Am I being stupid now? How can you see the album art, see the track list, switch between music services, search on them, etc. that you do not a streamer without a TV on an AVR?No need to have the TV on. Just the AVR.
I thought good looking is a subjective term?It's not that good looking, though.....neither the gear nor the little of the room I see.
I appreciate if you can send me the user manual of your AVR and I expand my knowledge. But meanwhile a quick question: where do you see the album cover?No need to have the TV on. Just the AVR. Sure I change the album all the time. Isn’t that the fun of it?
Apparently. How some look at that box of electronics and think its particularly attractive is beyond me....especially if it costs as much as the Naim does for the litttle performance you get....that just makes it look worse and worseI thought good looking is a subjective term?
Ah that’s your question. I use my iPhones / iPads mainly, PC sometimes. But the UI does not define whether a device is capable of streaming or not, it is just a different UI. You might prefer a remote, I am fine with an iPhone etc. simply a matter of preference.Am I being stupid now? How can you see the album art, see the track list, switch between music services, search on them, etc. that you do not a streamer without a TV on an AVR?
I’m sorry but why do you need a streamer when your iPhone is the streamer?!Ah that’s your question. I use my iPhones / iPads mainly, PC sometimes. But the UI does not define whether a device is capable of steaming or not, it is just a different UI. You might prefer a remote, I am fine with an iPhone etc. simply a matter of preference.
You have obviously not understood the concept of an all-in-one streamer device. For starters you need a TV in order to use an AVR. Since when listening music requires a TV? And, you need a Room system with a server, which is outside the scope of an all-in-one streamer.
The iPHone is the “remote” and that’s where you see the album art etc. Yes it uses an app so … the data is not streamed from the phone it solely tells the Denon where on the eg Quobuz, Tidal, Synology server it finds the song data to play.I’m sorry but why do you need a streamer when your iPhone is the streamer?!
Back to the subject: for many a physical remote is what’s called a remote. The other is an app. What intrigues me is how do you see the album art on the AVR remote app? What make is it?
What make/model is your AVR?The iPHone is the “remote” and that’s where you see the album art etc. Yes it uses an app so … the data is not streamed from the phone it solely tells the Denon where on the eg Quobuz, Tidal, Synology server it finds the song data to play.
But we are getting way OT. PM me or start another thread if you are interested
Waste your breath, you do.You level-matched the amps? And knowledge of the amps under test was removed?
Else?
And It could well be that the speakers are indeed to drive but the Denon is supposed to be able of high current and low impedance drive...
Still... stay and learn... You will soon realize, that the notions of "thin" and compressed are most often in our minds and, eyes...
Peace
On most network streamers, the UI and remote control is an IPad or an Iphone but it streams from your home network wirelessly or trough an ethernet connection (my preference) and ultimately from the cloud, or a media server. The Iphone doesn't stream anything.I’m sorry but why do you need a streamer when your iPhone is the streamer?!
I studied the AVRs you mentioned. I can verify that Arcam and NAD have front panel displays that can display album art and has a UI which is similar to what a standalone streamer will have. Thank you for the information. I didn’t know such devices existed.All ARCAM AVRs, JBL and AudioControl not only have build in streamer, they are Roon Ready. Same for NAD AVRs, they work with BlueOS app and also are Roon Ready.
That is why I keep using the adjectives standalone and all-in-one so that we can make functional comparison to this model in review.On most network streamers, the UI and remote control is an IPad or an Iphone but it streams from your home network wirelessly or trough an ethernet connection (my preference) and ultimately from the cloud, or a media server. The Iphone doesn't stream anything.
It was the CEOL DRA-N5 (2013), about ¼ the price of Naim's bottom-of-the-range streamer-amp. Denon had a great rep here for their mini systems and I already had a UD-M30. In effect I was replacing the CD player function with a streamer and iPod dock. <https://www.whathifi.com/denon/ceol-piccolo/review>The CEOL-N10? I've heard the similar Marantz Melody, which is probably at least one-tenth as good as the Uniti Star by price.
The AudioControls and the JBLs receivers/processors are based in the ARCAM AVRs/Processors architecture. All of them run the same firmware (developed by ARCAM) so the streaming capabilities are the same. AudioControl and JBL AVRs/Porcessors also have the same screen as the ARCAMs and are also Roon Ready. The only processor that is not based in the ARCAMs is the JBL SDP-75 which is based in the Trinnov processors instead.I studied the AVRs you mentioned. I can verify that Arcam and NAD have front panel displays that can display album art and has a UI which is similar to what a standalone streamer will have. Thank you for the information. I didn’t know such devices existed.
However, I cannot see how JBL Synthesis nor AudioControl can operate as a standalone streamer. May I ask your guidance to show me how?
This is what I can find from JBL Synthesis. No model has artwork capable screen.The AudioControls and the JBLs receivers/processors are based in the ARCAM AVRs/Processors architecture. All of them run the same firmware (developed by ARCAM) so the streaming capabilities are the same. AudioControl and JBL AVRs/Porcessors also have the same screen as the ARCAMs and are also Roon Ready. The only processor that is not based in the ARCAMs is the JBL SDP-75 which is based in the Trinnov processors instead.
Thank you so much!An all-in-one streamer like this allows you to decorate your living room like in the following photograph. Can you imagine a computer, DAC and amplifier in the place of this unit? If you do, such devices are not for you.
Your point is fair and see you are keeping it light hearted… it certainly looks better than a mass of interconnects, power cords and an outdated laptop in my living room to me. But only my wife’s opinion matters there. My point is there is an aspect of being a lifestyle device with something like this. UI and UX are studied user preferences very similar to the Harmin curve we often see here on ASR. I doubt Naim did any real testing around this as only giant corporations have the capital to fund this kind of research. I just think it looks nice on the table despite its obvious technical shortcomings.Apparently. How some look at that box of electronics and think its particularly attractive is beyond me....especially if it costs as much as the Naim does for the litttle performance you get....that just makes it look worse and worse
Actually, if the streamer supports Airplay, you *can* also stream from the iDevice (or a Mac).On most network streamers, the UI and remote control is an IPad or an Iphone but it streams from your home network wirelessly or trough an ethernet connection (my preference) and ultimately from the cloud, or a media server. The Iphone doesn't stream anything.
