Prana Ferox
Amir, this test was clearly botched and it's no wonder the results were bad, the display says right there, remove the film before use
Do you know what subjective means? It means it is specific to the subject (you). If you hear great things, that only applies to you. It is absolutely meaningless to anyone else. You hearing great things is not the definition of good sound quality, only of your preferences.Amir, I very much respect your technical background. Measurement numbers are not the same as sound quality which is necessarily subjective. How many live concerts have you gone to in the last 3 years? I have never read a music review that you wrote. Are you qualified to talk about the sound of music?
You do realise that he doesn't owe us anything, there is no should when he is doing it for free. Get a grip --- please!With his expertise and the resources available it should answer some questions about why the product is so inferior.
Thank you so much for sharing. I read this post carefully.
I can explain the content of the subject test through our design experience.
It took me more than three years to design DA005. Roughly estimated, I had done nearly ten different designs. In the test, I found that if all the parameters were set according to the "best" of the instrument test, the final sound was not what I wanted.
Our development process also confirmed the widely debated idea that hiFI systems are generally not sound good or bad through test instruments. Any experienced electronics engineer can do it well, and it doesn’t require much effort or musical awareness. I don’t really want to argue too much about that. The customers who have heard about our products have the best say.
If he designed the unit "by ear" then why publish specs that cannot be verified?A person over at the Audiogon forum reportedly contacted the designer of this DAC, "Jinbo Lee" and asked about the measurements here and he responded with this:
I would expect an explanation for its marginal showing, whether it's a sample-related issue or the result of specific design decisions, to come from the device's maker - not the person performing the test/review of their product. If they can show that there were procedural issues on Amir's end, it would be to their benefit to say/show what those were, no?An explanation of the results he gets is the point. With his expertise and the resources available it should answer some questions about why the product is so inferior.
He showed how it performed with 2v output, and the graph showed that best SINAD was in the range of 1.5v, so what exactly are you complaining about there?As it is his answer is, this is crap and I get to try to figure out why on my own.
I am not saying we are not getting our monies worth. We are, that's the problem.You do realise that he doesn't owe us anything, there is no should when he is doing it for free. Get a grip --- please!
So not only is it worse than an ODAC, it might burn your house down. At least it will look good while doing so.I forgot to mention that I did no see any regulatory/safety certification on the box.
I am well aware of that unfortunate trend which has gotten hold in mass market products with some devices shipped with nothing but a bootloader! This DAC is not one of those. This is a very low volume device sold at very high price. While typical smart devices have massive amount of software so huge potential for bugs, etc., whereas this is a simple device and I expect it to come to me in working condition. It is not like I am complaining about functionality of the UI, etc. that is software intensive. This is electrical performance I am measuring.As someone who works for a consumer/pro electronics manufacturer, I can tell you that products of any price usually don't ship with the latest firmware for logistics and tracking reasons. FW updates can involve a whole change request process including labeling updates, documentation updates, manufacturer coordination of the change over, manufacturing process updates, etc. If a major bug is discovered in the FW, the devices may have to be recalled by the distribution center and hand updated/reverted to a corrected FW. It is a costly endeavor that has little benefit.
The above graph is from XLR output. Don't confuse that that with the 2 volt output Dashboard which uses RCA out. The XLR output goes to 4.2 volt.The normal 2v sinad claims -95db. Upon further investigation the best case sinad happens at 1.5v as you say. At 2v, however, the sinad is at -104db on that same graph. What do you suppose is gong on?
His statement immediately preceding that graph said, "I suspected the output stage may be saturating so ran a sweep". Did you not read that?View attachment 207476
I was wondering how long it would take for someone to find that mistake!!!Amir, this test was clearly botched and it's no wonder the results were bad, the display says right there, remove the film before use
Two possible reasons that come to mind:
- auditory acuity - some people, particularly younger people, have better hearing than others so they may pick up on things that (dis)please them
- listener preference/bias - it's perfectly fine to say I prefer the sound of "X" over that of "Y", but that's not a basis for saying "X" is objectively better than "Y".
Yes, but science is not required, just basic logic (I would say "common sense" but that is surprisingly uncommon).“I’m not likely to make any progress here?” I think you are the one being dogmatic. Rather than hanging on to a belief that burn-in is real, why not open your mind and question your beliefs and look at the science? We are all here to learn, not to preach. Audio is science, not religion.
IMD ESS Hump is a design issue. It is not caused by a broken unit. As to reason, seems like they company gave us the answer above. They messed with the design until it sounded good to them. Without measurements, they are shooting blind and created what we see. If the measurements were wrong, I am sure they would have responded with better ones.The measurements are pretty bad, very disappointing. THD is not the top, but IMD and ess hump is the real problem.
The power supply seems to be implemented very well meanwhile. However, how did it happen that the measurement results are much worse than the specification? Is it a broken unit?
Yes, that is the $3,299 questionIf he designed the unit "by ear" then why publish specs that cannot be verified?
^^^ This ^^^Do you know what subjective means? It means it is specific to the subject (you). If you hear great things, that only applies to you. It is absolutely meaningless to anyone else. You hearing great things is not the definition of good sound quality, only of your preferences.
We don't even know (because you haven't tested blind) if the great things you hear are due to the nature of the sound reaching your ears, or are due to what goes on in your brain due to the unconcious bias you (like everyone else) are subject to.
