My BIC F12 finally gave up. Can it be salvaged?
Jstutman
I have a BIC 12 that I've had in storage for a short while. It worked for about a week. Before this happened, I was noticing a small "popping" sound coming from the subwoofer itself.
Now the subwoofer appears to still work. I can still see it moving but barely. There is just zero excursion? Like the drivers in my bookshelf are putting out more bass than the subwoofer does at this point.
Checked fuse.
With the symptoms I'm having especially with the popping I heard from the subwoofer. I'm assuming the sub may be the culprit. Thoughts?
Jdunk54nl
Arizona
J
Jstutman
I have two svs subs which is why this one was in storage
GEJIndy
Checked fuse.
Were you ever able to get this fixed?
I have a couple of thoughts.
I have a small 10" BIC sub that stopped working. I like to repair electronics so I took it apart. It has a very simple amplifier. Anyway, I found a bad capacitor in the power on circuit. I didnt have a schematic but it wasn't too hard to fix. I have an EE background and have been repairing electronics as a hobby since I was in high school. You should give it a try.
GEJIndy
AdamG
Moderator
Reality
GEJIndy
Welcome Aboard @GEJIndy.
