Music Hall Dac15.2 Review
This is a review and detailed measurements of the Music Hall Dac15.2 audio DAC. It is on kind loan from a member that sent it to me back in spring of this year! For one reason or the other (mostly because he didn't complain :) ), it has been sitting in a box until now. The Dac15.2 is an older product which I think came out in 2013. I still see it on sale though. The cost is around US $200.
From the outside, the DAC doesn't distinguish itself from myriad of other DACs other than the brown color of the fonts which look kind of nice:
Here is the back panel:
The main unusual thing is S/PDIF out which is not always seen on such DACs.
Power is provided by a heavy 12 volt, 1 amp external brick. This day and age it would have used a switching power supply.
Despite its age, the Dac15.2 was plug and play with Windows. And contrary to what the manual says, it was happy playing 192 kHz sampling rate.
DAC Audio Measurements
As usual we start with our dashboard of 1 kHz full amplitude tone:
The Dac15.2 uses TI PCM1796 spec and achieves its THD+N right on the money. This places it in the competent category of all DACs tested:
I am not too happy about that spike at 120 Hz which indicates power supply noise. That hurts the noise performance of the unit as it almost rises to the level of harmonic distortions. Luckily we don't hear too well in low frequencies so it is not an audible concern.
Speaking of noise, here is our dynamic range:
We are not close to matching chip specs which likely used a much cleaner power supply. Still, what is there is ample good enough for everyday use.
Intermodulation distortion+noise shows slightly elevated noise level relative to our reference DAC but otherwise good:
Music Hall Dac15.2 USB DAC Intermodulation Distortion Audio Measurements.png
Jitter test shows a lot of interference sources but levels are way too low to worry about:
Linearity follows the same class of performance:
As does our 32-tone test:
Filter response is not programmable and pretty standard for what comes in DAC chips by default:
THD+N versus frequency shows much higher levels than it should:
This test uses 90 kHz bandwidth (the dashboard uses 22.4 kHz). So let's look at that broader spectrum and see what is going on:
Ah, we see classic rise noise level due to "noise shaping" used in the DAC. In brief, noise from audible band is pushed out to ultrasonic/inaudible band. And that hurts the measurement and the eye, but not the ear.
Despite its age, the Music Hall Dac15.2 turns in competent performance showing that even back then, one could design a good DAC. Today, it is not competitive with much more optimized designs we see at even lower prices. So for new purchases, I suggest looking elsewhere. If you have one though, or can find one used at low price, then it is a good option.
Tomorrow we have to take all the panthers to the vet for their annual check up. They are going to charge us extra money because the panthers don't move so it is hard to examine them. In short, it is going to cost a fortune so I appreciate you all donating using : https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
digicidal
Sin City, NV
Not bad at all for the price and age. Still handily bests your average AVR in DAC performance (while losing horribly to them in features/inputs).
Is the S/PDIF output for daisy-chaining or ? I can't figure out why you would ever want to pass out digital from a DAC unless you wanted to use a second one with DSP for subs maybe?
Ceburaska
Gloucestershire, England
A tiny nitpick.
I don’t think the green band of DACs should be designated ‘competent’. To me that is an absolute term, whereas the bands are all relative. It’s fair to say that some of the red band DACs seem incompetently designed. But even there we could have competent, but lowly placed DACs simply due to the competition.
Another good “vintage” product if you can get it at secondhand prices.
I also fail to see the point of a digital out on a DAC. Aren’t you just putting this box in between the source and the next DAC? I guess could be useful if the final DAC doesn’t have usb? But then, why use that DAC? Confusing.
Ron Texas
Chances are, your 6 year old DAC is still good.
Tks
Bring back those outputs to today’s devices. The more the marrier.
Also that optical port with no flap door/cover got my OCD a bit active.
I’m wondering one thing about the PS noise. Can that be rectified by simply changing power supplies?
audio_tony
Leeds, UK
I suspect it would have originally been supplied with a bung for the optical port.
A PSU with better smoothing (or even a decent switched mode PSU) would sort out the PSU noise for sure I would have thought.
confucius_zero
Did u try using it with an "audiophile" power conditioner
They get used as a USB to S/PDIF converters in a pinch. Topping D10 has the same and people like it for that purpose. Indeed in that case it is not much more expensive than a dedicated device like that. So you get the DAC portion for "free."
Can't tell if you are serious or not. :) Just in case it is the former, it is cheaper to buy a new DAC without that issue.
Jimster480
Tampa Bay
i've actually used the SPDIF output on my DX7 many times.... I use it for testing other DAC's and at one point in time I used it for another DAC driving self powered speakers.
Old thread. But I have this DAC, Topping D30 and SMSL SU1 and all three sound different to my ear with my JBL S38 speakers or my MA silver 100 7g(cd player and computer output):
Toppping: super detailed and on my setup can sometimes be shrill.
Music Hall: more pleasant warmer sound at the expense of some detail. Wider soundstage.
SMSL SU1: very nice balance in bass and treble and softest highs of the 3.
I like all three and have them on there systems with topping at the office with my homemade speakers with Vida domes, smsl with the MA and music Hall with the JBL.
