Geert
- Joined
- Mar 20, 2020
- Messages
- 1,973
- Likes
- 3,628
Dirac?I just came across Nad C298 amplifier review which rivals Benchmark AHB2 amps! Add a Node 2i and maybe Schiit Freya you are done and come in below M33!
Mine is connected through Ethernet too but I’ve tried WiFi as well, but it doesn’t seem to be related to the network connection since I was also able to reproduce this issue from an external device like Node 2i which has this problem when connected through coaxial or optical but it plays fine when connected through line in.I have’t had these problems at all. Had my M33 for 3 months. I have my M33 connected by ethernet cable.
I read a review that says the m33 is not using ess 9028 pro dac chips but is using ES9028Q2M mobile chips .Is this really the case.This is a much inferior chip.Is this the problem with the distortion as these are 2 channel chips and not eight as the pro are.Why use these cheap mobile chips on the m33?Only you can say whether one sounds better for you. If the M33 is not a significant improvement to your ears over the c390dd then your decision to stick with what you have is 100% spot on. I know how you feel - took me many years to swap out my amp and it was the M33 that finally convinced me to do it because it is simply brilliant to my ears - but we're all different.
Also keep in mind that you can still do full room correction on the c390dd. A Roon subscription, a bluos network bridge MDC for the c390dd - which I think you said you had anyway ... ( MDC BluOS 2i - NAD Electronics ) ... and the free REW software gives you the ability to do anything that DIRAC can do (and better in my view).
I did not experience this problem in the 6 months or so that I had the M33. Don’t have it with the M10 that I own, either.
I am. 110Hz crossover.The problem is not there unless you are using subwoofers.
I believe the clipping is happening on a large percentage of new music because of how music is mostly recorded these days If you are a person who is trying to listen to new music recently recorded this clipping issue is a problem maybe this machine was made for the classic music listeners. What a shame. Nad is catering to a dying clientele.Well then you've either not noticed it (it is very rare - only certain passages of a few songs..maybe 1 in 1000 I have heard) - or there is some manufacturing difference/component difference in production runs. Might be the power module that is known to be an issue is only in some units???
Who knows.
Sorry there will be no Dirac!Dirac?
I think we had already come to the conclusion many pages back that the M33 has a relatively common issue called intersample clipping with a specific combination of settings: Subwoofer output ON and tone controls OFF. I expect NAD will have a fix for this; given how easy it would be for them to attenuate the digital signal by 3db, I assume they’re looking at a more sophisticated fix (in the DA conversion itself) where they won’t lose SNR by attenuating.Well then you've either not noticed it (it is very rare - only certain passages of a few songs..maybe 1 in 1000 I have heard) - or there is some manufacturing difference/component difference in production runs. Might be the power module that is known to be an issue is only in some units???
Who knows.
'Clipping bug confirmed by NAD engineers. Bug limited to only those who use subwoofer and never run Dirac live or use Dirac filters with too levels too high.'
In my case, the second case occurs with main speakers only. I had already uploaded an sound example in this thread.
It is user controlled during Dirac setup.I don't know how Dirac is implemented on the M33, so does the M33 allow you to tune the filter level or is this fully automated?
I believe I said classic not classical.What utter nonsense.
You have clearly never heard the M33.
Made for classical music?
And yes I own the M33What utter nonsense.
Off but should try on again and as it totally change sound from warm to more neutral (colder) with way more bass and louder with same volume on the display screen! My speakers are Martin Logan motion ESL!Which speakers were used?
Dirac Live on/off?
