pogo
- Joined
- Sep 4, 2020
- Messages
- 1,325
- Likes
- 430
Is your tone control active? The distortion disappear when tone control = on (for some reason).
Have you ever tried a hardware reset as described in post #307?
There is no hardware reset on the m33 but a hard reset...
But is there a difference between a soft and a hard reset and what are this differences?
In my opinion a soft reset can be done, when the m33 and the display is still working and a hard reset is necessary when the m33 doesn‘t reacts to any orders.
The results of the two resets are factory resets.
Or am I wrong?
This is a good point. However, I think volume management while it can be done wouldn't be convenient to use in practice while time delay is a non-issue. This is not conceptually different from using a pair of powered speakers for your HT system. So, any feature in your HT system to do time alignment will take care of any delays within the NAD (with or without Dirac engaged as long as you always use the mode that was used to measure it with the HT system).
But without a HT bypass at unity gain and also bypassing any processing (that will make it look like a clean external amp to your HT system), you have a couple of caveats:
1. The volume level on the NAD to use. In theory, you can put the NAD volume at 0db and use the HT volume control to control the volume so you have the complete dynamic range available. But this is a bit dangerous potentially unless you have an automatic volume change on switching the source. It is also inconvenient to change the volume to what you need on the NAD for the calibration done for HT every time you switch to HT from another source. If it allows you to specify a volume to start at whenever you switch to a specific input, then this becomes a non-issue. I have not seen the manual to see if it does. In this case, you can set the volume to whatever gets it closest to the volumes on the HT for other channels and then let the HT fine-tune its pre-out volume to match. The volume control on the HT system will then control all channels during use.
2. Engaging or disengaging Dirac. You can have Dirac engaged and then do the HT room EQ, so it will be doing the EQ over the Dirac corrected curve. If you don't and then use Dirac for other sources you will have to switch it off before using HT every-time unless this can also be specified as a per source setting. But this is cleaner and will work correctly with any crossed over sub in your HT system. If you engage Dirac with HT, then would need a separate profile setting for HT for the crossed over setting from the HT coming into your amp to have different correction than using another source into it for the full range.
So, while technically feasible, usability may not be as simple as a single remote click switch between HT and local sources.
Please explain
Please explain
I still have nor gotten a strong opinion about the grain issue...
Right on about the M33 remote control. The best looking, most buttoned but totally useless furniture scratcher since I had a cat. I recall BluOS has a remote that might work better with 80% less buttons. Anyone tried it?
See my post #420 for a very good alternative.
When 'audiophiles' report a particular grain issue, that experience is real.
This forum topic is so odd.
It has people that drop in from time to time to share the same problem again and again, but then disappear when given feedback on how they can fix their issues (which appear to be user originated). Then there was a mystery firmware update coming from NAD which has not happened.
Now we have folks quoting articles about grain and other negative subjective opinions that golden eared reviewers can hear only with certain speakers. I don’t know what to make of all this, but it seems very un-ASR-like.
My M33 has been operating flawless with the exception of the dumbest (but very beautiful) remote control ever conceived for an amplifier. I tested the distortion issue mentioned a few posts above using REW and didn’t see anything in the measures.
Now that I finally found a discounted NAD M33 (€4200 instead of €5500) I checked the Dirac website:
"Not The Original Owner?
I don't know what to say, but I think it's a total no go !
- If you purchased an NAD on the used market, the license for Dirac Live is not transferable from the original owner. If you’d like to use Dirac Live capabilities with your processor, you will need to purchase your own license for Dirac Live Full Frequency."
The M33 comes with the free LE version. What you’ve quoted above appears to be for the full version. I don’t see any reason why you can’t use the LE version with a second hand M33. Suggest contacting Dirac and ask them, they’re pretty good at replying quickly.
Yes, it is about the „light“ Dirac Version, I think. If the new owner wants a full version, he has to pay for. Normal.
But what about the full version of the first owner if he buys another Dirac-product with Dirac Le?
Is it possible to transfer this licence to another item?
