My affordable Rasperberry Pi Volumio streamer
telemike
Found this kit on Amazon. Adding a Rpi 4 to it made an affordable streamer I can use for Spotify Connect, Airplay and my local FLAC files on a USB hard drive. To get Volumio working I set the I2S DAC option to ST400 Dac (PCM5122) - Amp. By default they don't tell you what setting to use in Volumio. I like that the RCA output jacks are on the back with all the other connections.
TheBatsEar
Germany
Nifty one device solution. Consider loaning it to Amir for measurements.
T
telemike
I have it installed already with a Pi4 for streaming Spotify Connect
NiagaraPete
Mines kind of like that but I used a HiFiBerry Digi Pro and Dietpi with Airplay 2 and GMediarender.
FuzzTone
I put PiCore Player on mine, much better.
Try a iFI Elite for power. Or an Allo Shanti.
