "Try again", DID have dither, and showed all of the issues mentioned in this video, in fact some to a worse extent. To give MQA the benefit of the doubt and check that the dithering wasn't adversely affecting anything, I published the next two tracks without dither.
So this is not my fault at all, and the only Naive mistake made was not looking at all three files I had published.
- In response to others and my description of the MQA upsampling filters as leaky, they claim this term is derogatory and inappropriate. And that the only alternative would be brickwall bandlimiting.
Firstly, I don't think that the filter itself has feelings, but if I have hurt them then I apologise. Secondly, perhaps the biggest advantage of genuine native hires audio is just this. It allows much more flexibility with filter design. Going from 44.1khz to 96khz source sample rate gives you over 13x more distance between the audible band and nyquist frequency.
So if the argument is that brickwall filters are bad, which to be clear, in many aspects I agree with, the solution isn't MQA, its to use native hires!
- In regards to aliasing they claim that this is simply because the levels of the signal were too high and it wouldn't occur in real music.
For this point, I'm quite happy to accept this might be the case. (Though I would say it still is concerning that the encoder wasn't able to handle even simple sines, and still invalidates the "Lossless" claim.)
In fact as I mentioned earlier in the post, i'd prepared another track with ultrasonic content at much lower levels to test what level this was aliased down at. Unfortunately you had my tracks removed and this never made it to Tidal.
If this claim is true, then send me the MQA encoded version of that file and i'd be happy to post here with updates.
Again, lack of transparency makes it difficult to address concerns.....
- They also say that every MQA file will tell you the sample-rate of the original audio.
And this is true, but my complaint wasn't that it didn't tell you at all, it was that it isn't clear in the slightest. Tidal shows no indication at all of original sample rate.
You have to use a program like roon to show this information. This means it is misleading consumers into believing that any MQA release is better than RedBook FLAC.
I conducted a survey, which got over 250 responses, and of those who said they thought MQA was a good thing, TWO THIRDS of them believed that not only was MQA better than redbook, it was the same or BETTER than 24 bit 192khz FLAC.....
This is a concerning statistic as it simply isn't true!
I understand this lack of transparency may be Tidal's fault not MQA directly, but it is the combination of Tidal's lack of transparency and MQA's marketing that is having the harmful effect of misleading consumers.
Lastly i'd also just like to say. Obviously this is not 'ideal conditions' testing. But given the evidence shown and MQA's response, quite frankly until they provide something concrete, there is just no reason to trust them at all.
I, Amir, and many others would be HAPPY to work with MQA to test various claims, but the testing done here is the best we can do with the tools available.
Until MQA becomes more transparent, the objective evidence from various sources suggests it is riddled with problems.
Further Reading:
Bob Stuart wanted to censor AS: https://audiophilestyle.com/forums/...porware/page/584/?tab=comments#comment-958011
How to test MQA's leaky filter: https://audiophilestyle.com/forums/topic/62669-how-to-demonstrate-mqas-leaky-filter/
2018 RMAF MQA talk by Chris Connaker:
Archimago's MQA article: https://audiophilestyle.com/ca/reviews/mqa-a-review-of-controversies-concerns-and-cautions-r701/
PS Audio vid on MQA:
Schiit on MQA: https://www.schiit.com/news/news/why-we-wont-be-supporting-mqa#:~:text=Today, Schiit Audio announced that,so that they may choose
Linn on MQA: https://web.archive.org/web/20201111211105/https://www.linn.co.uk/blog/mqa-is-bad-for-music
Neil Young removes albums from TIDAL: https://neilyoungarchives.com/news/1/article?id=Tidal-Misleading-Listeners
John Atkinson of stereophile confirms low-level distortion: https://audiophilestyle.com/forums/topic/30381-mqa-is-vaporware/?do=findComment&comment=980145
GTO filter analysis: https://audiophilestyle.com/forums/topic/55951-ifi-foe-fum/#comments
Benchmark Audio's statement about MQA transient shifting: https://www.theabsolutesound.com/ar...lifier-and-dac3-b-digital-to-analog-converter
RealHD stops supporting MQA: https://www.realhd-audio.com/?p=7218
Archimago on transient smearing https://archimago.blogspot.com/2018/02/musingsmeasurements-on-blurring-and-why.html
Rob Watts on digital filters: https://www.head-fi.org/threads/watts-up.800264/page-134#post-15968970
Benchmark on MQA: https://benchmarkmedia.com/blogs/application_notes/163302855-is-mqa-doa
Meridian has doctored tests of hi-res in the past: https://audioinvestigations.blogspot.com/2015/07/the-great-debate-amir-vs-arny.html
Filter ringing (with a link to Mans/troll audio) https://audiophilestyle.com/forums/...porware/page/699/?tab=comments#comment-983918
Aliasing vs. imaging: https://audiophilestyle.com/forums/...porware/page/683/?tab=comments#comment-980885
Music aliasing distortion example: https://audiophilestyle.com/forums/...porware/page/683/?tab=comments#comment-980857
Linear phase vs. Minimum phase: https://troll-audio.com/articles/linear-and-minimum-phase/
Sox settings to duplicate an MQA filter: https://audiophilestyle.com/forums/...echnology/page/7/?tab=comments#comment-754014
JA's post showing signal aliasing: https://audiophilestyle.com/forums/topic/30381-mqa-is-vaporware/?do=findComment&comment=980401
mansr's original Dragonfly DAC analysis: https://audiophilestyle.com/forums/...analysis/page/20/?tab=comments#comment-690307
Why MQA's digital filters blur the music: https://audiophilestyle.com/forums/...porware/page/470/?tab=comments#comment-936690
A Survey of Musical Instrument Spectra to 102.4 KHz https://www.cco.caltech.edu/~boyk/spectra/spectra.htm
RealHD Audio on MQA: https://www.realhd-audio.com/?p=6517
Steve H
Valley of the Sun
It may be a rounding error in the marketplace, but 3 million subscribers is A LOT of revenue, especially in the audiophile world. And if folks still generally believe that MQA has some value, which according to @GoldenOne survey they do, Spotify lossless is not going to be the nail in the coffin. On top of all this, plenty of recent and upcoming electronic devices are MQA compatible, and I don't want to see consumers pay the extra dough for a feature nobody needs.
In 2017 Tidal had just over 170,000 subscribers to its lossless tier, just under 950,000 subscribers total and had revenue of $116,779,000. In 2019 their revenue was $166,910,000. Those are not indicative of 3 million subscribers.
Lossless streaming is about 1% of the market, a little over 4 million.
MQA is seen to have value because people believe Bob Stuart is successful. the reality is he's lost a hundred million dollars in the high resolution area. His investors, the labels, manufacturers and the audio press simply didn't do their due diligence.
mansr
Hampshire
All recent 2L releases are MQA only. I don't know whether older ones have been replaced, but it wouldn't surprise me.
jensgk
Denmark
RichB
Massachusetts
Oukkidoukki
Go check this....its pretty amazing.....they have left dynamics wide open, no typical mastering.....need to put volume put then pretty awesome.....ipad is full volume and jds o2 full on high gain...to k702.....still not too loud....tells something.....and still using ipad 16bit headphone out so its not high def.....gotta test some fn dongles some day!:D
Racheski
Chicago
I was going by what someone had posted earlier, but yeah it looks like Tidal fudged that number in the past. So let's say they have somewhere between 1.5-2M subs; that's still a nice chunk of change.
Maybe from an investor perspective, but consumers buy the MQA plan because they believe MQA will sound better. I highly doubt the majority of them know who Bob Stuart is.
dmac6419
USofA
According to one report, streaming subscriptions as of Q1 2000 were:
Spotify: 128 million
Apple Music: 72 million
Amazon Music: 56 million
Tencent Music: 44 million
Google Play / YouTube Music: 24 million
Deezer: 8 million
Pandora: 4 million
Others: 64 million
Among “others,” Tidal claims 3 million subscribers, or about 0.7% of all streaming subscribers.
So 99.3% of music streaming subscribers do not have access or listen to MQA. In fact, 97% don’t even seem to care about CD quality lossless streaming.
So basically MQA is a rounding error in the marketplace. It will not be the differentiator that drives Tidal to overcome Spotify.
Don't really care Jack has more money than Spotify,how many paying customer do Spotify have,nothing against Spotify,Spotify has yet to make a profit.
dmac6419
USofA
People buy 24/192 for the same reason,what's your point.
Jimbob54
Wish I'd have captured the album title /cover too, but here https://www.audiosciencereview.com/forum/index.php?threads/something-very-strange.15049/post-472670
Status
