Musiland MU2S Phone USB-C Dongle Review
This is a review and detailed measurements of the Musiland MU2S smartphone USB-C DAC and headphone amplifier dongle. It is on kind loan from a member overseas. It costs US $45.
Yes, Musiland seems to make countless variety of these dongles. This one looks nothing like MU2 (without S):
There are no controls on this unlike the Plus and regular versions of the MU2 series. And the plasticy unit is not going to impress any of your friends. :) Then again it may just blend into the look of your headphone cables.
Audio Measurements
I tested the unit using Roon to stream content to it on Windows 10. Here is our usual dashboard:
Maximum output is 1.7 volts which is a good step above many that cap out at 1.0 volt. This will help in powering higher impedance headphones.
Distortion is dominated by the second harmonic but at -110 dB, it is benign. What sets SINAD (signal over distortion and noise) then is noise.
Dynamic range is not bad though for the desired application:
Musiland MU2S USB-C Headphone Phone Dongle Dynamic Range Audio Measurements.png
Jitter graph shows good bit of unwanted spikes but should not be audible:
Most important measurement is how much power we get relative to distortion and noise. Let's start by testing at 300 ohm to simulate high impedance headphones:
Musiland MU2S USB-C Headphone Phone Dongle Power into 300 ohm Audio Measurements.png
Noise is somewhat elevated relative to its more expensive brothers but you get a bit more power:
Testing at 33 ohm load shows almost identical performance:
Musiland MU2S USB-C Headphone Phone Dongle Power into 33 ohm Audio Measurements.png
The family resemblance is definitely there. This is decent amount of power for a dongle:
Since output power is very similar to other ones in the series from Musiland, I did not try to perform a listening test. Read about it here: https://www.audiosciencereview.com/forum/index.php?threads/musiland-mu2-hp‐amp-usb-c-phone-dongle-review.10038/
Stepping up from $9 dongles, you definitely get more power in the Musiland MU2S so seems like a nice upgrade. As with the rest of the line from Musiland, I can recommend this dongle.
As always, questions, comments, corrections, etc. are welcome.
Quality of sushi improves during cooler weather (fish build up more fatty tissue). Alas, the price does not go down so I appreciate some donation to fix my cravings using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Luyil
Hi Amir,
Thanks for the review, impressive power for the price. and form factor. Did you get the output impedance of this dongle?
ferongr
The lack of the awkard control box like in the MU2 is a plus in my book. I'm gonna snag one.
August
Compared with the previous generation, the performance has declined, disappointing:oops:
martijn86
The Netherlands
Looking at the form factor and performance this seems to be more in line with the MU1.
Koeitje
Koeitje
Yes, I have that one. Got just enough power to drive easy to drive headphones. It broke though (bad usb connection), but they are sending me a replacement with the MQA version of their new DAC. I use it with my laptop which got a terribly noisy 3.5mm connection and my phone. Pretty good improvement for both :D.
Got good experiences with them, very good service. So I backed the Kickstarter without hesitation.
tjf
Silicon Valley, CA, USA
Hey, didn't know where to post this new device review suggestion/hope/wish...
https://www.minidsp.com/products/plate-amplifiers/il-dsp-headphone-amp
Since it uses a recent low power Cirrus Logic DAC (CS43130) that also seems to incorporate a Head Phone amp in the same LSI, and then the matching low power XCore asynch USB as the USB interface, and lastly Mini DSP EQ...and I still assume all input thru output processing is 96KHZ as typical for Mini DSP...
Amir...any shot at getting your AP rig to sort out one of these $99 devices??
Thanks in advance!
Apologies if I'm posting this request redundantly...
doctorjuggles
London, UK
Have you received your Ztella yet? I’m interested to see what people think. (And would live to see how it tests, but one thing at a time...)
Koeitje
Yes, I got both versions even. Sounds really good and has got plenty of power. But I don't have hard to drive headphones (HD25, PM3 and T51i ( or whatever it's called)).
